Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Group Buys Members group buys |
Thread Tools |
#511 |
No snake oil
Victors 1kHz oscillator into RTX6001 (-10dB). ![]()
/ Anders |
#512 |
Modifications are ongoing at the moment. Shipment will resume by Monday next week.
For those who have already received their RTX6001, I have made a description of the modifications needed to improve the distortion at high input levels. Please take a look at it and report back if this is something you feel that you are able to do yourself. If so, we will send two mounted PCB's for each Analyzer. I assume most people on this forum will be able to do the modification, avoiding shipping the unit back and forth. Using a solder iron with a fine tip will be an advantage. |
#513 |
I'll perform the modification myself
![]() A brief testing procedure after the mod is made will be useful (I mean, something like measuring voltages at a few test points, before we fire up the unit to see the distortion improvement at high signal level) |
#514 |
Cwtim01, it is better to modifiy the one channel and compare it to other unmodified channel.
#515 |
#516 | |
I dοn't think, it can make it difficult for DIY members. |
#517 |
Looks to me this mod should be possible for me to do. Probably I have to add some fine tips for SMD work to my soldering kit.
#518 | |
Regards, Clemens |
#519 | |
It's also perfectly valid to just check it after completing the modifications to verify that the modification was performed correctly. For those of us in North America I would probably recommend Kynar or teflon 30awg wire wrap wire for the modification, unless the retrofit already includes the wire.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine |
#520 |
Jens,
For me no problem, you can send me the two little pcb ... Marco |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
DIY Audio Analyzer with AK5397/AK5394A and AK4490 | JensH | Equipment & Tools | 3052 | 7th February 2021 03:15 AM |
Mirand audio - AK4490 USB Dac with DSD support | ravid | Swap Meet | 2 | 23rd July 2016 05:26 PM |
Audio Precision ATS-1 Audio Analyzer works but Ugly | Zero Cool | Swap Meet | 12 | 14th May 2016 05:02 PM |
NTi Audio XL2 Handheld Audio Analyzer | Fredenando | Equipment & Tools | 0 | 18th April 2010 04:04 AM |
AKM AK5394a | TobWen | Digital Source | 41 | 31st December 2003 07:18 PM |
New To Site? | Need Help? |
