WAF : which enclosure for FE 206 ES-R ?
Old 26th March 2020, 08:16 PM   #21
noviygera is online now noviygera  United States
Of course.
Here is what I have:
Tannoy 12 in paper cone
Qts=0.50
Sd=531.0cm2
fs=57Hz
Mms=75.0g
Qms=8.065
Qes=0.573
Re=5.128ohm
Le=0.38mH
Vas=36.8L
Old 26th March 2020, 08:18 PM   #22
And another source measured the following:
image_zpse645eceb.jpg Photo by dan_clements1 | Photobucket
Old 27th March 2020, 02:32 PM   #23
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Well, you could probably do something along those lines with it, but we're in essence talking a complete new design from scratch. I'll have a look and see whether something can be created with relatively minimal changes. That said, Bill created this design for a particular purpose & to be honest, it's -how shall I say it?- not necessarily the most linear device on the planet.
www.wodendesign.com (commercial site)
www.frugal-horn.com www.frugal-phile.com (community sites)
Old 27th March 2020, 05:22 PM   #24
waxx is offline waxx  Belgium
I would also get rid of that driver if you can't build a big horn with it. It's very good for that, but it's the only thing it can do. For smaller designs other fullrange drivers are way more usefull.
A Tang Band W8-2145 or a Mark Audio Alpair 10 series gives you a lot more options (just as example, there are many more) that will have a much higher waf factor.
Old 27th March 2020, 05:55 PM   #25
Scottmoose's Avatar
I won't comment about other drive units, but purely from the perspective of physics / loudspeaker engineering, the Tannoy units mentioned do not require a big horn; they're suitable for other forms of vented box loading, or sealed boxes for that matter if you don't mind the relatively limited LF extension from a large unit. It depends what the end objectives / requirements happen to be.
Old 27th March 2020, 07:21 PM   #26
Didn't mean to highjack this thread. I have the Tannoys v12 -- compact reflex enclosure. I was looking to try another enclosure. Should I start another thread? The design I wanted to explore is a transmission line terminated by a Karlson slot.
WAF : which enclosure for FE 206 ES-R ?Hide this!Advertise here!
Switching car audio enclosure to home enclosure wattz Subwoofers 10 18th April 2010 05:51 PM
help, bmb cs 350 enclosure triast Multi-Way 0 8th July 2007 09:38 AM
Convert horn enclosure to sub enclosure chipco3434 Subwoofers 5 22nd December 2004 03:54 PM
the $5 amp enclosure theChris Chip Amps 62 30th June 2004 01:29 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
