Group Buys Members group buys
GB for ArDAM Lite bare PCBs
Old 17th February 2019, 06:27 PM   #171
euro21 is online now euro21  Hungary
Default ArDAM Lite controlled DAM1941
Hi folks,
I -almost- finished my ArDAM Lite controlled DAM1941.
It's now in "breadboarded" state, but sooner or later I will make a case.
I attached my configuration's block diagram.
The ArDAM Lite PSUs is DiyInHK dual LT3042 (+transistor) versions (+5V, +3V3).
My OLED is 1.3" SH1106 chip version (I2C).
I rewrite Dimdim's code.
Because Arduino Nano has very narrow space for program, only the "necessary" commands and status informations have been implemented:
Commands:
- Volume up; Volume down;
- Source selection: Auto, USB, AES/EBU, BNC SPDIF, RCA SPDIF, Opical (Soren now not implemented I2S);
- Filter changing: four filter selection.
Status display:
- Volume;
- Type of stream (PCM, DSD);
- Sample rate;
- Source;
- Filter.
Because Nano's space is "full", the "draw_logo" procedure now is commented.
The IR codes is my remote control's code, must be change your remote codes.
Use attached Dimdim's "IR_Scanner" for detecting codes from your IR remote control.
If you want to see DAM's serial commands, use attached "serial_console" program.
Have fun and enjoy yourself!
File Type: zip ArDAM_Lite_1.30_OLED_Jolida_remote_V_1.3.zip (4.1 KB, 12 views)
Old 22nd February 2019, 04:47 AM   #172
nashbap is offline nashbap  United States
Thanks euro21. Can I buy this? when ready; no rush, still planning.
Nash
F5TV3, AVC, BA3b pre, Salas DCG3b, OBL-15
Old 22nd February 2019, 06:48 AM   #173
Originally Posted by nashbap View Post
Can I buy this?
Each component purchasable from the net, ArDAM Lite PCB there from Dimdim, 1.3" OLED, Arduino Nano, parts from ebay.
I use this PSU -because I own several pieces- for control and display:
DiyInHK dual PSU from 0.8uV Ultralow noise DAC power supply regulator 3.3/5/7V 1.5A*x2 - DIYINHK.
My breadboarded system use LT3045 PSUs for DAM, but any good PSU (for example UBiB) usable.
I bought two bobbin transformers for PSUs (INDEL 40VA 7.5V or 9V AC, depends of PSU type). Any transformer usable which have low primary-secondary capacitance. For me toroid not this type.
Old 22nd February 2019, 04:05 PM   #174
Thanks for details.
nash
Old 23rd February 2019, 11:08 PM   #175
kin1111kin is offline kin1111kin  Hong Kong
can it be used on 1541?thx
Old 25th February 2019, 02:17 AM   #176
Myint67 is offline Myint67  Singapore
i would like to buy one if still available
Old 25th February 2019, 11:13 PM   #177
Me too
GB for ArDAM Lite bare PCBsHide this!Advertise here!
GB for Leach Low-TIM with 8 + 8 BJT outputs (bare PCB) linuxguru Group Buys 55 16th June 2018 08:19 AM
GB for TPA3116/8 PBTL bare pcb DUG Group Buys 612 25th April 2017 10:00 AM
FS : Bare PCBs of latest Slewmaster amplifier (OPS and IPS) pinnocchio Swap Meet 9 14th January 2016 12:10 AM
Lite DAC 38 PCM1704 bare PCB's Alfetta87 Swap Meet 2 19th April 2009 05:48 PM
Copyright ©1999-2019 diyAudio
