Group Buys Members group buys
Group buy: DCT03 DC trap (filter) for toroidal transformers
Old 26th October 2018, 05:51 AM   #121
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Please contact me for info.
/Per-Anders (my first name) or P-A as my friends call me.
My group buys Super Regulator group buy. 43 pcb's in interest. DCT03 group buy. 39 pcb's in order, 4 paid.
Old 2nd November 2018, 12:08 PM   #122
Ralphien is offline Ralphien
Finished my DC trap finally
Managed with a 50w iron but only just, used some hot melt glue between the caps to stop the board being bendy (saw someone else used it)
Found the right enclosure (see below)
It works on my power amp with the irritating buzzing toroid - excellent!
Thanks P-A
TW11-8-22B | TW ABS Enclosure, 220 x 110 x 75.3mm | RS Components
Old 3rd November 2018, 11:58 AM   #123
peranders's Avatar
It's correct that you'll need a lot of heat to solder 105 um copper and rather big parts. Personally I use a 135 W iron turned up to 400 deg C.
Old 4th November 2018, 08:45 PM   #124
AmpUtator is offline AmpUtator  United States
Thanks Per-Anders for all your help with my first DIY project DCT03/Fo-Felix EMI filter. It's working perfectly .
Old 15th November 2018, 08:41 AM   #125
Hi Per-Anders,
I've read your documentation on testing the DCT03, but I'm not sure if I need an oscilloscope or will a DMM work?
I've been using my DMM set to AC or DC volts, using either a 5VDC walwart or a 12VAC walwart but I'm not seeing 0.7, 1.4, 2.1 or 2.8 volts.
Also, my second DCT03 was built with CDE 380LX series caps, I hope those are okay, the EPCOS where out of stock at the time.
They do seem to be working okay I'm just not getting those numbers.
What am I doing wrong ?
Old 17th November 2018, 12:41 AM   #126
shattered_dream is offline shattered_dream  Germany
No problem with sparks?
Old 17th November 2018, 07:48 AM   #127
peranders's Avatar
AmpUtator, if you take a good picture of your DCT03 (both sides) I can tell you with rather high certainty that it will work.
Old 23rd November 2018, 08:42 PM   #128
Hi Per-Anders,
I built two DCT03's. The first unit uses CDE 380LX caps, (TDK's were out of stock) I hope the 380's are okay to use?
I briefly tested my DCT03/Fo-Felix build using an old receiver and didn't notice any problem.
Take a look at the photos and see if you think it looks okay.
After my enclosures are painted I'll test them both and see if I notice any sparks as mentioned by shattered_dream.
I did do a better soldering job on my second unit. I'll upload those photos later.
Thanks,
Old 23rd November 2018, 08:55 PM   #129
peranders's Avatar
It looks OK.
Old 23rd November 2018, 09:52 PM   #130
It looks OK.
Awesome. How about the second DCT03 with the TDK caps?
Group buy: DCT03 DC trap (filter) for toroidal transformersHide this!Advertise here!
Group Buy: SST03 Soft start for toroidal transformers peranders Group Buys 27 18th June 2011 10:59 AM
Toroidal Transformers etoiledusoir Swap Meet 1 26th February 2011 11:46 PM
Toroidal transformers scottw Power Supplies 19 17th November 2006 11:09 AM
Best Transformers (Encapsulated Toroidal or Open Frame Toroidal) Rixsta Pass Labs 10 23rd April 2004 04:41 AM
Copyright ©1999-2019 diyAudio
