Group Buys Members group buys
Linear regulator PCB (LM317, LT1085, LM338, LT1083)
Thread Tools
Old 7th May 2015, 12:56 AM   #71
johngalt47 is offline johngalt47  United States
RIP
Originally Posted by mravlca View Post
Hi John,
you can't use LM337. This PCB only accepts positive regulators. If you look few posts up you can see how to connect two of these PCBs to get syxmmetrical power supply.
Best Regards,
Aleš
If I do it this way, do I use the same type device in both boards (i.e., LM317)?
Any technology sufficiently advanced is indistinguishable from magic
Old 11th May 2015, 09:16 AM   #72
mravlca is offline mravlca  Slovenia
mravlca's Avatar
Originally Posted by Christensen View Post
Aleš -I need 3.3V out. Do you have a proposal for components? and do you sell components?
use usual components, but use only one red LED instead of two, if you still won't be able to set Vout to 3.3V, try using LED with small forward voltage.
I do not provide components for this PCB.
Originally Posted by djonesii View Post
On your e-bay site, it says the boards will take DC as input. Would this be an option to use a SMPS to run a gainclone?
Yes, it can be an option. You would improve ripple rejection from SMPS and normally you would have better voltage regulation (depends on what kind of SMPS you are using). You should disregard rectifying diodes and you shouldn't use so big filtering capacitor. 2200uF-3300uF value should be sufficient.
Yes, you use LM317 on both boards, but as mentioned before you need to use transformer with dual voltage output and not center tapped one.
Best Regards,
Aleš
Old 26th May 2015, 05:10 PM   #73
aradan is offline aradan  Singapore
Hi Ales,
Thank you for the great boards. I have received mine a while ago and building a 12v regulator now.
I have a question, based on the description on ebay there is a C2 SMD component which is required, although I am not able to find the place for it on the board. It looks like the PCB layout on ebay page and the one I have is slightly different.
I have C20, C4
The pcb on ebay has
LOW Noise Power Supply PCB FOR LT1083 LT1084 LT1085 LM317 LM338 1pcs TPA3116 | eBay
C1: 10000uF 35V ok, looks like it is called C20 on my board
C2: 100nF 50V 1206 SMD - where should this one be placed ?
C3: 10uF 50V 1206 SMD (optional component, but will improve ripple rejection) - where should this one be placed ?
C4: 100uF 35V - is OK, still have it
Thanks for your reply looking forward to finish the board soon !
Old 26th May 2015, 09:39 PM   #74
mravlca's Avatar
Originally Posted by aradan View Post
Hi Ales,
I have C20, C4
The pcb on ebay has
Hi aradan,
some of these PCBs had silkscreen error, but nothing wrong with PCB itself.
C20 = C1
C2 should be placed under C1, on your PCB under C20.
C3 capacitor is on the bottom side of the PCB, between R2 trimmer and diode D6.
Best Regards,
Aleš
Old 26th June 2015, 12:51 PM   #75
mravlca's Avatar
Hey guys,
these PCB are back in stock and available. Black color only.
Best Regards,
Aleš
Old 4th August 2015, 03:07 AM   #76
acg is offline acg  Australia
Hi ales,
Boards have arrived. All looks good. Thanks for your help.
Anthony
Old 22nd September 2015, 03:18 PM   #77
mravlca's Avatar
Default LOWEST PRICE EVER!
You can now buy PCBs directly from dirtypcbs.
CLICK HERE TO BUY PCBS
What is this?
This is a universal power supply for regulators such as LM317, LM338, LM1084, LM1085, LT1086, LT1085, LT1084, LT1083 and other that have same pinout and their output voltage is configured same way.
Old 9th November 2015, 08:55 PM   #78
mcandmar is offline mcandmar  Ireland
mcandmar's Avatar
Sweet. I used one of your earlier versions in a recent build and it worked great, just found this searching for more
Cheers!
Old 10th November 2015, 02:58 AM   #79
marcus1 is offline marcus1
Just found this - thanks mravica.
I can never get the right parts when ordering - anyone do an order from Mouser or Digikey that details the correct part numbers?
What is this?
Old 11th November 2015, 07:02 AM   #80
euforia is offline euforia  Sweden
You mention in your first post that you can use this as a preregulator, would it be possible to connect two of these board together to get even better ripple rejection?
I looked at the datasheet for LT1084 and could not find any suggestions for a dual setup for a tracking preregulating circiut as compared to datasheet for LM338 which has this pointed out, the regulators are not quite placed in series but rather in a parallel way and thus helping each-other.
Do you have any thoughts on this?
I found your PCB today and I really like the small form factor, my goal is to build a clean enough PSU for a MiniDSP 12v 1,5A and wonder if this might do the job? I have read about newer and more exotic regulator circuits using SMD mounted IC's but they all are limited to max 1A which isn't enough in this case.
Linear regulator PCB (LM317, LT1085, LM338, LT1083)Hide this!Advertise here!
Thread Tools
Linear regulator PCB plus regulators mravlca Swap Meet 60 17th March 2014 07:55 PM
Suggestions on PCB: LM317 As Walwart Regulator (1st Eagle PCB) tommy_o Power Supplies 10 14th July 2011 03:05 PM
LT1083/84/85 linear regulator family: what's the output voltage range? jarthel Parts 6 26th July 2007 02:53 PM
Linear Tech LT1085/84/83CK TO-3 Package kevinkr Parts 2 22nd March 2007 03:18 AM
The LT1085 voltage regulator Ryssen Parts 6 30th January 2004 10:31 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
