Roender'S FC-100 - Group Buy
Gentlemen, I have 1 pair of FC-100 PCBs and 1 pair of LT3062-FrontEnd-PSU - PCBs left (see image).
Give me a PM if you like to have them.
Best regards - Rudi_Ratlos
Nisbeth, thank you for your quick answer.
Since you live within the European tax-union, shipping will not cost too much.
I will give you the price of the PCBs incl. shipping via PM.
Moreover: I will give you the documentation, the BoM (I even have a complete (more or less) "shopping cart" for the FC-100 components,
saved at "www.reichelt.de", drill-master, ...
We can talk about hard to get components, matching, ..., if you like.
Best regards - Rudi
Patriz, do you mean the issue described by Rudi in his builder's manual?
He solved the problem by disabling ThermalTrak diode and bypassing it with a BAT42 Schottky diode.
I'm not sure which diode should be bypassed. Rudi bypassed the second (Q2 transistor).
Also, in the datasheet of the BAT42 I can see the max forward voltage is 400-650 mV. Should it be lower @ 0.2-0.3 V?
I tested the amp again and when I power it on the voltage drop across each of the 2 emitter resistors is 38mV and then slowly doping down. After a few minutes it is 36mV and continue to drop 0.01 mV per second (from 36mV to 35.4mV in a minute).
Is this normal?
Rudi suggested checking and adjusting the bias after 15-30 minutes. Does it mean I should adjust to get 36-38mV when the amp is hot?
Once the amp is cooled down and powered back on the voltage is something about 44mV.
