Group Buys Members group buys
GB for ArDAM Lite bare PCBs
Old 16th June 2017, 06:31 PM   #111
Dimdim is offline Dimdim  Greece
The thing is that removing external power and serial lines does not do the trick, because the Nano always "sees" the isolator and its serial lines get "confused".
So I would say, definitely make the Nano removable.
http://www.dimdim.gr
Old 18th June 2017, 02:26 PM   #112
hannesie is offline hannesie  Netherlands
What is wrong ?
I don't know how to handle this.
Hans
Old 18th June 2017, 03:05 PM   #113
Probably some incompatibility with Arduino 1.6.6.
I'd try upgrading to a newer version of the IDE.
It compiles fine with 1.8.2.
Old 18th June 2017, 03:26 PM   #114
You are right, with the Arduino 1.8.3 it was with no problems.
Hans
Old 19th June 2017, 08:17 PM   #115
Sorry, I have a other problem.
I can 't find the pins for the isol_serial for pin 3 and 5 , this should be the input and the output.
I looking for the J3 and there is no input or output, am I wrong?
It is different for me, because I use the board of Kiven Chen, so I have to use the connections on the backside.
Hans
Old 19th June 2017, 09:24 PM   #116
What does Kiven Chen do with these signal pins? Does he connect them to anything, or are they unused?
I can't really tell from this side if you have soldered wires to the correct pins. Where is Pin 1 of J3? Is it top left?
Also, doublecheck that you haven't shorted any wires to gnd.
Old 19th June 2017, 09:38 PM   #117
Sorry it is at the right, under, The other pins where used for a switchboard with led's for the Amanero, and a selection knob.
No use for the RXD or TXD was in the board set-up.
I can remove that board, you can see here the other upper side.
He used it also for the IS signals for the Amanero and S/PDIF.
Hans
Old 19th June 2017, 09:59 PM   #118
Are you sure that you are not getting a serial connection? Is the Nano working as expected when off board?
Did you "train" it to use your remote control?
I think it's time to start a new builders' thread..
Old 20th June 2017, 08:26 AM   #119
First I made a better connection to make sure that there is no shorted fault.
As far as I can see there is no connection to the serial pins.
Indeed , a new builders is a good idea.
I have not test the set-up, wil do it now.
Hans
Old 20th June 2017, 09:56 AM   #120
How did you determine that there is no connection to the serial pins?
Are you measuring for continuity between your wires and the corresponding pins on your dam?
If you're measuring for continuity between these pins and the ones on J10, it's normal not to find any. They are separate serial ports.
GB for ArDAM Lite bare PCBsHide this!Advertise here!
GB for Leach Low-TIM with 8 + 8 BJT outputs (bare PCB) linuxguru Group Buys 55 16th June 2018 08:19 AM
GB for TPA3116/8 PBTL bare pcb DUG Group Buys 612 25th April 2017 10:00 AM
FS : Bare PCBs of latest Slewmaster amplifier (OPS and IPS) pinnocchio Swap Meet 9 14th January 2016 12:10 AM
Lite DAC 38 PCM1704 bare PCB's Alfetta87 Swap Meet 2 19th April 2009 05:48 PM
Copyright ©1999-2019 diyAudio
