Group Buys Members group buys
PeeCeeBee V4H GB
PeeCeeBee V4H GB
Old 11th December 2018, 09:06 PM   #591
shaan is offline shaan  India
shaan's Avatar
Originally Posted by Medisinmannen View Post
Will add caps on my boards when i recive new pcb...
You can use 1206 series SMD caps on your existing boards for minimum footprint. 270pF 50V will suffice.
V4 GB! | V4H GB!! | PSU GB!!!
Old 14th December 2018, 03:50 AM   #592
drgnanam is offline drgnanam  India
Originally Posted by shaan View Post
Hello Members.
Since mid August I have been receiving a few reports of the amplifier setting up normally but running into oscillation and overheating as soon as the music volume is slightly increased. The sound is crackling and noisy with high current draw from power supply. No report of catastrophic failure, but it has been annoying the builders. Generally the suggested solution was to replace the 5W resistors with 2W ones, but even this didn't help a couple cases.
While I didn't face the same problem beforehand in my builds, recently after my last bunch of 5W resistors was exhausted I ordered another bunch. These were same value but from different manufacturer. And during tests was faced by the very same problem of oscillation with signal input.
I isolated the oscillation to the output section and tried whatever I could to make it go away. After a month of experiments, today evening it went away.
The culprit is the unequal gate-source capacitance of the N and P channel MOSFETs - the 2SK1058 has 600pF between gate and source pins while the 2SJ162 has 900pF.
Installed a 270pF 500V ceramic capacitor between the gate and source pins of each of the N MOSFETs (on the positive side of the board), and that's all. Now the amp is fully tame and calm. I cranked up the volume and gradually ran it right into clipping with music and no hint of oscillation in the scope. No crackle, no noise, no heat, just music, with the same 5W resistors that are very inductive.
I'm a bit embarassed because it's a very commonplace and effective trick. I wonder why it didn't struck me earlier . I understand that in an otherwise well sounding amplifier this kind of problems are quite unwelcome and I apologize to everyone who faced it during their build. In the next bunch of V4H boards there will be accomodation for the two capacitors.
Thanks for your time.
shaan
Hi shaan,
Does this problem occurs with V2 also, l had one board failure after set up , and another one looks OK , can you confirm this
Old 14th December 2018, 05:41 AM   #593
shaan's Avatar
No I did not face the problem in V2. Unfortunately I don't have any V2 boards to test. The effect of these capacitors on sonics is zero and if anything they won't make the amp unstable. So if you are thinking of adding them to your boards then feel free to do so.
Old 14th December 2018, 02:25 PM   #594
thankyou
Old Today, 06:07 AM   #595
Vunce is offline Vunce  United States
PeeCeeBee V4H GB
I finally got a bit of time to start the V4H amplifier boards
Shaan,
From the start, I installed the 270pF caps to guard against potential oscillation like you had discussed.
File Type: jpg 3E1B72FA-4369-44EC-AB13-32E4DD1557CA.jpg (1,014.4 KB, 22 views)
File Type: jpg 3278FF2B-DD35-47E6-87F9-9B1C3F07647A.jpg (828.6 KB, 22 views)
PeeCeeBee V4H GBHide this!Advertise here!
PeeCeeBee V4 GB! shaan Group Buys 936 9th December 2018 12:48 PM
PeeCeeBee shaan Solid State 2800 7th December 2018 06:48 PM
FS :PeeCeeBee V4 meanman1964 Swap Meet 0 1st December 2017 04:54 AM
Retro PeeCeeBee inspired by Juma. gannaji Solid State 20 21st November 2017 02:41 AM
FS: PeeCeeBee PauloPT Swap Meet 10 2nd September 2016 04:48 PM
