Ian asynchronous I2S and S/PDIF FIFO KIT group buy
1. iancanada 1*FifoPi, 1*LifiPO4 power, 1*EssController …
2. Crom 1 x FifoPi, 3xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT (and if you have any left: The RPi I2S adapter that enables the ESS controller to be used as an external controller)
3. Oyvind 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
4. Pistollero 1 x FifoPi, 2xLifePO4 power
5. MikeyFresh interested in 1 pc. each of all 7 items listed in this GB
6. Randytsuch 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage
7. necplusultra 2 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
8. szczemirek 1 x FifoPi
9. casshan 1 x FifoPi, 1 x LifiPO4 power, 1 x Ess Controller
10. zapio : 2 x FifoPi , 4 x LifiPO4 power, 1 x Ess Controller, 1 x transformer I/V PCB mini KIT 1 x I/V STD standard I/V stage, 1 x Dual Mono ES9038Q2M DAC HAT
11. trung224 : 1xLiFePO4 power
12. Sq225917 : 1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
13. passive420: 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
14. comickitkit: 1 x Fifopi
15. crymen: 1 x Fifopi, 1 x LifePO4 power
16. ppap64: 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
17. Greg Stewart: 2 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage
18. jacklee: 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
19. kenlaumm: 1 x Fifopi, 1 x LifePO4 power
20.curryking: 1 x FIFOPi,1 x ES9038 dual mono DAC Hat, 2 x ESS Controller
21. Cerole: 1 x FifoPi, 3 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT
22. Big bird: 1 x Fifopi, 1 x LifePO4 power, 1 x ES9038 dual mono DAC Hat, 1 x ESS Controller
23. wealas: 2 x LiFePO4 power
24. ernesternest: 1 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage
25. nounouchet: 3 x LiFePO4 power
26. mjensen: 1 x FifoPi, 1 x LifePO4 power, 2 x ESS Controller, 1 x Dual Mono 9038 Dac Hat, 1 x I/V STD standard I/V stage[/QUOTE]
27. janho12345: 1x FifoPi
28. Forane12: 2X FifoPi , 3X LifiPO4 pure power supply, 2X ESS controller, 2X Dual Mono ES9038Q2M , 2X ES9028Q2M DAC HAT, 2X I/V STD standard I/V stage, 2X Transformer I/V PCB
29. Joseacm08: 1X FifoPi , 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M , 1X ES9028Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
30. ccliu: 1X FifoPi , 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M , 1X ES9028Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
31. e-yakovkev: 1 x FifoPi, 3 x LifePO4 power
30. minivan: 1xfifopi ,1x Lifepo4 pure power
31. StarLex: 1X FifoPi , 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
32. Akasaka: 1x FifoPi, 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini KIT
33. Yatsushiro: 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT
34. luchoh:1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage,
35. nielsek:1xFifoPi, 1x LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage
35. emynet 1x FifoPi, 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini KIT
minivan lost me and e-yakovkev. add back.
31. e-yakovkev: 1 x FifoPi, 3 x LifePO4 power 30. minivan: 1xfifopi ,1x Lifepo4 pure power
32. minivan: 1xfifopi ,1x Lifepo4 pure power
33. StarLex: 1X FifoPi , 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
34. Akasaka: 1x FifoPi, 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini KIT
35. Yatsushiro: 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT
36. luchoh:1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage,
37. nielsek:1xFifoPi, 1x LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage
38. emynet 1x FifoPi, 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini KIT
Added myself back to the end
39. cspirou: 1*I2S FIFO 2 Kit, 1*Dual XO clock board(no XO), 1*SPDIF interface, 1*I2S to PCM, 1*FIFO II isolator PCB, 1*RPi I2S PCB adapter, 6*LT3042/LT3045 PCB, 1*I/V STD stage, 1*transformer I/V PCB kit, 1*LifiPO4, 1*McDualXO, 6* U.FL coax (any length), 1*SMT XO adapter package, 1*I2S backdoor kit
I changed my order
21. Cerole: 1 x FifoPi, 3 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1*I2S FIFO 2 Kit, 1*Dual XO clock board, 1*SPDIF interface, 1*I2S to PCM, 1*FIFO II isolator PCB
40. Brumjam: 1 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT
You could insert yourself back in your original position, around 20. But then you would need to shift all the others down one. Not your fault that someone accidentally deleted you.
But not sure if position on the list will make much difference, I imagine most of the dacs will ship around the same time.
Randy
Randy
Yeah, i don't think position matters. It's just an interest check and rather not re-edit all those numbers
41.misterdog:1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
41. misterdog:1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
42. palmito: 1*FifoPi, 1*LifiPO4 power, 1*ESS controller, 1*Dual Mono ES9038Q2M, 1*I/V stage, 1*Transformer I/V PCB mini KIT
43. flowerpot: 2*LifiPO4 power
