Group Buys Members group buys
PeeCeeBee V4 GB!
PeeCeeBee V4 GB!
Old 8th June 2019, 11:40 AM   #1011
shaan is offline shaan  India
shaan's Avatar
Originally Posted by nanakos View Post
Shaan have you 2 pcs V4H?
Yes I do.
V4 GB! | V4H GB!!(ONLINE) | PSU GB!!!
Old 9th June 2019, 02:50 PM   #1012
nanakos is offline nanakos  Greece
Shaan send you pm
Old 26th June 2019, 01:40 AM   #1013
gadut is offline gadut  Indonesia
gadut's Avatar
PeeCeeBee V4 GB!
Interested for the board, any available? This will be my first class AB build and I'll be using Exicon which supposed to be for F7 but seems enough class A.
I will build separate psu box with 2x25Vac and CRC filter, will it good enough for this vssa? i find many build with additional cap multiplier but i want to make it simple.
AD1865||DCB1||FW PSU||J2||M2||SIT L'Amp||Open Baffle
Old 26th June 2019, 01:54 AM   #1014
shaan's Avatar
Hi.
Yes boards are available.
Yes it will run fine as long as the power cables between PSU and amp box aren't too long. vssa?
Old 26th June 2019, 02:37 AM   #1015
gadut's Avatar
PeeCeeBee V4 GB!
Originally Posted by shaan View Post
Hi.
30cm cable with psu box is stacked below amplifier chassis, and i always add extra caps on the chassis.
I also have unused 2x15V 120VA toroid which I will also utilised later for another board, any estimation for output power? it wil power tweeter above 3kHz hence only small powered required.
i'll send pm for payment details
Old 26th June 2019, 02:41 AM   #1016
shaan's Avatar
About 20W will be available. 120VA is ample reserve for >3KHz duty.
Old 26th June 2019, 02:47 AM   #1017
gadut's Avatar
PeeCeeBee V4 GB!
perfect shaan, finally i can utilize the 2x15V toroid which i was confused for it's usage. too big for preamp but too low for even gainclone
Old 22nd August 2019, 12:14 PM   #1018
gadut's Avatar
PeeCeeBee V4 GB!
how many A does this board pull from psu? i think I will combine this board with my class a monoblock, with 225VA supplies for 2.6A class a bias, maybe another 0.5A available without stressing the toroid
Old 22nd August 2019, 02:38 PM   #1019
shaan's Avatar
At maximum power output it takes about 2.5A when driving 8ohm loads and about 5A when driving 4ohm loads.
Old 10th September 2019, 12:20 PM   #1020
Theodosis O. is offline Theodosis O.  Greece
Hi Shaan,
I couldn't find BAV21 at Mouser and got BAV20. Is it OK ?
PeeCeeBee V4 GB!Hide this!Advertise here!
PeeCeeBee shaan Solid State 2806 4th September 2019 12:18 PM
FS: PeeCeeBee PauloPT Swap Meet 10 2nd September 2016 03:48 PM
VSSA PMI version vs Peeceebee Shaan version thimios Solid State 33 9th April 2015 11:06 AM
FS: F5X GB chassis and all GB parts Studley Swap Meet 6 21st May 2013 11:47 AM
Conrad Heatsinks GB in GB/EU bremen nacht Parts 1 1st February 2006 08:48 PM
Copyright ©1999-2019 diyAudio
