Group Buys Members group buys
PeeCeeBee V4H GB
PeeCeeBee V4H GB
Old Yesterday, 07:25 AM   #521
shaan is offline shaan  India
shaan's Avatar
Originally Posted by gaborbela View Post
I only have at home 5mm red LED, those are 2V type based on the general information. Can I use those or must be 1.8V (3mm) type?
If someone built the amp please share your opinion.
Thank you
Based on the picture some people use 3mm other use 5mm I even saw green 5mm types???
Hi Gabor.
You can use the 2V rated red LEDs without problem. However it may need only a couple turns in VR1 and VR2 to reach 10mA VAS bias, be careful during setup.
Guys (please) I really would love to get some help so I can put this project together, please
Very likely Shaan is sick, I know other peoples finished these project, what hard to understand the unwillingness to help a fellow DIY-er. Honestly, if I can (able) to help someone I usually jump in to do so.
I'm better than before but it's festive season here so giving my family some time and been wandering with them here and there. As a result could not find time to jump in.
I'm not an expert but try to help as much as I can. I hope it helps you setup your boards. Feel free to post any and all questions regarding the amp. If you want you can message me in FB too.
I having a problem to find the jumpers since there is no part number and I never used something like that before I do not wish to order some useless items. The shipping cost to me just too much to order unwanted parts.
If you can't find any 2.5mm pitched jumper header pins then use cut-off wires of the resistors, or any other wire. The jumpers need to be shorted only after setup has been done. If you don't want to or can't find jumper shunts then just solder the top of the two wires, will work without any problem.
Please, guys, I need some help!?
Maybe I'm impatient, maybe -(I suffer from PTSD and herniated low back problem, my spine pushes the nerve) These not for an excuse.
Nothing is ever taken as excuse, Come on! If it is hurting too much then I'd suggest that you don't push it too much, get back to assembling after you start feeling better.
Also, I ordered 1/2W resistor PRP type I suffered a lot to populate the boards, just found out I supposed to use 1/4W type.
Thank you.
Greetings gabor
That's unfortunate (However, don't desolder them if one's pins are not touching another resistor's pin. Don't worry the amp will work fine with either 1/2 or 1/4w resistors.
Thanks for your patience.
V4 GB! | V4H GB!! | PSU GB!!!
Old Yesterday, 07:52 AM   #522
outtek is offline outtek
Hi Gaborbela, or anyone looking for a PN from the BOM published , example:
- for the 6.35mm x 0.8mm terminal tab : 1217127-1 TE Connectivity / AMP | Mouser Romania or Mouser PN : 571-1217127-1, I would sugest to use these kind because of the kinked tabs found on each side making them more friendlier to the solder joint (these two on each side will push on the PCB so the tension will go on the laminate if soldered right at the surface of the board ) when inserting the female header on.
- example of jumper header cap of 2.54mm from Mouser : 1-881545-2 TE Connectivity / AMP | Mouser Romania , or Mouser PN : 571-1-881545-2, if you need more example just search in the category that this one is found ;
Again if you need the male or female one, just tick the desired type from the selection boxes , usually you can get these from many supplier not just mouser, I get stuff from mouser, or TME, you will find these more or less under the same category.
Cheers.
Old Yesterday, 10:10 AM   #523
Hi Shaan, what's with the 12mm straight pin header - 6 of these in the BOM, I have looked at the PCB layout and I only see the power connectors, the input one, output one and that's about all.
Thank again.
Old Yesterday, 08:20 PM   #524
gaborbela is offline gaborbela  Canada
Thank you, Shaan & Oracle1
Here is my progress, it was not easy because of the size of the resistors I ordered. I usually use 1/2W type and automatically I order those. I did not want to return for exchange because of the shipping cost plus they take of percentage for restocking.
I soldered some part on the bottom I could not do another way.
I will order some parts more (some electrolytic) the one I got way too big by size. Nichicon FG 2200uF 25V or ROE 2200 16V.
No problem because I need a few other things also.
Can I use this for a jumper? I do not see legs for soldering.
Sorry, this part is new to me. I don't know how this works, it supposed to have another part like male and female?
M7581-05 Harwin | Mouser Canada
If this OK I will order form Mouser together the other missing parts.
Please let me know, thank you!
Greetings gabor
Old Yesterday, 08:34 PM   #525
Hi Gaborbela, you can use the one you are showing as the jumper cap, you need also the one that solders to the PCB, for example from Mouser you can get this made by TE Connectivity , part number is 825433-2.
Good luck.
PeeCeeBee V4H GBHide this!Advertise here!
PeeCeeBee V4 GB! shaan Group Buys 902 Yesterday 03:40 PM
PeeCeeBee shaan Solid State 2799 3rd September 2018 09:22 AM
FS :PeeCeeBee V4 meanman1964 Swap Meet 0 1st December 2017 03:54 AM
Retro PeeCeeBee inspired by Juma. gannaji Solid State 20 21st November 2017 01:41 AM
FS: PeeCeeBee PauloPT Swap Meet 10 2nd September 2016 03:48 PM
