Group Buys Members group buys
xrk971 Pocket Class A Headamp GB
Old 25th April 2019, 04:27 PM   #1891
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Yes, it could apply to the DCA, I sill need re-run the sim with IRF610 and a higher bias current setpoint on the outputs though to get design sorted out.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 29th April 2019, 06:23 AM   #1892
yourownbuzz is offline yourownbuzz  Australia
nice! would be waiting for an update to the DCA build too!
Old 29th April 2019, 02:44 PM   #1893
Got Foam?
xrk971's Avatar
Default Low bias JFET DCA
Here is the schematic for the low bias currrent DCA HPA. 118uA bias current for BF82 and 104mA for IRF610:
xrk971 Pocket Class A Headamp GB-bf862-low-bias-irf610-hpa-v1-schematic-jpg
Predicted FFT for 1.4Vpp into 250ohms (THD is about 0.01%):
xrk971 Pocket Class A Headamp GB-bf862-low-bias-irf610-hpa-v1-fft-1-4vpp-250ohm-jpg
Predicted FFT for 700mVpp into 55ohms (THD is about 0.03%):
xrk971 Pocket Class A Headamp GB-bf862-low-bias-irf610-hpa-v1-fft-700mv-55ohm-jpg
Old 30th April 2019, 03:58 PM   #1894
Got Foam?
xrk971's Avatar
Can anyone think of a device that operates with 100uA bias current and has a native speed of 0.400THz or 400GHz?
Old 7th May 2019, 09:02 AM   #1895
knauf1919 is offline knauf1919  Romania
Q1 can be replaced with J112?
https://www.tme.eu/Document/2ab8d7a6...63e9f/J111.pdf
Old 7th May 2019, 11:38 AM   #1896
Got Foam?
xrk971's Avatar
J112 is a much bigger 50mA current switch. Might not be the best use for an audio input. BF862 is still available and are the best for this application.
Old 7th May 2019, 11:48 AM   #1897
Originally Posted by xrk971 View Post
BF862 is still available...
Where?
Old 7th May 2019, 01:06 PM   #1898
Got Foam?
xrk971's Avatar
For example, AliExpress - look for code stamped 2AW. Price should not be too cheap.
Online Shop 10pcs/lot BF862 Stamp 2AW SOT-23 original authentic | Aliexpress Mobile
Online Shop 40pcs/lot BF862 Stamp 2AW SOT-23 new original | Aliexpress Mobile
If they send you one not stamped 2AW, file complaint and get a refund. All of ones I have received lately are genuine (checked with JFET Idss matching rig).
Old 7th May 2019, 01:30 PM   #1899
I never bought electronic components on that site but I'll make a try.
Thank you.
Old 7th May 2019, 01:51 PM   #1900
twocents is offline twocents  South Africa
twocents's Avatar
Thank you.
I like Aliexpress, but if you want a supplier closer to home:
bf862 jfet | eBay
xrk971 Pocket Class A Headamp GBHide this!Advertise here!
BF862 based SE Class A Headamp without the HEAT xrk971 Headphone Systems 522 14th October 2018 03:53 PM
FS: F5X GB chassis and all GB parts Studley Swap Meet 6 21st May 2013 11:47 AM
Midgård, compact, low distortion, high quality, Class A Lateral FET headamp Neutrality Headphone Systems 23 12th March 2013 05:21 PM
Another Class A headamp idea Dxvideo Solid State 3 19th November 2007 08:08 AM
Pocket pre-amp & headamp digi01 Chip Amps 11 10th October 2004 12:49 AM
Copyright ©1999-2019 diyAudio
