Group Buys Members group buys
Ian asynchronous I2S and S/PDIF FIFO KIT group buy
Old 14th April 2019, 01:43 PM   #3421
iancanada is offline iancanada  Canada
iancanada's Avatar
Originally Posted by Supersurfer View Post
Hi Ian,
Is it possible to modify the non isolated power supply on the battery board so it is always on?
This would be very helpfull for running distributions like Moode/volumio without the risk that the power supply is stopped on low battery and corrupting the sd card.
Hi Supersurfer,
It is possible,
Hardware solution would be easier. Software solution also good be need more time.
Please let me know.
Have a good weekend.
Ian
Old 14th April 2019, 01:45 PM   #3422
iancanada's Avatar
Originally Posted by paoloilpizzo View Post
an easter gift
I'm waiting with trepidation
Of course
Ian
Old 15th April 2019, 01:21 AM   #3423
ofswitched is offline ofswitched  Taiwan
Originally Posted by Deenoo View Post
Hi Ian,
What is the difference between LifePo4 and LifePo4 mkII?
Thx! D'
I hope that MKII can include a short circuit protection, overheat detection and other common BMS functions to make the LifePo4 power supply safer and more reliable. It is also best to allow the user to turn off the automatic charging function and allow manual charging.
It is better to be able to display the status of each battery. If a battery is found to be abnormal, it should be automatically turned off to avoid damage to other batteries.
In short, the sound quality is very important, but safety is more important, especially the LifePo4 battery is purchased by the user, the battery quality and characteristics are not the same, so the LifePo4 power supply must consider more unpredictable conditions.
Old 15th April 2019, 05:14 PM   #3424
Supersurfer is offline Supersurfer  Netherlands
Originally Posted by iancanada View Post
Hi Supersurfer,
It is possible,
Please let me know.
Ian
Thanks.
What would the hardware solution be? Can you share your idea or schematic?
Old 15th April 2019, 05:45 PM   #3425
Greg Stewart is offline Greg Stewart  United States
@iancanada & @supersurfer,
I have some thoughts on the 'always-on' state for the LiFePO4 supply, but think it is better to take them over to the main thread on this product here:
Develop ultra capacitor power supply and LiFePO4 battery power supply
That way we can keep as much of the IP on the unit in one place as possible.
Sound good?
Greg in Mississippi
Everything matters!
Old 17th April 2019, 06:08 PM   #3426
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
Hi Ian,
I've sent you some emails regarding a feature that I would love to see on your DAC, unfortunately, I don't know if this email is answered by you or someone that helps you with the group buy. So I will ask my question here if you don't mind.
I've been using Tidal High Res along with Roon Audio for managing my music library, Tidal and my different DACs/Zones. Since Tidal is now going full MQA for high resolution masters and that Roon is capable of doing only the first unfold of MQA, the rest has to be done by the DAC itself.
My question was to know if you plan on supporting MQA at a later date. I know there could be licensing fees but I would be willing to pay my share to be able to enjoy MQA at its full potential.
Could that be something of interest to you?
Do
PREAMPs : AMB α10 + USSPA | LDR3x + USSPA | AMPs: AMB β24 | USSA5 | TGM8 | VZ Audio NS OPS | FC-100 | Modulus-686 |
DACs : Mirand AK4490 + Discrete Output | Speakers : Troels Gravesen ATS-4 | Sagwee LT V3 |
Old 19th April 2019, 05:24 PM   #3427
pinnocchio's Avatar
ESS is coming soon with new DAC chips that will support native complete unfold of MQA files. This will be great because the product no longer need rigorous tests from MQA org. I believe they will have Pro and mobile chips as well.
Old 19th April 2019, 06:00 PM   #3428
Julf is offline Julf  Europe
It is great only if you believe the MQA woo.
Old 19th April 2019, 06:23 PM   #3429
chi0001 is offline chi0001  Hong Kong
anyone know how to connect it?
i tried but very little sound coming out, the ess controller i already set to 0db.
Old 19th April 2019, 07:36 PM   #3430
The tamura does not have a center tap on output so You will not be able to run differential.
You can connect same numbers. Only 5 must not be connected to 5 but to ground on pcb (or left floating)
Probably better to let 2 loose as well, I do not know how it is routed on pcb.
Tamura is very nice stuff!
Ian asynchronous I2S and S/PDIF FIFO KIT group buyHide this!Advertise here!
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4927 Today 08:00 PM
High Performance WM8741 Super Mini DAC with I2S Data Switching PCB - Group Buy heartwinter Group Buys 26 19th January 2012 12:12 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
What speakers are you going to use with your gainclone group buy kit AJ Bertelson Multi-Way 6 2nd March 2004 07:01 PM
Copyright ©1999-2019 diyAudio
