I am hoping you can help me with choosing the right capacitors for this project.
Will go with :
C1 : polystyrene ?
C2, C3, C9, C10, C11, C13 : Polarized Aluminum electrolytic capacitor (ie: nichicon muse kz, fg, Elna Silmic II, Panasonic FC) ? Audio oriented or "classic" ?
C4, C6, C5, C7 (RIAA): MKP/polypropylene ? Better ?
C8 : MKP/polypropylene (ie : Mundorf Mcap MKP) ?
C12, C14 : Basic Polarized Aluminum electrolytic capacitor
Am I good ?
Will go with :
C1 : polystyrene ?
Am I good ?
can you give me an address for ship the pcb ?
thank
received the board. thanks a lot !
thanksreceived the board. thanks a lot !
4pcs available.
I'm still trying to clarify the board with the schematic. I count (3) 4.7uf caps on the schematic per channel. The red board shows (5) 4.7uf/ch?? Specifically what value cap goes in the position right next to the labeling "7815"? Also the transistors labeling is not that clear. Can you clarify please. Do you have an updated schematic that matches the board?
i update the boardI'm still trying to clarify the board with the schematic. I count (3) 4.7uf caps on the schematic per channel. The red board shows (5) 4.7uf/ch?? Specifically what value cap goes in the position right next to the labeling "7815"? Also the transistors labeling is not that clear. Can you clarify please. Do you have an updated schematic that matches the board?
Anybody have a BOM with part numbers from Mouser or digikey?
Do you want mine ?
Here is my MOUSER order:
Transistor :
BC550CTA
BC560CTA
Resistors :
MBB02070C4701FCT00
Caps :
c1=4,7pf
Replaced by 330pf to match with my cartridge
FKP2D003301D00HF00
c2,c3,c9,c10,c11,c13=4,7uF 25v.
UFG1H4R7MDM
c4,c6=3,3nF
FKP2D013301G00HSSD
c5,c7=10nF
FKP2C021001G00HSSD
c8=470nF
didn’t fit well, but wanted to try Nichicon MKP
QXP2E474KRPT
c12,c14=1uF
UFG1H010MDM1TD
Not populated for the moment.
Maybe this weekend if time allows.
Transistor :
BC550CTA
BC560CTA
Resistors :
MBB02070C4701FCT00
Caps :
c1=4,7pf
FKP2D003301D00HF00
UFG1H4R7MDM
c4,c6=3,3nF
FKP2D013301G00HSSD
c5,c7=10nF
FKP2C021001G00HSSD
c8=470nF
QXP2E474KRPT
c12,c14=1uF
UFG1H010MDM1TD
Very happy with the result ! Thank you Scafas for the pcb.Congratulations Mr. Scafus on an excellent sounding Pre! Just breaking in and sounding very good so far.
@Freecrowder : What value did you use for C1 and R1 ?
thanks , but i'm not scafus.....scafasCongratulations Mr. Scafus on an excellent sounding Pre! Just breaking in and sounding very good so far.
so i'm very happy you like it..
tks
- Group Buys
- supa phono preamplifier pcb
