Group Buys Members group buys
Ian asynchronous I2S and S/PDIF FIFO KIT group buy
Old 22nd April 2019, 06:44 AM   #3441
prohvesor is offline prohvesor  Ukraine
Who else waiting for lifepo4 MKII ? When it will be available? I’m waiting already 5 weeks after payment!
Old 22nd April 2019, 11:35 PM   #3442
iancanada is online now iancanada  Canada
iancanada's Avatar
Default LifePO4 mkII arrived
Good news, LifePO4 mkII arrived today. Busy in testing just to make sure everything is good.
All orders on hold will be shipped within this week. Please watch your account for shipping update.
Ian
Old 23rd April 2019, 01:03 AM   #3443
acg is offline acg  Australia
Woo hoo!
Old 24th April 2019, 05:10 AM   #3444
iancanada's Avatar
LifePO4 mkII power supplies are available now.
They can use both 26650 battery cells with tabs and standard battery cases. Internal safety features have also been improved. So, over all it will be much easier and safer to assemble. PCB will be a little bit wider to fit the battery holders. But all mounting holes keep no change.
I'm sorry for keeping you waiting. I thank you for your patience. All orders on hold will be shipped within this week. Shipping information will be updated soon.
LifePO4mkII
by Ian, on Flickr
Ian
Old 24th April 2019, 07:28 PM   #3445
iancanada's Avatar
LifePO4 Pure mkII with battery holders and battery cells(no tabs).
LifePO4mkII2
by Ian, on Flickr
Ian
Old 24th April 2019, 07:52 PM   #3446
NicMac is offline NicMac  Italy
NicMac's Avatar
Default ESS controller questions
I have read the manuals, but still have a few questions.....:
Q1: Will the controller work when mounted on the DAC (i.e. "normal mode") GPIO even if the DAC module is not mounted on the RPi/Isolater modules?
Using the DAC module with a SPDIF input for example.
Q2: What PSU rail feed the ESS controller when mounted in the "normal model" and in the "isolated mode"? RPi, isolator or DAC?
Q3: Why is the "isolated mode" not the preferred (i.e. normal) mode?
Thanks!
Old 25th April 2019, 01:15 AM   #3447
Greg Stewart is offline Greg Stewart  United States
NicMac,
Sorry these answers are not clear from the manual. I'll take a look at that.
A1: The ESS Controller just by itself should work OK when just connected to a DAC board which is not connected to an RPi. The controller connects to the DAC board directly via the I2C pins and requires no driver on an RPi to do so, so no RPi should work just fine. I only hedge because I have tried it myself yet.
A2: When you connect the the ESS Controller on the non-isolated GPIO header of an IsolatorPi or FiFoPi, the power that is being fed to the RPi (or that header's 5V pins) powers the ESS Controller. When you connect it on the isolated GPIO header side of either, the power being fed to that side (IsolatorPi or FiFoPi output side) is fed to the ESS Controller.
A3: The isolated mode is the preferred mode. In that mode, the noise on the grounds on the input side of the isolators is not directly connected to the output side and it has a lower impact on the output side (IMHO, not NO impact, but that is up for debate). In none-isolated mode (what you are calling 'normal' mode), the grounds are common between the ESS Controller, the IsolatorPi or FiFoPi output, and your I2S source (if used). Then that noise can directly affect the output side and the DAC operation.
Again, I will check the manual to confirm that it clearly states that. Are you looking at the version of the manual that has both Ian and I as the authors?
I hope this all helps!
Greg in Mississippi
Everything matters!
Old 26th April 2019, 12:05 AM   #3448
iancanada's Avatar
Please do always include your invoice number if you have any question to ask or inquire. That will save me a lot of time to access your files.
Thanks.
Ian
Old 26th April 2019, 10:14 AM   #3449
chi0001 is offline chi0001  Hong Kong
Originally Posted by chi0001 View Post
i only tried se output, i try to cut pin 5 tonight and tell you the result.
tested, only connected 4 & 6, the result is same.
Old 26th April 2019, 01:38 PM   #3450
jacklee is offline jacklee  Hong Kong
Sorry to hear that. I don't have other ideas except if you have a scope you can check the signal levels at the input of the trans to see if that's normal.
Ian asynchronous I2S and S/PDIF FIFO KIT group buyHide this!Advertise here!
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4943 Today 12:51 PM
High Performance WM8741 Super Mini DAC with I2S Data Switching PCB - Group Buy heartwinter Group Buys 26 19th January 2012 12:12 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
What speakers are you going to use with your gainclone group buy kit AJ Bertelson Multi-Way 6 2nd March 2004 07:01 PM
Copyright ©1999-2019 diyAudio
