Group Buys Members group buys
Ian asynchronous I2S and S/PDIF FIFO KIT group buy
Old 9th December 2018, 09:09 PM   #2771
ilgavro is offline ilgavro
Originally Posted by cps3113 View Post
1. iancanada 1*FifoPi, 1*LifiPO4 power, 1*EssController
2. Crom 1 x FifoPi, 3xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT (and if you have any left: The RPi I2S adapter that enables the ESS controller to be used as an external controller)
3. Oyvind 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
4. Pistollero 1 x FifoPi, 2xLifePO4 power
5. MikeyFresh interested in 1 pc. each of all 7 items listed in this GB
6. Randytsuch 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage
7. necplusultra 1 x FifoPi, 1xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
8. szczemirek 1 x FifoPi
9. casshan 1 x FifoPi, 1 x LifiPO4 power, 1 x Ess Controller
10. zapio : 2 x FifoPi , 4 x LifiPO4 power, 1 x Ess Controller, 1 x transformer I/V PCB mini KIT 1 x I/V STD standard I/V stage, 1 x Dual Mono ES9038Q2M DAC HAT
11. trung224 : 1xLiFePO4 power
12. Sq225917 : 1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
13. passive420: 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
14. comickitkit: 9 x Fifopi, 7 x Ess Controller, 7 x dual mono 9038 dac hat, 6 x I/V STD standard I/V stage, 1 x Transformer I/V PCB, 8 x LifePO4 pure power supply, 1 x McFIFO, 1 x McDualXO
15. crymen: 1 x Fifopi, 1 x LifePO4 power
16. ppap64: 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
17. Greg Stewart: 2 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat
18. jacklee: 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
19. kenlaumm: 1 x Fifopi, 1 x LifePO4 power
20.curryking: 1 x FIFOPi,1 x ES9038 dual mono DAC Hat, 2 x ESS Controller
21. Cerole: 1 x FifoPi, 3 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1*I2S FIFO 2 Kit, 1*Dual XO clock board, 1*SPDIF interface, 1*I2S to PCM, 1*FIFO II isolator PCB
22. Big bird: 1 x Fifopi, 1 x LifePO4 power, 1 x ES9038 dual mono DAC Hat, 1 x ESS Controller
23. wealas: 2 x LiFePO4 power
24. ernesternest: 1 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage
25. nounouchet: 3 x LiFePO4 power
26. mjensen: 1 x FifoPi, 1 x LifePO4 power, 2 x ESS Controller, 1 x Dual Mono 9038 Dac Hat, 1 x I/V STD standard I/V stage
27. janho12345: 1x FifoPi
28. Forane12: 2X FifoPi , 3X LifiPO4 pure power supply, 2X ESS controller, 2X Dual Mono ES9038Q2M , 2X ES9028Q2M DAC HAT, 2X I/V STD standard I/V stage, 2X Transformer I/V PCB
29. Joseacm08: 1X FifoPi , 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M , 1X ES9028Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
30. ccliu: 1X FifoPi , 2X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M , 1X ES9028Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
31. e-yakovkev: 1 x FifoPi, 3 x LifePO4 power
32. minivan: 1xfifopi ,1x Lifepo4 pure power
33. StarLex: 1X FifoPi , 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
34. Akasaka: 1x FifoPi, 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini KIT
35. Yatsushiro: 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT
36. luchoh:1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage,
37. nielsek:1xFifoPi, 1x LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage
38. emynet 1x FifoPi, 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini KIT
39. cspirou: 1*I2S FIFO 2 Kit, 1*Dual XO clock board(no XO), 1*SPDIF interface, 1*I2S to PCM, 1*FIFO II isolator PCB, 1*RPi I2S PCB adapter, 6*LT3042/LT3045 PCB, 1*I/V STD stage, 1*transformer I/V PCB kit, 1*LifiPO4, 1*McDualXO, 6* U.FL coax (any length), 1*SMT XO adapter package, 1*I2S backdoor kit
40. Brumjam: 1 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT
41. misterdog:1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
42. palmito: 1*FifoPi, 1*LifiPO4 power, 1*ESS controller, 1*Dual Mono ES9038Q2M, 1*I/V stage, 1*Transformer I/V PCB mini KIT
43. flowerpot: Withdrawn (After some consideration decide to withdraw from this GB)
44. _oxygen: 1x FifoPi, 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini KIT
45. SonofThor: 1x FifoPi, 1x LifePo4 power, 1x ESS controller, 1x Dual Mono ES9038Q2M, 1x STD standard I/V stage, 1x Transformer I/V PCB mini kit
46. Morde: 1x FifoPi, 2x LifePo4 power, 1x ESS controller, 1x Dual Mono ES9038Q2M, 1x STD standard I/V stage, 1x Transformer I/V PCB mini kit
47. 1001meier: 1xFifoPi, 1x LifePo4 power
48. deenoo: 1*FifoPi, 1* LifePo4 power, 1*ESS controller, 1*I/V STD standard I/V stage, 1*Transformer I/V PCB mini KIT
49. Robs : 1*FifoPi, 1* LifePo4 power, 1*ESS controller, 1*I/V STD standard I/V stage, 1*Transformer I/V PCB mini KIT
50. linh0983 : 1xLiFePO4 power , 1xDual Mono ES9038Q2M , 1x FifoPi
51. JoeyDD: 1*LifePO4 power, 1*ESS controller
52. pierantonio: 1 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage
53. xaled: 1x FifoPi, 2x LifePo4 power, 1x ESS controller, 1x Dual Mono ES9038Q2M, 1*Transformer I/V PCB mini KIT
54. Duanbui: 1xLiFePO4 power
55. maartn: 1x FifoPi, 1 x ESSController
56. syracuze: 1 X FifoPi , 3 X LifePO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
57. Flyingsparks: 2X FifoPi , 2X LifiPO4 power , 2X ESS controller, 1X Dual Mono ES9038Q2M , 1X ES9028Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
58. number9, 1x FifoPi, 1x LifePo4 power, 1x ESS controller, 1x Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage
59. duc985: 1x FifoPi, 1x LifePo4 power, 1x ESS controller, 1x Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage,1X Transformer I/V PCB
60. Lucser: 2 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage and, if completed, 2 x I2S to LVDS HDMI Tx modules as per #2602 post.
61. Stokessd: 1x FIFO, 1x ESS Controller, 1x Dual Mono ES9038Q2M DAC HAT, 1x Transformer I/V PCB mini KIT
62. tomcoppa 1*FifoPi, 1*LifiPO4 power, 1*EssController, 1*dual mono 9038 dac hat, 1*I/V STD standard I/V stage, 1*transformer I/V PCB mini KIT
63. Blitz: 3xLifePO4 Power, 1*transformer I/V, 1*I/V Standard
64. Chipno :1 x FifoPi , 1 x LifiPO4 power
65. simon dart: 1x FifoPi, 1x LifePo4 power, 1x ESS controller, 1x Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage,1X Transformer I/V PCB
66. kolossos4730: 1 x FifoPi 768KHz I2S/DSD/DoP FIFO for RPi with built in isolator, 1 x LifiPO4 pure power supply, 1 x ESS controller, 1 x Dual Mono ES9038Q2M DAC HAT, 1 x I/V STD standard I/V stage
67. mksung: 1*FifoPi
68. stavros61:1 x FifoPi 768KHz I2S/DSD/DoP FIFO for RPi with built in isolator, 1 x LifiPO4 pure power supply, 1 x ESS controller, 1 x Dual Mono ES9038Q2M DAC HAT, 1 x I/V STD standard I/V stage
69. cjunkk: 1X FifoPi , 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
70. bartb: 1x McFIFO, 1x McDualXO, 1x LifiPO4-pure
71.JimS::1 x FifoPi 768KHz I2S/DSD/DoP FIFO for RPi with built in isolator, 2 x LifiPO4 pure power supply, 1 x ESS controller, 1 x Dual Mono ES9038Q2M DAC HAT, 1 x I/V STD standard I/V stage
72.KenI:1*FifoPi 768KHz I2S/DSD/DoP FIFO for RPi with built in isolator, 1*ESS controller, 1*Dual Mono ES9038Q2M DAC HAT, 1*I/V STD standard I/V stage
73.kvl: 1*FifoPi, 1* LifePo4 power, 1*ESS controller, 1xDual Mono ES9038Q2M ,1*I/V STD standard I/V stage, 1*Transformer I/V PCB mini KIT
74 secanbj 1*FifoPi, 1*ESS controller, 1xDual Mono ES9038Q2M ,1*I/V STD standard I/V stage
75.deanoUK :1 x FifoPi 768KHz 1 x LifiPO4 pure power supply, 1 x ESS controller, 1 x Dual Mono ES9038Q2M
76. cubano: 1X FifoPi , 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage
77. Hellokitty123: 1X LifiPO4 pure power supply / 1X I/V STD standard I/V stage 1X / Transformer I/V PCB mini KIT
78. nori1000: 1 x FifoPi 768KHz I2S/DSD/DoP FIFO for RPi with built in isolator, Or 1x Isolator II, 1 x LifiPO4 pure power supply, 1 x ESS controller, 1 x Dual Mono ES9038Q2M DAC HAT,
79. Rowli: 2 x LifiPO4
80. Sidiropa: 1*LifePo4 power
81. stephengrenfell 1*FifoPi, 1*LifiPO4 power
82. Mindfunk: 1 x FifoPi 768KHz I2S/DSD/DoP FIFO for RPi with built, 1X LifiPO4 pure power supply
83. tanelip: 1*FifoPi, 2*LifiPO4 power
84. sbiswas-1: 1 x McFIFO, 1x McDualXO,1x LifiPO4 pure power supply
85. Jjazz: 1 X FifoPi , 1 X LifePO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini kit.
86. s666foto: 1 X FifoPi , 1 X LifePO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini kit.
87. niner: 2 x LifiPO4
88. maui: 1 * FifoPi, 1 * LifePO4, 8 * U.Fl wire single ended coax, 1 * XO adapter kit lot of 5
89. ofswitched: 2 * FifoPi, 2 * LifePO4, 1*ESS controller
90. neslo: 1 X FifoPi , 1 X LifePO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini kit.
91 AlanElsdon:1 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage
92 cv: 2 x FifoPI
93. chi0001: 1 x FifoPi, 1 x LifePO4 power, 2 x 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1X I/V STD standard I/V stage, 1 x transformer I/V PCB minit kit
94. cps3113:1 X LifePO4 pure power supply.
95. ilgavro 1x fifopi 2x lifepo4 power 1xesscontroller 1x dual mono 9038 da hat 1 x std standard I/V stage
Old 9th December 2018, 10:20 PM   #2772
iancanada is offline iancanada  Canada
iancanada's Avatar
92 cv: 2 x FifoPI
Old Yesterday, 12:06 AM   #2773
ykharlamov is offline ykharlamov
92 cv: 2 x FifoPI
96. ykharlamov: 1 x LifePO4 power, 1 x McFIFO, 1 x McDualXO
Old Today, 12:11 AM   #2774
M_Balou is offline M_Balou  Europe
M_Balou's Avatar
92 cv: 2 x FifoPI
97. M_Balou: 1*FifoPi
Old Today, 02:34 AM   #2775
yaboin is offline yaboin  United States
1. iancanada 1*FifoPi, 1*LifiPO4 power, 1*EssController …
92 cv: 2 x FifoPI
98. yaboin: 1*FifoPi, 1*LifePO4 power, 1*ESS Controller, 1*dual mono 9038 dac hat, 1*I/V STD standard I/V stage, 1*transformer I/V PCB mini kit
Old Today, 04:17 AM   #2776
stenachio is offline stenachio  United States
92 cv: 2 x FifoPI
99. stenachio: 1*FifoPi, 1*LifePO4 power, 1*ESS Controller, 1*dual mono 9038 dac hat, 1*I/V STD standard I/V stage
Ian asynchronous I2S and S/PDIF FIFO KIT group buyHide this!Advertise here!
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4740 Yesterday 08:39 PM
High Performance WM8741 Super Mini DAC with I2S Data Switching PCB - Group Buy heartwinter Group Buys 26 19th January 2012 01:12 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 05:00 PM
What speakers are you going to use with your gainclone group buy kit AJ Bertelson Multi-Way 6 2nd March 2004 08:01 PM
