The Well Tempered Master Clock - Group buy
So I see in the excel there is a standard part numbers for the freq doublers.
In the below examples the part numbers are followed by the freq needs so I assume the PCB is standard but the BOM has slightly different parts to deliver the different freq needs?
1 x TWTMC-DBM-F 5.6448 MHz to 11.2896 MHz
1 x TWTMC-DBM-F 11.2896 MHz to 22.5792 MHz
1 x TWTMC-DBM-F 6.144 MHz to 12.288 MHz
1 x TWTMC-DBM-F 12.288 MHz to 24.576 MHz
Yes, the PCB layout is the same for all the frequencies while the filters are different for each frequency, therefore some components differ from a frequency to another.
In the semi-finished board the filters components are not assembled so it's suitable for each frequency, then you will pick the right BOM according to the frequency to be duplicated.
The finished board contains all the parts already assembled so there is a specific item for each frequency to be duplicated.
wlowes
1 x 5.6448 MHz SC-cut
1 x TWTMC-DRIXO-SF
1 x TWTMC-DRIXO-XFMR 5-12 MHz
1 x TWTMC-STS-DX
-G600:
2 x TWTMC-DRIXO New Driscoll semi-finished
1 x SC 5.6448 MHz
1 x SC 6.1440 MHz
2 x TWTMC-DRIXO semi-finished
4 x TWTMC-DBM-F semi-finished
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
2 x transformer kit for Driscoll 5 to 12
4 x transfomer kit for freq doublers
-mars2:
2 x SC 11.2896 MHz
2 x SC 12.2880 MHz
4 x TWTMC-DBM semi-finished
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
1 x TWRPS-pp bare board
-tbrowne:
4 x SC 5.6448 MHz
1 x SC 6.144 MHz
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-SF
1 x TWTMC-EXO-SF
4 x TWTMC-DBM-SF
1 x TWTMC-DRIXO-XFMR 22-24 MHz
1 x TWTMC-DRIXO-F 5.6448 MHz
2 x TWTMC-STS-SX
-laserscrape:
1 x TWTMC-DRIXO-SF
1 x TWRPS-UGL-SF
-clsidxxl:
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
1 x TWTMC-DRIXO-F 11.2896 MHz
1 x TWTMC-DRIXO-F 12.2880 MHz
2 x TWTMC-STS-SX
1 x TWRPS-UGL-F
-gabor80:
2 x TWTMC-DRIXO-SF
2 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
2 x TWTMC-DRIXO-XFMR 5-12 MHz
2 x TWTMC-DBM-XFMR
-crowlie
1 x SC 5.6448 MHz
3 x TWTMC-DRIXO-SF
3 x TWTMC-STS-SX
3 x TWTMC-DIL
-wealas
2 x 5.6448 MHz SC-cut
2 x 6.1440 MHz SC-cut
4 x TWTMC-DRIXO-SF
8 x TWTMC-DBM-SF
4 x TWTMC-DRIXO-XFMR 5-12 MHz
8 x TWTMC-DBM-XFMR
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
-Raj1
1 x 22.5792 MHz SC-cut
1 x 24.5760 MHz SC-cut
1 x TWTMC-DRIXO-F 22.5792 MHz
1 x TWTMC-DRIXO-F 24.576 MHz
2 x TWTMC-STS-SX
-markw4
1 x 11.2896 MHz SC-cut
1 x 12.2880 MHz SC-cut
2 x 22.5792 MHz SC-cut
2 x 24.5760 MHz SC-cut
Plus some other stuff
-bisesik
2 x 11.2896 MHz SC-cut
2 x TWTMC-DRIXO-F 11.2896 MHz
2 x TWTMC-STS-SX
2 x TWRPS-UGL-F
-hifoli
1 x 6.1440 MHz SC-cut
1 x TWTMC-DRIXO-F 6.144 MHz
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
1 x TWRPS-LBS-P
1 x TWRPS-LBS-M-SF
-Sligolad
4 x TWTMC-STS-SX
-wyan
1 x 6mHz AT-cut
-M_Balou
1 x TWTMC-STS-SX
-Supersurfer
1x 22.5792 MHz SC-cut
1x 24.5760 MHz SC-cut
1x TWTMC-D
4x TWTMC-DRIXO-SF
4x TWTMC-DBM-SF
2x TWTMC-DRIXO-XFMR 5-12 MHz
2x TWTMC-DRIXO-XFMR 22-24 MHz
4x TWTMC-DBM-XFMR
2x TWTMC-STS-SX
2x TWTMC-STS-DX
Mobilux:
1 x TWTMC-STS-DX
1 x TWTMC-DIL
ilgavro:
1x 5.6448 MHz SC-cut
1x 6.1440 MHz SC-cut
1x 5.6448 MHz AT-cut
1x 6.2500 MHz AT-cut
1x TWTMC-DRIXO-SF
1x TWTMC-PXO-AIO-SF
1x TWTMC-PPG 22.5792 MHz
1x TWTMC-PPG 24.576 MHz
1x TWTMC-STS-SX
1x TWTMC-STS-DX
bryman79:
4 x TWTMC-DRIXO-SF
3 x TWRPS-UGL-SF
1 x TWTMC-PPG 22.5792 MHz
1 x TWTMC-PPG 24.576 MHz
1 x TWTMC-DBM-F 22.5792 MHz to 45.1584 MHz
1 x TWTMC-DBM-F 24.576 MHz to 49.152 MHz
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
thom:
1x 6.0000 MHz AT-cut
2 x TWTMC-DRIXO-SF
4 x TWTMC-DBM-SF
1 x TWTMC-PXO-AIO-SF
4 x TWTMC-DBM-XFMR
1 x TWTMC-PXO-AIO-XFMR
CV
Joined 2002
wlowes
1 x TWTMC-DRIXO-SF
1 x TWTMC-STS-DX
-G600:
1 x SC 5.6448 MHz
1 x SC 6.1440 MHz
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
-mars2:
2 x SC 11.2896 MHz
2 x SC 12.2880 MHz
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
-tbrowne:
4 x SC 5.6448 MHz
1 x SC 6.144 MHz
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-SF
1 x TWTMC-EXO-SF
4 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
-laserscrape:
1 x TWTMC-DRIXO-SF
1 x TWRPS-UGL-SF
-clsidxxl:
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-STS-SX
1 x TWRPS-UGL-F
-gabor80:
2 x TWTMC-DRIXO-SF
2 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
2 x TWTMC-DBM-XFMR
-crowlie
1 x SC 5.6448 MHz
3 x TWTMC-DRIXO-SF
3 x TWTMC-STS-SX
3 x TWTMC-DIL
-wealas
4 x TWTMC-DRIXO-SF
8 x TWTMC-DBM-SF
8 x TWTMC-DBM-XFMR
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
-Raj1
2 x TWTMC-STS-SX
-markw4
-bisesik
2 x TWTMC-STS-SX
2 x TWRPS-UGL-F
-hifoli
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
1 x TWRPS-LBS-P
1 x TWRPS-LBS-M-SF
-Sligolad
4 x TWTMC-STS-SX
-wyan
1 x 6mHz AT-cut
-M_Balou
1 x TWTMC-STS-SX
-Supersurfer
1x TWTMC-D
4x TWTMC-DRIXO-SF
4x TWTMC-DBM-SF
4x TWTMC-DBM-XFMR
2x TWTMC-STS-SX
2x TWTMC-STS-DX
Mobilux:
1 x TWTMC-STS-DX
1 x TWTMC-DIL
ilgavro:
1x TWTMC-DRIXO-SF
1x TWTMC-PXO-AIO-SF
1x TWTMC-STS-SX
1x TWTMC-STS-DX
bryman79:
4 x TWTMC-DRIXO-SF
3 x TWRPS-UGL-SF
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
thom:
2 x TWTMC-DRIXO-SF
4 x TWTMC-DBM-SF
4 x TWTMC-DBM-XFMR
CV:
4 x TWTMC-DRIXO-SF
4 x TWTMC-DBM-SF
2 x TWTMC-DRIXO-XFMR 22-24 MHz
4 x TWTMC-DBM-XFMR
2 X TWTMC-STS-SX
wlowes
1 x TWTMC-DRIXO-SF
1 x TWTMC-STS-DX
-G600:
1 x SC 5.6448 MHz
1 x SC 6.1440 MHz
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
-mars2:
2 x SC 11.2896 MHz
2 x SC 12.2880 MHz
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
-tbrowne:
4 x SC 5.6448 MHz
1 x SC 6.144 MHz
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-SF
1 x TWTMC-EXO-SF
4 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
-laserscrape:
1 x TWTMC-DRIXO-SF
1 x TWRPS-UGL-SF
-clsidxxl:
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-STS-SX
1 x TWRPS-UGL-F
-gabor80:
2 x TWTMC-DRIXO-SF
2 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
2 x TWTMC-DBM-XFMR
-crowlie
1 x SC 5.6448 MHz
3 x TWTMC-DRIXO-SF
3 x TWTMC-STS-SX
3 x TWTMC-DIL
-wealas
4 x TWTMC-DRIXO-SF
8 x TWTMC-DBM-SF
8 x TWTMC-DBM-XFMR
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
-Raj1
2 x TWTMC-STS-SX
-markw4
-bisesik
2 x TWTMC-STS-SX
2 x TWRPS-UGL-F
-hifoli
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
1 x TWRPS-LBS-P
1 x TWRPS-LBS-M-SF
-Sligolad
4 x TWTMC-STS-SX
-wyan
1 x 6mHz AT-cut
-M_Balou
1 x TWTMC-STS-SX
-Supersurfer
1x TWTMC-D
4x TWTMC-DRIXO-SF
4x TWTMC-DBM-SF
4x TWTMC-DBM-XFMR
2x TWTMC-STS-SX
2x TWTMC-STS-DX
Mobilux:
1 x TWTMC-STS-DX
1 x TWTMC-DIL
ilgavro:
1x TWTMC-DRIXO-SF
1x TWTMC-PXO-AIO-SF
1x TWTMC-STS-SX
1x TWTMC-STS-DX
bryman79:
4 x TWTMC-DRIXO-SF
3 x TWRPS-UGL-SF
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
thom:
2 x TWTMC-DRIXO-SF
4 x TWTMC-DBM-SF
4 x TWTMC-DBM-XFMR
CV:
4 x TWTMC-DRIXO-SF
4 x TWTMC-DBM-SF
4 x TWTMC-DBM-XFMR
2 X TWTMC-STS-SX
woodturner-fran
3 x 22.5792 MHz SC-cut
3 x 24.5760 MHz SC-cut
8 x TWTMC-D
wlowes
1 x TWTMC-DRIXO-SF
1 x TWTMC-STS-DX
-G600:
1 x SC 5.6448 MHz
1 x SC 6.1440 MHz
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
-mars2:
2 x SC 11.2896 MHz
2 x SC 12.2880 MHz
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
-tbrowne:
4 x SC 5.6448 MHz
1 x SC 6.144 MHz
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-SF
1 x TWTMC-EXO-SF
4 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
-laserscrape:
1 x TWTMC-DRIXO-SF
1 x TWRPS-UGL-SF
-clsidxxl:
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-STS-SX
1 x TWRPS-UGL-F
-gabor80:
2 x TWTMC-DRIXO-SF
2 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
2 x TWTMC-DBM-XFMR
-crowlie
1 x SC 5.6448 MHz
3 x TWTMC-DRIXO-SF
3 x TWTMC-STS-SX
3 x TWTMC-DIL
-wealas
4 x TWTMC-DRIXO-SF
8 x TWTMC-DBM-SF
8 x TWTMC-DBM-XFMR
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
-Raj1
2 x TWTMC-STS-SX
-markw4
-bisesik
2 x TWTMC-STS-SX
2 x TWRPS-UGL-F
-hifoli
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
1 x TWRPS-LBS-P
1 x TWRPS-LBS-M-SF
-Sligolad
4 x TWTMC-STS-SX
-wyan
1 x 6mHz AT-cut
-M_Balou
1 x TWTMC-STS-SX
-Supersurfer
1x TWTMC-D
4x TWTMC-DRIXO-SF
4x TWTMC-DBM-SF
4x TWTMC-DBM-XFMR
2x TWTMC-STS-SX
2x TWTMC-STS-DX
Mobilux:
1 x TWTMC-STS-DX
1 x TWTMC-DIL
ilgavro:
1x TWTMC-DRIXO-SF
1x TWTMC-PXO-AIO-SF
1x TWTMC-STS-SX
1x TWTMC-STS-DX
bryman79:
4 x TWTMC-DRIXO-SF
3 x TWRPS-UGL-SF
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
thom:
2 x TWTMC-DRIXO-SF
4 x TWTMC-DBM-SF
4 x TWTMC-DBM-XFMR
CV:
4 x TWTMC-DRIXO-SF
4 x TWTMC-DBM-SF
4 x TWTMC-DBM-XFMR
2 X TWTMC-STS-SX
woodturner-fran
8 x TWTMC-D
Tonerei
4 x TWTMC-D
wlowes
1 x TWTMC-DRIXO-SF
1 x TWTMC-STS-DX
-G600:
1 x SC 5.6448 MHz
1 x SC 6.1440 MHz
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
-mars2:
2 x SC 11.2896 MHz
2 x SC 12.2880 MHz
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
-tbrowne:
4 x SC 5.6448 MHz
1 x SC 6.144 MHz
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-SF
1 x TWTMC-EXO-SF
4 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
-laserscrape:
1 x TWTMC-DRIXO-SF
1 x TWRPS-UGL-SF
-clsidxxl:
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-STS-SX
1 x TWRPS-UGL-F
-gabor80:
2 x TWTMC-DRIXO-SF
2 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
2 x TWTMC-DBM-XFMR
-crowlie
1 x SC 5.6448 MHz
3 x TWTMC-DRIXO-SF
3 x TWTMC-STS-SX
3 x TWTMC-DIL
-wealas
4 x TWTMC-DRIXO-SF
8 x TWTMC-DBM-SF
8 x TWTMC-DBM-XFMR
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
-Raj1
2 x TWTMC-STS-SX
-markw4
-bisesik
2 x TWTMC-STS-SX
2 x TWRPS-UGL-F
-hifoli
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
1 x TWRPS-LBS-P
1 x TWRPS-LBS-M-SF
-Sligolad
4 x TWTMC-STS-SX
-wyan
1 x 6mHz AT-cut
-M_Balou
1 x TWTMC-STS-SX
-Supersurfer
1x TWTMC-D
4x TWTMC-DRIXO-SF
4x TWTMC-DBM-SF
4x TWTMC-DBM-XFMR
2x TWTMC-STS-SX
2x TWTMC-STS-DX
Mobilux:
1 x TWTMC-STS-DX
1 x TWTMC-DIL
ilgavro:
1x TWTMC-DRIXO-SF
1x TWTMC-PXO-AIO-SF
1x TWTMC-STS-SX
1x TWTMC-STS-DX
bryman79:
4 x TWTMC-DRIXO-SF
3 x TWRPS-UGL-SF
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
thom:
2 x TWTMC-DRIXO-SF
4 x TWTMC-DBM-SF
4 x TWTMC-DBM-XFMR
CV:
4 x TWTMC-DRIXO-SF
4 x TWTMC-DBM-SF
4 x TWTMC-DBM-XFMR
2 X TWTMC-STS-SX
woodturner-fran
8 x TWTMC-D
Tonerei
4 x TWTMC-D
Aihorn
1 X 5.6448 MHz SC-cut
1 X 24.5760 MHz SC-cut
2 X TWTMC-DRIXO-SF
1 X TWTMC-DRIXO-XFMR 5-12 MHz
1 X TWTMC-DRIXO-XFMR 22-24 MHz
1 X TWTMC-STS-SX
1 X TWTMC-STS-DX
wlowes
1 x TWTMC-DRIXO-SF
1 x TWTMC-STS-DX
-G600:
1 x SC 5.6448 MHz
1 x SC 6.1440 MHz
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
-mars2:
2 x SC 11.2896 MHz
2 x SC 12.2880 MHz
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
-tbrowne:
4 x SC 5.6448 MHz
1 x SC 6.144 MHz
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-SF
1 x TWTMC-EXO-SF
4 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
-laserscrape:
1 x TWTMC-DRIXO-SF
1 x TWRPS-UGL-SF
-clsidxxl:
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-STS-SX
1 x TWRPS-UGL-F
-gabor80:
2 x TWTMC-DRIXO-SF
2 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
2 x TWTMC-DBM-XFMR
-crowlie
1 x SC 5.6448 MHz
3 x TWTMC-DRIXO-SF
3 x TWTMC-STS-SX
3 x TWTMC-DIL
-wealas
4 x TWTMC-DRIXO-SF
8 x TWTMC-DBM-SF
8 x TWTMC-DBM-XFMR
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
-Raj1
2 x TWTMC-STS-SX
-markw4
-bisesik
2 x TWTMC-STS-SX
2 x TWRPS-UGL-F
-hifoli
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
1 x TWRPS-LBS-P
1 x TWRPS-LBS-M-SF
-Sligolad
4 x TWTMC-STS-SX
-wyan
1 x 6mHz AT-cut
-M_Balou
1 x TWTMC-STS-SX
-Supersurfer
1x TWTMC-D
4x TWTMC-DRIXO-SF
4x TWTMC-DBM-SF
4x TWTMC-DBM-XFMR
2x TWTMC-STS-SX
2x TWTMC-STS-DX
Mobilux:
1 x TWTMC-STS-DX
1 x TWTMC-DIL
ilgavro:
1x TWTMC-DRIXO-SF
1x TWTMC-PXO-AIO-SF
1x TWTMC-STS-SX
1x TWTMC-STS-DX
bryman79:
4 x TWTMC-DRIXO-SF
3 x TWRPS-UGL-SF
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
thom:
2 x TWTMC-DRIXO-SF
4 x TWTMC-DBM-SF
4 x TWTMC-DBM-XFMR
CV:
4 x TWTMC-DRIXO-SF
4 x TWTMC-DBM-SF
4 x TWTMC-DBM-XFMR
2 X TWTMC-STS-SX
woodturner-fran
8 x TWTMC-D
Tonerei
4 x TWTMC-D
Aihorn
2 X TWTMC-DRIXO-SF
1 X TWTMC-STS-SX
1 X TWTMC-STS-DX
sterlingmck
1 x TWTMC-STS-SX
pinnocchio
1x TWRPS-LBS-P
1x TWRPS-LBS-M-SF
1x TWRPS-LBS-D-SF
1x TWTMC-DRIXO-F 5.6448 MHz
1x TWTMC-DRIXO-F 6.144 MHz
Joined 2007
wlowes
1 x TWTMC-DRIXO-SF
1 x TWTMC-STS-DX
-G600:
1 x SC 5.6448 MHz
1 x SC 6.1440 MHz
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
-mars2:
2 x SC 11.2896 MHz
2 x SC 12.2880 MHz
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
-tbrowne:
4 x SC 5.6448 MHz
1 x SC 6.144 MHz
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-SF
1 x TWTMC-EXO-SF
4 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
-laserscrape:
1 x TWTMC-DRIXO-SF
1 x TWRPS-UGL-SF
-clsidxxl:
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-STS-SX
1 x TWRPS-UGL-F
-gabor80:
2 x TWTMC-DRIXO-SF
2 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
2 x TWTMC-DBM-XFMR
-crowlie
1 x SC 5.6448 MHz
3 x TWTMC-DRIXO-SF
3 x TWTMC-STS-SX
3 x TWTMC-DIL
-wealas
4 x TWTMC-DRIXO-SF
8 x TWTMC-DBM-SF
8 x TWTMC-DBM-XFMR
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
-Raj1
2 x TWTMC-STS-SX
-markw4
-bisesik
2 x TWTMC-STS-SX
2 x TWRPS-UGL-F
-hifoli
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
1 x TWRPS-LBS-P
1 x TWRPS-LBS-M-SF
-Sligolad
4 x TWTMC-STS-SX
-wyan
1 x 6mHz AT-cut
-M_Balou
1 x TWTMC-STS-SX
-Supersurfer
1x TWTMC-D
4x TWTMC-DRIXO-SF
4x TWTMC-DBM-SF
4x TWTMC-DBM-XFMR
2x TWTMC-STS-SX
2x TWTMC-STS-DX
Mobilux:
1 x TWTMC-STS-DX
1 x TWTMC-DIL
ilgavro:
1x TWTMC-DRIXO-SF
1x TWTMC-PXO-AIO-SF
1x TWTMC-STS-SX
1x TWTMC-STS-DX
bryman79:
4 x TWTMC-DRIXO-SF
3 x TWRPS-UGL-SF
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
thom:
2 x TWTMC-DRIXO-SF
4 x TWTMC-DBM-SF
4 x TWTMC-DBM-XFMR
CV:
4 x TWTMC-DRIXO-SF
4 x TWTMC-DBM-SF
4 x TWTMC-DBM-XFMR
2 X TWTMC-STS-SX
woodturner-fran
8 x TWTMC-D
Tonerei
4 x TWTMC-D
Aihorn
2 X TWTMC-DRIXO-SF
1 X TWTMC-STS-SX
1 X TWTMC-STS-DX
sterlingmck
1 x TWTMC-STS-SX
pinnocchio
1x TWRPS-LBS-P
1x TWRPS-LBS-M-SF
1x TWRPS-LBS-D-SF
ernesternest
TWTMC-PXO-AIO 5,6448 MHZ
TWRPS-UGL
TWTMC-STS-SX
wlowes
1 x TWTMC-DRIXO-SF
1 x TWTMC-STS-DX
G600:
1 x SC 5.6448 MHz
1 x SC 6.1440 MHz
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
1x TWRPS-pp
-mars2:
2 x SC 11.2896 MHz
2 x SC 12.2880 MHz
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
-tbrowne:
4 x SC 5.6448 MHz
1 x SC 6.144 MHz
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-SF
1 x TWTMC-EXO-SF
4 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
-laserscrape:
1 x TWTMC-DRIXO-SF
1 x TWRPS-UGL-SF
-clsidxxl:
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-STS-SX
1 x TWRPS-UGL-F
-gabor80:
2 x TWTMC-DRIXO-SF
2 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
2 x TWTMC-DBM-XFMR
-crowlie
1 x SC 5.6448 MHz
3 x TWTMC-DRIXO-SF
3 x TWTMC-STS-SX
3 x TWTMC-DIL
-wealas
4 x TWTMC-DRIXO-SF
8 x TWTMC-DBM-SF
8 x TWTMC-DBM-XFMR
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
-Raj1
2 x TWTMC-STS-SX
-markw4
-bisesik
2 x TWTMC-STS-SX
2 x TWRPS-UGL-F
-hifoli
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
1 x TWRPS-LBS-P
1 x TWRPS-LBS-M-SF
-Sligolad
4 x TWTMC-STS-SX
-wyan
1 x 6mHz AT-cut
-M_Balou
1 x TWTMC-STS-SX
-Supersurfer
1x TWTMC-D
4x TWTMC-DRIXO-SF
4x TWTMC-DBM-SF
4x TWTMC-DBM-XFMR
2x TWTMC-STS-SX
2x TWTMC-STS-DX
Mobilux:
1 x TWTMC-STS-DX
1 x TWTMC-DIL
ilgavro:
1x TWTMC-DRIXO-SF
1x TWTMC-PXO-AIO-SF
1x TWTMC-STS-SX
1x TWTMC-STS-DX
bryman79:
4 x TWTMC-DRIXO-SF
3 x TWRPS-UGL-SF
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
thom:
2 x TWTMC-DRIXO-SF
4 x TWTMC-DBM-SF
4 x TWTMC-DBM-XFMR
CV:
4 x TWTMC-DRIXO-SF
4 x TWTMC-DBM-SF
4 x TWTMC-DBM-XFMR
2 X TWTMC-STS-SX
woodturner-fran
8 x TWTMC-D
Tonerei
4 x TWTMC-D
Aihorn
2 X TWTMC-DRIXO-SF
1 X TWTMC-STS-SX
1 X TWTMC-STS-DX
sterlingmck
1 x TWTMC-STS-SX
pinnocchio
1x TWRPS-LBS-P
1x TWRPS-LBS-M-SF
1x TWRPS-LBS-D-SF
ernesternest
TWRPS-UGL
TWTMC-STS-SX
Can someone please check my order?
I am about to place my order but not 100% it is right.
It will be for Ians FiFoPi and I would like this option in the PDF Andrea created.
I do not need a PSU....
1 x TWTMC-DRIXO-SF 5.6448 MHz
1 x TWTMC-DRIXO-SF 6.144 MHz
1 x TWTMC-DBM-SF 5.6448 to 11.2896 MHz
1 x TWTMC-DBM-SF 11.2896 to 22.5792 MHz
1 x TWTMC-DBM-SF 6.144 to 12.288 MHz
1 x TWTMC-DBM-SF 12.288 to 24.576 MHz
1 x TWTMC-STS-SX + 1 x TWTMC-STS-DX
do I also need the below for the above boards as ordering semi-finished, I am sure the below is not correct?
4x TWTMC-DBM-XFMR
thanks in advance for the confirmation
correct
4x TWTMC-DBM-XFMR
correct for semi-finished boards
You don't need 2x TWTMC-DRIXO-XFMR 22-24 MHz, you get 2 oscillators so you need the transformers for the base oscillators only (5.6448 and 6.144 MHz)
wlowes
1 x TWTMC-DRIXO-SF
1 x TWTMC-STS-DX
G600:
1 x SC 5.6448 MHz
1 x SC 6.1440 MHz
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
1x TWRPS-pp
-mars2:
2 x SC 11.2896 MHz
2 x SC 12.2880 MHz
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
-tbrowne:
4 x SC 5.6448 MHz
1 x SC 6.144 MHz
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-SF
1 x TWTMC-EXO-SF
4 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
-laserscrape:
1 x TWTMC-DRIXO-SF
1 x TWRPS-UGL-SF
-clsidxxl:
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-STS-SX
1 x TWRPS-UGL-F
-gabor80:
2 x TWTMC-DRIXO-SF
2 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
2 x TWTMC-DBM-XFMR
-crowlie
1 x SC 5.6448 MHz
3 x TWTMC-DRIXO-SF
3 x TWTMC-STS-SX
3 x TWTMC-DIL
-wealas
4 x TWTMC-DRIXO-SF
8 x TWTMC-DBM-SF
8 x TWTMC-DBM-XFMR
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
-Raj1
2 x TWTMC-STS-SX
-markw4
-bisesik
2 x TWTMC-STS-SX
2 x TWRPS-UGL-F
-hifoli
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
1 x TWRPS-LBS-P
1 x TWRPS-LBS-M-SF
-Sligolad
4 x TWTMC-STS-SX
-wyan
1 x 6mHz AT-cut
-M_Balou
1 x TWTMC-STS-SX
-Supersurfer
1x TWTMC-D
4x TWTMC-DRIXO-SF
4x TWTMC-DBM-SF
4x TWTMC-DBM-XFMR
2x TWTMC-STS-SX
2x TWTMC-STS-DX
Mobilux:
1 x TWTMC-STS-DX
1 x TWTMC-DIL
ilgavro:
1x TWTMC-DRIXO-SF
1x TWTMC-PXO-AIO-SF
1x TWTMC-STS-SX
1x TWTMC-STS-DX
bryman79:
4 x TWTMC-DRIXO-SF
3 x TWRPS-UGL-SF
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
thom:
2 x TWTMC-DRIXO-SF
4 x TWTMC-DBM-SF
4 x TWTMC-DBM-XFMR
CV:
4 x TWTMC-DRIXO-SF
4 x TWTMC-DBM-SF
4 x TWTMC-DBM-XFMR
2 X TWTMC-STS-SX
woodturner-fran
8 x TWTMC-D
Tonerei
4 x TWTMC-D
Aihorn
2 X TWTMC-DRIXO-SF
1 X TWTMC-STS-SX
1 X TWTMC-STS-DX
sterlingmck
1 x TWTMC-STS-SX
pinnocchio
1x TWRPS-LBS-P
1x TWRPS-LBS-M-SF
1x TWRPS-LBS-D-SF
ernesternest
TWRPS-UGL
TWTMC-STS-SX
SimonJ
4x TWTMC-DBM-XFMR
wlowes
1 x TWTMC-DRIXO-SF
1 x TWTMC-STS-DX
G600:
1 x SC 5.6448 MHz
1 x SC 6.1440 MHz
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
1x TWRPS-pp
-mars2:
2 x SC 11.2896 MHz
2 x SC 12.2880 MHz
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
-tbrowne:
4 x SC 5.6448 MHz
1 x SC 6.144 MHz
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-SF
1 x TWTMC-EXO-SF
4 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
-laserscrape:
1 x TWTMC-DRIXO-SF
1 x TWRPS-UGL-SF
-clsidxxl:
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-STS-SX
1 x TWRPS-UGL-F
-gabor80:
2 x TWTMC-DRIXO-SF
2 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
2 x TWTMC-DBM-XFMR
-crowlie
1 x SC 5.6448 MHz
3 x TWTMC-DRIXO-SF
3 x TWTMC-STS-SX
3 x TWTMC-DIL
-wealas
4 x TWTMC-DRIXO-SF
8 x TWTMC-DBM-SF
8 x TWTMC-DBM-XFMR
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
-Raj1
2 x TWTMC-STS-SX
-markw4
-bisesik
2 x TWTMC-STS-SX
2 x TWRPS-UGL-F
-hifoli
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
1 x TWRPS-LBS-P
1 x TWRPS-LBS-M-SF
-Sligolad
4 x TWTMC-STS-SX
-wyan
1 x 6mHz AT-cut
-M_Balou
1 x TWTMC-STS-SX
-Supersurfer
1x TWTMC-D
4x TWTMC-DRIXO-SF
4x TWTMC-DBM-SF
4x TWTMC-DBM-XFMR
2x TWTMC-STS-SX
2x TWTMC-STS-DX
Mobilux:
1 x TWTMC-STS-DX
1 x TWTMC-DIL
ilgavro:
1x TWTMC-DRIXO-SF
1x TWTMC-PXO-AIO-SF
1x TWTMC-STS-SX
1x TWTMC-STS-DX
bryman79:
4 x TWTMC-DRIXO-SF
3 x TWRPS-UGL-SF
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
thom:
2 x TWTMC-DRIXO-SF
4 x TWTMC-DBM-SF
4 x TWTMC-DBM-XFMR
CV:
4 x TWTMC-DRIXO-SF
4 x TWTMC-DBM-SF
4 x TWTMC-DBM-XFMR
2 X TWTMC-STS-SX
woodturner-fran
8 x TWTMC-D
Tonerei
4 x TWTMC-D
Aihorn
2 X TWTMC-DRIXO-SF
1 X TWTMC-STS-SX
1 X TWTMC-STS-DX
sterlingmck
1 x TWTMC-STS-SX
pinnocchio
1x TWRPS-LBS-P
1x TWRPS-LBS-M-SF
1x TWRPS-LBS-D-SF
ernesternest
TWRPS-UGL
TWTMC-STS-SX
SimonJ
4x TWTMC-DBM-XFMR
Joined 2003
DDDAC
5.6448 MHz SC-cut
TWTMC-STS-SX
TWTMC-STS-DX
wlowes
1 x TWTMC-DRIXO-SF
1 x TWTMC-STS-DX
G600:
1 x SC 5.6448 MHz
1 x SC 6.1440 MHz
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
1x TWRPS-pp
-mars2:
2 x SC 11.2896 MHz
2 x SC 12.2880 MHz
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
-tbrowne:
4 x SC 5.6448 MHz
1 x SC 6.144 MHz
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-SF
1 x TWTMC-EXO-SF
4 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
-laserscrape:
1 x TWTMC-DRIXO-SF
1 x TWRPS-UGL-SF
-clsidxxl:
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-STS-SX
1 x TWRPS-UGL-F
-gabor80:
2 x TWTMC-DRIXO-SF
2 x TWTMC-DBM-SF
2 x TWTMC-STS-SX
2 x TWTMC-DBM-XFMR
-crowlie
1 x SC 5.6448 MHz
3 x TWTMC-DRIXO-SF
3 x TWTMC-STS-SX
3 x TWTMC-DIL
-wealas
4 x TWTMC-DRIXO-SF
8 x TWTMC-DBM-SF
8 x TWTMC-DBM-XFMR
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
-Raj1
2 x TWTMC-STS-SX
-markw4
-bisesik
2 x TWTMC-STS-SX
2 x TWRPS-UGL-F
-hifoli
1 x TWTMC-STS-SX
1 x TWTMC-STS-DX
1 x TWRPS-LBS-P
1 x TWRPS-LBS-M-SF
-Sligolad
4 x TWTMC-STS-SX
-wyan
1 x 6mHz AT-cut
-M_Balou
1 x TWTMC-STS-SX
-Supersurfer
1x TWTMC-D
4x TWTMC-DRIXO-SF
4x TWTMC-DBM-SF
4x TWTMC-DBM-XFMR
2x TWTMC-STS-SX
2x TWTMC-STS-DX
Mobilux:
1 x TWTMC-STS-DX
1 x TWTMC-DIL
ilgavro:
1x TWTMC-DRIXO-SF
1x TWTMC-PXO-AIO-SF
1x TWTMC-STS-SX
1x TWTMC-STS-DX
bryman79:
4 x TWTMC-DRIXO-SF
3 x TWRPS-UGL-SF
2 x TWTMC-STS-SX
2 x TWTMC-STS-DX
thom:
2 x TWTMC-DRIXO-SF
4 x TWTMC-DBM-SF
4 x TWTMC-DBM-XFMR
CV:
4 x TWTMC-DRIXO-SF
4 x TWTMC-DBM-SF
4 x TWTMC-DBM-XFMR
2 X TWTMC-STS-SX
woodturner-fran
8 x TWTMC-D
Tonerei
4 x TWTMC-D
Aihorn
2 X TWTMC-DRIXO-SF
1 X TWTMC-STS-SX
1 X TWTMC-STS-DX
sterlingmck
1 x TWTMC-STS-SX
pinnocchio
1x TWRPS-LBS-P
1x TWRPS-LBS-M-SF
1x TWRPS-LBS-D-SF
ernesternest
TWRPS-UGL
TWTMC-STS-SX
SimonJ
4x TWTMC-DBM-XFMR
