Group Buys Members group buys
Ian asynchronous I2S and S/PDIF FIFO KIT group buy
Old 17th December 2017, 11:20 AM   #2541
cyrilliu is offline cyrilliu  Taiwan
Banned
Originally Posted by wealas View Post
So you edited both files and restarted, correct? When running Spotify, can you do "ps -ef|grep spot" and see if you get the full command line, maybe some parameters are passed there that force the bit rate or it is not using the spotout device. Also try to change hw:1 to plughw:1 in both files.
No change after I changed hw:1 to plughw:1 in both files.
Old 17th December 2017, 11:22 AM   #2542
wealas is offline wealas
Yep, see my previous message.
Old 17th December 2017, 11:40 AM   #2543
Banned
Yep, there is the problem: --device plughw:1
it needs to be spotout
looks like volspotconnect2 doesn't have the logic to use spotout.
You can try and edit /data/plugins/music_service/volspotconnect2/index.js and change the line
Code:
var conf3 = conf2.replace("${outdev}", hwdev);
to
Code:
var conf3 = conf2.replace("${outdev}", "spotout");
save and restart volumio.
Nothing happened after I have done this change and restart.
Old 17th December 2017, 11:52 AM   #2544
Banned
Code:
  var outdev = self.commandRouter.sharedVars.get('alsa.outputdevi$
                var devicename = self.commandRouter.sharedVars.get('system.name$
                var hwdev ='plughw:' + outdev;
                                if (outdev == "softvolume") {
                                        hwdev = "softvolume"
                var conf1 = data.replace("${shared}", shared);
                var conf2 = conf1.replace("${devicename}", devicename);
Old 17th December 2017, 12:31 PM   #2545
Ah, they restore the plugin and wipe the changes, sorry, I don't know how to help you. Maybe go on the volumio forums.
Old 17th December 2017, 12:32 PM   #2546
Banned
ok, thanks!
Old 17th December 2017, 01:05 PM   #2547
Banned
Both of asoundrc and /etc/asound.conf are created by spotify configuration. When I do spotify configuration again, the contents of asoundrc and /etc/asound.conf will be changed to default setting.
Old 17th December 2017, 03:03 PM   #2548
You can check the index.js and see where it gets the templates for the asound files and edit the templates and Google where volumio stores the plug-in sources so you can edit those in order to get the changes you want to stick after reboots.
Old 18th December 2017, 04:49 AM   #2549
Banned
volumio-snapcast-plugin may solve this problem.
GitHub - Saiyato/volumio-snapcast-plugin: Volumio 2 SnapCast plugin, to easily manage SnapCast functionality
Old 18th December 2017, 02:24 PM   #2550
Banned
Originally Posted by cyrilliu View Post
volumio-snapcast-plugin can not resample to 24bit. I give up....
Ian asynchronous I2S and S/PDIF FIFO KIT group buyHide this!Advertise here!
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4856 10th April 2019 07:11 AM
High Performance WM8741 Super Mini DAC with I2S Data Switching PCB - Group Buy heartwinter Group Buys 26 19th January 2012 12:12 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
What speakers are you going to use with your gainclone group buy kit AJ Bertelson Multi-Way 6 2nd March 2004 07:01 PM
Copyright ©1999-2019 diyAudio
