I would like to ask a noob question, can ian es9028q2m and ess controller work with jlsounds i2soverusb without raspberry pi? Which mode it can work on, async or sync?
Thanks.
Yes, that's possible, you will need the ReceiverPi rather than the RPi in this case.
The configuration would be:
USB streamer + ReceiverPi + ESScontroller + ES9028Q2M +IV.
If you want to improve sound quality by sync mode, then you can add a FifoPi between ReceiverPi and ES9028Q2M.
Ian
I'm trying use a Aroiodac with the ReceiverPi in a RPI free mode, but i have no audio out when i attach optical input, there is light in D7(lock) and D9 (OPT)..
Is this combination possible?
I suspect that the Aroiodac is a master DAC.
ABACUS electronics - AroioDAC
It sens to put fifopi recocler between soekris dam 1021dac and xmos usb interface? This will be roon core on intel nuc to lan, raspberry b3 to lan and to xmos interface by usb. Or mayby better SQ will be connect raspberry by i2s to fifopi rec and next by i2s to dam1021?
@bmxmen - I thought that DAM1021 generates its own clocking, thus re-clocking before hand is unnecessary. Also since RPi doesn't allow for synchronous clocking then it's not really worth it.
I would say otherwise. I used to have soekris Dam. It actually does not have recloking, but rather adaptive clocking. You will not find two clocks with exact 45.x and 49.x audio frequencies anywhere on Soekris board. I tried soekris with differet I2S interaface and it gave me different sound each time. So I would go with Ian reclocker in front of Soekris.
Hello j know that amanero usb or xmos usb via i2s to dam 1021 plays difrent. I have heard that it is better to konnect raspberry via i2s but it need a good galvanic isolator. And something to reclock jittered i2s section in raspberry. for now im playing by usb to xmos then i2s.
1. iancanada 19A*1, 20A*1, 21A*1, 22A*1, 23A*2,24A*1
2. jacklee 19A*1, 20A*1, 21A*2, 22A*3, 23A*2, 24A*1, 1A*1, 27*
3. jimk04 1A*2, 3A*1, 4A*1, 8A*2, 9A*2, 10A*2, 11A*2, 13A*1, 16A*2, 19A*2, 23A*2, 24A*1, 27*1
4. PJotr25 9A*1, 10A*1, 11A*4, 19A*1, 21A*1, 22A*1, 23A*2, 27*1
5. adrian311 19A*1, 14A*2, 21A*4, 22A*1, 23A*2, 24A*1, 13*4, 19*1, 20*1
6. photochum1 = 20A*1, 1A*1, 9A *1 (CCHD957 XO adapter KIT lot of 2), 12Ax2,
7. linh0983 19A*1, 20A*1, 23A*2
8. KFU 13A*4, 19A*1, 23A*1
9. Ernesternest: 13A*2, 21A*2, 22A*1, 23A*1
10. sgledhill 3A*1, 4A*1, 8A*1, 11A*1, 21A*1, 22A*1, 22A*1, 23A*2, 24A*1
11. Yatsushiro 8A*1, 19A*1, 21A*2, 23A*2
12. trung224 1A*1, 9A*1, 11A*4, 13A*3, 14A*1, 20A*1, 21A*1, 22A*1, 23A*2, 27*1 (add some items)
13. necplusultra 2A,13A,15A,12A,23A*2,7A,19A,20A
14. Sebbyp 21A*2 (SMD Finished), 22A*1, 23A*2, 1A, 7A, 8A, 9A
15. s666foto 1A*1, 3A*1, 5A*1, 8A*1, 18*1, 19A*1, 20A*1, 21*1, 21A*2, 22A*1, 23A*2
16. nounouchet 19A*1, 21A*1, 22A*1, 23A*1, 20*1, 23*4, 24*4
17. Myint 67 19A *1 , 20A*1 ,21A*1 ,23A*1,24A*1,9A*1,11A*1, 17*4
18. TioFrancotirador 19A*1, 22A*1, 23A*2, 1A*1, 4A*1, 3A*1, 8A*1, 11A*1, 9A*1
19. Rrbs 21A*1, 23A*2
20. Pinnocchio 19A*1, 20A*1, 17A*1, 18A*1, 21A*2
21. redjr 7A*1, 19A*1, 20A*1, 21A*1, 23A*1, 24A*1, 27*1
22. Stones 19A*1, 21A*2, 23A*2, 27*1
23. mksung 19A*1, 20A*1, 21A*1, 22A*2, 23A*1 ,24A*1
24. alazira 4A*1, 11A*4, 17A*1, 18A*1, 19A*1, 20A*1, 21A*1, 22A*1, 23A*2, 24A*1, 17*8, 27*1
25. metronet 3A, 4A, 7A, 10A, 13A*4, 22A, 23A, 24A, 21*4, 27
26. Beetrood 19A*1, 20A*1, 23A*2, 24A*1, 27*2
27. ccliu 7A*1, 13A*4, 17A*1, 18A*1, 19A*1, 20A*1, 21A*1, 22A*1, 23A*2, 24A*1, 27*1
28. unixdeveloper 19A*1, 20A*1, 21A*2, 22A*1, 23A*4, 24A*1, 27*1
29. TirNaOg 17A*1, 21*4, 22*4
30. DUC985 9A, 21A, 23A*2
31. topicreader 19A*1, 20A*1, 21A*1, 22A*1, 23A*2, 24A*1
32. fergas 19A*1, 23A*1, 24A*1, 27*1
33. rickmcinnis 1A, 23A
34. JimS 13A*4, 17A*1, 18A*1, 21A*1, 22A*1, 23A*2, 27*1
35. duster1 1A*2, 3A*1, 4A*1, 8A*1, 9A*1, 19A*3, 21A*3, 22A*1, 23A*2, 24A*1, 27*1
36. M_Balou 21A*1, 22A*1, 23A*2
37. palmito 20A*1, 21A*3,23A*2
38. Daniel Lin 19A*1, 20A*1, 22A*1, 23A*1, 24A*1, 21 * 4
39. mnichols30030 3A*1, 5A*1, 6A*1, 8A*1, 11A*1, 12A*1, 16A*2, 22A*1, 23A*2, 24A*1
40. kvl 5A*1, 13A*4, 14A*1, 19A*1, 21A*1, 22A*1, 23A*2, 24A*1
41. zapio : 9A *2, 13A*4, 19A*1, 20A*1, 21A*2, 22A*2,23A*2
42. oyvind 21A*1,22A*1,23A*1
43. eagwok33: 13A*4, 19A*2, 20A*2, 21A*2, 23A*2
44. deanoUK 13A*4, 14A*2, 17A*1, 18A*1, 19A*1, 20A*1, 21A*2, 22A*1, 23A*2, 24A*1
45. Julf 1A,9A,12A*2,20A,22A
46. KenI 11A*4,12A*2,16A*1,19A*1,20A*1,21A*1,22A*1
47. Aguaazul 13A*4, 14A*2, 16A*2, 19A*1, 20A*1, 21A*2, 22A*1, 23A*2, 24A*1, 10*1, 12*4, 21*1, 27*1
48. prohvesor 1A*1, 3A*1, 4A*1, 7A*1, 9A*1, 19A*1, 21A*1, 23A*2, 27*1
49. Grarea 1a*1, 11a*1, 20a*1, 23a*2, 24a*1
50. Prakit 6A*1, 8A*1,12A*4, 20A*1
51. Spev 13A*4, 23A*2
52. Mull3t 1A*1, 5A*1, 13A*4, 23A*2, 24A*1, 20*1, 27*1
53. Terry22 21A*2, 23A*2, 11*2, 13*2, 14*2, 15*2
54. STEDAV 1A*1 2A*1 3A*1 4A*1 6A*1 8A*1 9A*1 10A*1 12A*1 13A*4 14A*2 16A*1 18A*1 19A*1 21A*1 22A*1 23A*2 24A*1 27*1
55. judesu777 1A*1 2A*1 3A*1 4A*1 6A*1 7A*1 8A*1 9A*1 11A*4 13A*4 14A*2 14*427*1
56. Lucser 9A*1 13A*4 16A*1 15*4 20A*1, 21A*2, 22A*1, 23A*2
57. dirkwunderl 1A*2 11A*4 17A*1 18A*1 19A*2 20A*2 21A*1 22A*2 23A*2
58. jaq 1A*1, 3A*1, 4A*1, 8A*1, 13A*3, 19A*1, 21A*1, 22A*1, 23A*1, 24A*1
59. chih 7A*1, 13A*2, 14A*1 , 19A*1, 21A*1, 23A*2, 24A*1, 27*1
60. pierantonio 10A*1, 13A*2, 19A*1, 21A*1, 22A*1, 23A*1, 27*1
61. ozcal 23a*2
62. wcwc 10A*1, 13A*4, 18A*2, 19A*1, 20A*1, 22A*1, 23A*2, 13*4, 27*1
63. ricyuyc 1A*1, 13A*2, 19A*1, 22A*2, 11*2, 26*2
64. nano35 1A*1, 22A*1, 23A*1, 24A*1, 27*1
65. atom6422 12A*2, 13A*4, 14A*2, 15A*1, 17A*2, 18A*2, 19A*1, 20A*1, 21A*3, 22A*2, 23A*2, 24A*1, 5*1, 21*4, 27*1
66. UMarcus 1A*1, 3A*1, 4A*1, 6A*1, 7A*1, 8A*1, 9A*1, 11A*3, 12A*4, 13A*1, 16A*2, 21A*1, 22A*1, 23A*2, 24A*1, Update : 10A*2, 27*1
67. AlanElsdon 19A*1, 21A*2, 22A*1, 23A*2
68. Maniolo 1A*1, 9A*1, 12A*3, 20A*1
69. Arnolddew 1A*1, 9A*1, 13A*1, 20A*1, 23A*1
70. AudioDAC 16A*1, 19A*1, 20A*1, 23A*2, 24A*1,
71. Narukas 9A*1, 11A*4, 19A*1, 23A*2, 13*4, 23*1
72. kft 1A*1, 3A*1, 4A*1, 6A*1, 8A*1, 9A*1, 16A*, 24A*1, 27*1
73. Patjr 8A*1, 19A*1, 21A*1,23A*2
74. Sam402 1A*1, 11A*4, 12A*3, 18A*1, 20A*1, 23A*1
75. duanbui 1A*1, 9A*1, 11A*4, 13A*3, 14A*1, 20A*1, 21A*1, 22A*1, 23A*2, 27*1
76. ffeg2008 1Ax1, 3Ax1, 4Ax1, 6Ax1, 7Ax1, 8Ax1, 10Ax1, 13Ax2, 14Ax2, 19Ax1, 23Ax2, 24Ax1,27x1
77. Bartb 23A*2, 1*1, 2*1
78. vanofmonks 19A*1, 21A*1, 23A*1, 27*1
79. samsie 1Ax1, 3Ax1, 4Ax1, 6Ax1, 7Ax2, 8Ax1, 13Ax4, 14Ax2, 20Ax1, 23Ax2, 24Ax1,27x1
61. ozcal 23a*2
New DAC HAT Design?
@Ian, Any plans to work your digital magic with a new pi DAC hat based on the AKM4497/99 chip? I think it would be a big hit as you seem to have a band of loyal followers here on DIYAudio. Now that I have tweaked my ESS9038 stack to the point where it's such pleasure listen to, I'd like to compare it to the AKM 'velvet' sound. It's time to build another DAC stack! I'll be first in line. 😀
Hello mayby you will help. I was testing this system: roon core on intel nuc, roon bridge raspberry pi4 with moode audio 6.2 ,next bu usb to xmos , next via i2s tp soerkis dam1021 dac. Im plaing with upsampling to 352/384khz in roon audio, it plays laouder and more detailed then normal 44khz. Next test intel nuc with roon core ,roon bridge raspberry pi4 with moode audio 6.2 via i2s to dam 1021 dac. And in roon core seting it is limited tp 192khz,of corse i dont se much difrence in sound quality by 44 and ups to 192khz, it just play poor vs prev config. My dam 1021 dont have i2s isolators, with xmos it plays clearer without isolators. Did rasp pi 4 can play via i2s more then 192khz? Plan is to play via i2s with you reclocer. But im little scary that will be not good as xmos with ups to 384khz. Please help me!
Hi Ian,
I'm using the McFIFO board in a three-way DAC based on AK4483.
The McFIFO works very well. It is directly battery powered from a LifePO4 board. I have also integrated the Arduino "FifoDisplay" code into my project to display the available information on a 3.5 inch TFT screen.
Just missing the information about the number of bits of the input signal, would it be possible to get it with an update of the board?
I have a question about the Ground management with the McFIFO board. The 6 fixing holes of the card are connected to 0V. So when the board is fixed on the chassis by metal brackets, there are 6 points of contact with the Ground. Isn't it better to isolate the 0v from the ground and use 6 plastic brackets?
nounouchet
nounouchet
I would even be willing to prepay for this AK4499
+1
I need help too!
I have not been able to play music beyond 24/192 or any DSD via I2S. I'm using an Allo USbridge and Ultimate Q2 reclocker with TransporterPi or I2S transmitter. Running Volumio.
61. ozcal 23a*2
80. Boldname 1*1, 2*1
61. ozcal 23a*2
61. ozcal 23a*2
81. Narukas 11*2
61. ozcal 23a*2
81. Narukas 11*2
@Nikon1975
Yes, it's still available. Please go ahead with sending me the order form if you are interested in.
GitHub - iancanada/DocumentDownload: Download documents of Ian's products
Ian
Ian
- Group Buys
- Ian asynchronous I2S and S/PDIF FIFO KIT group buy
