Group Buys Members group buys
xrk971 Pocket Class A Headamp GB
Old 21st February 2020, 06:04 PM   #2001
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
No, like this.
Glue Henna Dispensing Needle Tips Luer Lock Blunt End Plastic Tapered Needles 22 Gauge 100 Pieces Glue Henna Dispensing Needle Tips Luer Lock Blunt End Plastic Tapered Needles 22 Gauge 100 Pieces: Amazon.com: Industrial & Scientific
The pink ones flow a little more and can be useful as well.
Fresh solder paste that flows easily is important. Should not make you hurt your hand from having to squeeze to hard. I had that happen and it was 2yrs old way past expiry. Keep in refrigerator in a ziplock when not in use.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 21st February 2020, 07:12 PM   #2002
Vunce is offline Vunce  United States
Thanks for the kind words fellas
I took my time and had to wipe off a few pads because too much paste was applied. One of the steps that really helped was sticking the SMD components (while still in their packaged row) on a piece of blue tape to hold them in the order listed on the parts list. It kept me from misplacing components. When the board was completed, I was amazed with how fast the actual “soldering” went. With enough practice this method is much faster than soldering THT components.
Next up, Aksa Lender preamp SMT DB’s
@IAIMH
The pink tip I used came with a different tube of solder paste. The two nozzles that came with the MGChemicals paste that I used would never have worked, they were much too big. The pink nozzle hole is about 30% as big as the included syringe type nozzle.
File Type: jpg DD1BB8A1-F6CB-4237-A382-1591E9B99A5C.jpg (356.1 KB, 114 views)
Old 21st February 2020, 07:32 PM   #2003
pcgab is offline pcgab  United States
@IAIMH
I need to get some of those smaller nozzle tips. The one I have is a bit too large for smaller pads and can be a real pain to apply cleanly.
Old 21st February 2020, 07:37 PM   #2004
jhofland is offline jhofland  United States
re: ItsAllInMyHead,
The tips you point out are the correct ones. If it matters, I found them on Amazon at a better price.
Old 21st February 2020, 07:38 PM   #2005
Hey Pcgab,
If you need a lead-free low temp paste the pink tip was included
No Clean Lead Free Low... No Clean Lead Free Low Temperature Solder Paste 15 Grams - - Amazon.com
Old 22nd February 2020, 09:57 AM   #2006
ItsAllInMyHead is offline ItsAllInMyHead  United States
Thanks everyone. I ordered up a variety of the tapered tips. Brilliant. Maybe I can take up a side gig and learn to do henna tattoos. Can't imagine what they'd have to do with henna and hydroponics, but those seem to be tagged keywords.
I never thought to store it in the fridge after use. Noted with thanks. I don't use a ton of paste, so that's a great tip.
If you want a friend, feed any animal - Perry Farrell
Old 6th March 2020, 07:49 PM   #2007
Got Foam?
xrk971's Avatar
Default Updated Design for 2SK209BL and ZXMN10A8 MOSFET
Hi Folks,
Due to the end of life of my favorite JFET, the BF862 and now, the end of the old MOSFET we used, it is time to update the design to some available options. The Toshiba 2SK209BL actually is working out really well. I am getting some nice performance with about 0.02%THD for 1.0Vpp into a 250ohm load.
xrk971 Pocket Class A Headamp GB-pca-2sk209bl-zxmn10gta-v3-jpg
Old 7th March 2020, 06:05 PM   #2008
Got Foam?
xrk971's Avatar
I just built a verification unit using the above resistor settings and 2SK209BL and ZXMN10A08GTA. For R3, I did not have a 1k3 on hand so used a 1k2 1210 resistor in its place. It resulted in a slightly higher bias current iof 72mA, but that's ok as I will be using them with lower impedance phones. I am using the 2200uF 16v Nichicon rail cap as the output cap, now bypassed with a 0.1uF 100v Wima MKS. The sound is excellent!
xrk971 Pocket Class A Headamp GB-pca-2sk209bl-zxmn10gta-verification-jpg
File Type: jpg PCA-2SK209BL-ZXMN10GTA-verification.jpg (432.0 KB, 104 views)
xrk971 Pocket Class A Headamp GBHide this!Advertise here!
BF862 based SE Class A Headamp without the HEAT xrk971 Headphone Systems 522 14th October 2018 03:53 PM
FS: F5X GB chassis and all GB parts Studley Swap Meet 6 21st May 2013 11:47 AM
Midgård, compact, low distortion, high quality, Class A Lateral FET headamp Neutrality Headphone Systems 23 12th March 2013 05:21 PM
Another Class A headamp idea Dxvideo Solid State 3 19th November 2007 08:08 AM
Pocket pre-amp & headamp digi01 Chip Amps 11 10th October 2004 12:49 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
