Group Buys Members group buys
Maya R2R Advanced Volume controller
Old 15th April 2019, 07:09 AM   #431
tvicol is offline tvicol  Europe
tvicol's Avatar
Maya R2R Advanced Volume controller Maya R2R Advanced Volume controller
SE -> BAL schematic
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz
Tibi
Old 24th April 2019, 09:29 PM   #432
Dudeisms is offline Dudeisms  United States
Need some help. I have a second relay board to make the Maya balanced, but I don't understand how to connect it to the original maya that I have. Please help.
Also what size standoffs do I need, and what other stuff will I need to connect this 2nd board?
Old 25th April 2019, 06:25 AM   #433
tvicol's Avatar
Hope attached pictures are self explanatory.
Tibi
Old 26th April 2019, 12:42 PM   #434
PieterPiet is offline PieterPiet  Netherlands
Hi Tibi, can I ask you 3 small questions?
1) is a 6 Vac 15VA transformer sufficient to power your latest balanced Maya? Or do I need at least 9V 20VA?
2) I am looking to change your encoder for another one (see below) with an integrated NO switch (to use for the menu button). But I see two capacitors c20 and c21 on your encoder PCB, 47 nF between common and the two channels. I need new caps with a new encoder-with-switch, what type of 47 nF capacitors do I need?
3) My guess is that this encoder-with-switch suits Maya, am I right? Bourns 652-PEC11R4225KS0024
PEC11R-4225K-S0024 Bourns | Mouser Nederland
Old 27th April 2019, 10:32 AM   #435
tvicol's Avatar
Hi Pieter,
1) maya regulator 7805 need 3V drop for proper regulation. At 6 Vac you get ~7,2Vdc after rectification which is quite low.
I suggest you to use 9Vac or replace 7805 with a LDO regulator.
2) This is a direct replacement. No capacitors needed.
PEC16-4220F-S002
PEC16-4220F-S0024 BOURNS - Codor: incremental | TME - Componente electronice
3) No.
Tibi
Old 27th April 2019, 12:06 PM   #436
Tibi, Thank you for the answers !
Old 12th May 2019, 03:53 PM   #437
tjencks is offline tjencks  United States
Tibi and others, since Vicol Audio page is no longer available can someone send me or provide me access to the docs for Maya Controller and VolCB that was on Vicol audio site.
I'm not sure if I have the latest firmware either but I suspect I'm fine there as I got my unit August 2018.
Just need the docs to ensure I understand everything completely. Am looking to power the Maya main unit from my own DC supply ... need suggestion on best place to connect this supply after the 7805 regulator.
Old 12th May 2019, 04:13 PM   #438
tvicol's Avatar
Please mail me for documentation.
Tibi
Old 23rd June 2019, 10:52 AM   #439
havefun is offline havefun
Why is the website not working?
Old 23rd June 2019, 01:31 PM   #440
danzup is offline danzup  Romania
danzup's Avatar
Vicol Audio have close business. For archive please see :
danzup personal site
There are not better tube than 6P3S and 6N2P for my ears !
Maya R2R Advanced Volume controllerHide this!Advertise here!
Interest check on Vicol Audio Maya R2R Volume controller aradan Group Buys 222 12th November 2018 09:55 AM
R2R Shunt Volume with 3 selectable sources quanghao Quanghao Audio Design 13 2nd August 2016 04:30 PM
Vicol Audio R2R Volume controller Builds aradan Analog Line Level 13 18th April 2016 02:06 PM
R2R/Shunt volume controller; Quasar amplifier; Silver-Gold interconnect tvicol Vendor's Bazaar 3 27th June 2011 06:40 AM
Samsung 1602VFD For CDROM Controller & Remote Volume Controller slowgay Swap Meet 2 22nd November 2008 02:44 PM
Copyright ©1999-2019 diyAudio
