Group Buys Members group buys
xrk971 Pocket Class A Headamp GB
Old 26th December 2017, 11:42 AM   #1411
BYRTT is offline BYRTT  Denmark
BYRTT's Avatar
Right its looks be pure DC supply portion part and PCB also include reasonable high value capacitive buffer, but think the way power pull will be from DC supply is AC switching dictated as input audio signal demands power from DC supply.
Then again complete unit is so small so probably no problems at all for this build making it a good stiff low impedance supply
Old 27th December 2017, 07:40 PM   #1412
diyricky is offline diyricky  United Kingdom
Just trying to find my way around the design and this large thread.
On the opening post there is this line -
Edit (Dec 22, 2017) - here is the latest BOM that I use for low impedance cans with a smooth sound signature.
If I click on it, it just opened a blank page ?
Old 27th December 2017, 08:28 PM   #1413
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
Sorry about that bad link.
Should be this:
Let me fix index. Thanks.
X
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 28th December 2017, 07:46 PM   #1414
freebee is offline freebee  Netherlands
Probably not a good idea, but would it be possible to substitute R5 and RL 270 Ohm with either 200 or 330 Ohm? For some reason I'd like to use the following 'audio' resistors :
Mouser No: 754-RS2012P-331-DT53
Mfr. No: RS2012P-331-D-T5-3
Mfr.: Susumu
Otherwise I'll just use 270 Ohm from a different series.
Old 28th December 2017, 10:19 PM   #1415
Got Foam?
xrk971's Avatar
Mfr.: Susumu
Make R5=200ohm and RL=330ohm and it should work fine. Nice performance actually. This is pushing 1.2vpp into 330ohms with 58mA bias current from 16.4v supply.
Harmonic Frequency Fourier Normalized Phase Normalized
Number [Hz] Component Component [degree] Phase [deg]
1 1.000e+03 9.126e-01 1.000e+00 -179.97° 0.00°
2 2.000e+03 2.724e-04 2.985e-04 90.14° 270.10°
3 3.000e+03 5.728e-05 6.276e-05 -179.89° 0.08°
4 4.000e+03 1.017e-06 1.114e-06 -102.06° 77.90°
5 5.000e+03 5.473e-08 5.997e-08 179.87° 359.84°
6 6.000e+03 1.409e-07 1.544e-07 179.51° 359.48°
7 7.000e+03 1.214e-07 1.330e-07 179.98° 359.95°
8 8.000e+03 1.062e-07 1.164e-07 179.98° 359.95°
9 9.000e+03 9.469e-08 1.038e-07 179.99° 359.95°
Total Harmonic Distortion: 0.030507%(0.030480%)
File Type: jpg Pocket-Class-A-R5-200ohms-RL-330ohms.jpg (29.6 KB, 220 views)
Old 29th December 2017, 01:10 PM   #1416
Great! Thanks a million! Almost ready to order the parts. Will let you know how it turned out. Any reason for using Nichicon KA 2200uf 16v instead of Silmic (apart from size)?
Old 29th December 2017, 02:08 PM   #1417
Got Foam?
xrk971's Avatar
According to StellearElephant, who did listening tests (all subjective), if I can paraphrase him, KA sounds more detailed and has good bass and balanced . Silmic II is smoother and less forward and softer details. It’s all a matter of taste. He also found that adding film bypass did not change much.
Old 30th December 2017, 07:05 PM   #1418
I've been trying to find a 6mm d-shaft max. 12mm knob, however they seem to be difficult to come by. Any idea as where to get one?
Also is it ok to use 10K or 15K for RLED (instead of 12K)?
Old 30th December 2017, 08:03 PM   #1419
Got Foam?
xrk971's Avatar
Work fine aluminum alloy knob 15MM * 16.5MM 15MM * 17MM silver half shaft hole D hole potentiometer-in Switch Caps from Home Improvement on Aliexpress.com | Alibaba Group
Old 30th December 2017, 08:10 PM   #1420
Always go for the larger 15k resistance which means the led will be dimmer.
Generally you find such indicator leds annoying if they are too bright
Cannot be more precise since we do not know the exact parameters of the led you purchase, they all vary slightly.
xrk971 Pocket Class A Headamp GBHide this!Advertise here!
BF862 based SE Class A Headamp without the HEAT xrk971 Headphone Systems 522 14th October 2018 03:53 PM
FS: F5X GB chassis and all GB parts Studley Swap Meet 6 21st May 2013 11:47 AM
Midgård, compact, low distortion, high quality, Class A Lateral FET headamp Neutrality Headphone Systems 23 12th March 2013 05:21 PM
Another Class A headamp idea Dxvideo Solid State 3 19th November 2007 08:08 AM
Pocket pre-amp & headamp digi01 Chip Amps 11 10th October 2004 12:49 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
