TABAQ TL for Tang Band
Old 30th June 2020, 07:45 AM   #3051
nas3000 is offline nas3000  Lithuania
Originally Posted by GM View Post
Translating to nothing........ Per the chart, a shelf vent has a 2.227 'pipe' end correction, though without access to my own calculator based on measurements, not on pipe end corrections per se, I can't say how accurate it is other than it's my understanding that the chart has been vetted/well proven by others, both pro and DIY.
Re when does a reflex, which is presumed to have a uniform particle density air mass 'plug', change to a 1/4 WL resonator [MLTL, etc.], is when simmed using accurate pipe/horn theory, the 'visible' and/or measured turnover point is when the reflex calculated alignment is 'stretched' to a high enough aspect ratio [pipe compression ratio [CR] to my way of viewing it] that the vent is becoming too long for a given vent area [Av], i.e tuning [Fb, Fp] is 'creeping' lower due to increasing 1/4 WL pipe action increasingly damping the vent with increasing CR.
I currently only have Hornresp [HR] loaded, which has no shelf vent option and otherwise WRT accuracy only know that it's good enough when the vent is a reflex [hole in a box], be it just a box or some type of MLTL and one pipe vent MLTL recently done by 'Scottmoose' in MJK's software for comparison.
All that said, historically it was recommended to start with too large and or too long a vent and do final tuning in-room and IME, many times I had to tune each cab individually for best overall in room performance; though admittedly I'm from the era of 'acoustic solutions to acoustic problems' since highest practical acoustic efficiency was a primary goal, whereas today with ~affordable, high SQ, all encompassing DSP, cheap high power; speaker design has become mostly moot in [casual] DIY, consumer HIFI/HT apps.
GM
Dear GM,
It may be my language barrier, but... Are you talking about personal calculator, which differs a little from the publicly known formulas?
Or there is another things to consider vent tuning, when building MLTL?
Both???
Old 30th June 2020, 07:54 AM   #3052
perceval is offline perceval  Taiwan
perceval's Avatar
So, tilting works fine.
I have the SB65 pushed back 15cm from a plumb line aimed at the base.
It is also great to better time align the woofer to the full range.
Nas, as I have stated, only the frequencies higher than 200Hz were affected, anything under, I guess the wavelengths are just too great to be affected by such a small change.
That room has bass traps in all 4 corners, but I still get dips and peaks in the lower frequencies if I move around the room.
Old 2nd July 2020, 08:35 AM   #3053
Entas is offline Entas  Lithuania
Hello,
I have attached a picture of two TABAQs. Which one looks better for you? Left one has a vent at the bottom and the right one, has a vent in the middle of the CSA (second attachement).
Old 14th July 2020, 05:56 AM   #3054
irishpatrick33 is offline irishpatrick33  United States
I kinda finished my speakers. The binding posts arenít oriented correctly on a couple (ridiculous mistake). So I will probably open back up and fix. This design is the vertical port using a brick inside the reservoir to weigh down. It took forever, though I was adhering to mm level precision. At one point I dropped a 3/4 assembled speaker, essentially knocking it over onto a concrete floor. The darn thing tried exploding on the top of the side facing up. Luckily it split along the joint. Glueing back together solved it. I may add cloth to entire speaker... or not.
Iím letting them break in. The speakers are plenty loud with sufficient bass for my tastes/circumstance. Iíve only had a set of B&O RL 60.2ís in the same system. The B&Oís has more slam due to actual woofer. Though they had a poor sound stage and required placement at ear level for listening. These babies lack the slam but soundstage far better. The midrange doesnít compare with a Maggie. Iím wondering what more or less stuffing might do. I will only open back up once more, anything more is asking for trouble.
File Type: jpg 0947DA48-82D7-4660-9659-CD0B634009B3.jpg (635.0 KB, 176 views)
File Type: jpg 51D3AAE1-951D-45FF-84B5-E32D26022432.jpg (891.3 KB, 174 views)
File Type: jpg 2CDEF919-6A54-4C0F-9980-F95992FAF2EF.jpg (761.9 KB, 172 views)
File Type: jpg 1E2E2E0A-D332-41CF-99E9-05A00A1894D7.jpg (817.0 KB, 92 views)
Old 14th July 2020, 12:39 PM   #3055
twocents is offline twocents  South Africa
twocents's Avatar
They came out beautiful irishpatrick - despite some mishaps. I like the rounded corners and the rebates for the drivers are perfect. CNC I assume, or some excellent router skills. Hope you enjoy them more after the drivers have loosed their muscles a bit. Are you using a BSC?
Old 14th July 2020, 02:24 PM   #3056
perceval's Avatar
Rebating a Faital driver is certainly not the easiest.
The rounded corners are indeed quite nice, too.
Because you are the builder, only you will notice the little flaws. Everybody else will marvel at these.
You will indeed need a BSC with them, if you hadn't already.
It would bring back the midrange and bass slam that a 3" driver can provide!
Enjoy!
Old 14th July 2020, 03:13 PM   #3057
What is a BSC?
Old 14th July 2020, 03:28 PM   #3058
twocents's Avatar
BSC = Baffle Step Compensation (or circuit). To use Bjorn's own words from one of his documents:
TABAQ in your listening room
Until now, I have been is the world of theory. Real life is different, and I have to deal with the baffle step problem, which is general for all full range designs.
You already know than a speaker placed in the middle of the room has a weaker bass then placed against the wall. The same thing is happening for the middle and high tones, which get extra help from the front of the cabinet. The result is a speaker that sounds bright with a focused middle tone. This ďanalyticalĒ sound will be irritating after some time.
Therefore, a baffle step compensation circuit is needed to attenuate the higher frequencies.
Does it sound complicated? It is not. It is just a resistor and an inductor in parallel and placed in the + cable to the driver.
Martin King latest MathCad models now include calculations needed for baffle step compensation. The values for the TABAQ are a resistor of 3.9 Ohm and an inductor of 1.0 mH. This is 4 db attenuation at 700 Hz. If your cabinet is more than 1 meter from the wall Ė or your personal choice would prefer more attenuation of the higher frequencies, 6 db attenuation is accomplished by using 6.8 ohm and 1.5 mH instead.
Old 15th July 2020, 03:35 AM   #3059
kissabout2002 is offline kissabout2002  Italy
wowww they are simply gorgeous love it
Old 15th July 2020, 12:21 PM   #3060
Kudos for implementation. Ascetic but very very solid and professional. Is this 3fe25 or 3fe22? If you run some test tone from 20Hz to 20kHz when there is "some" bass and when there is "solid" bass? Are they suitable for 60-65Hz?
TABAQ TL for Tang BandHide this!Advertise here!
Tang Band W3-593SF vs. Tang Band W3-926SD Zaputh Full Range 17 5th June 2009 11:37 PM
Tang Band MTM ? wrenchone Multi-Way 11 21st November 2007 06:39 PM
8 x 12 Tang Band troystg Subwoofers 3 2nd February 2007 03:37 AM
Tang-band 2-way (W3+W8) haffe Multi-Way 10 31st January 2007 11:11 PM
New Tang Band is BUSTED! Zero Cool Subwoofers 6 8th May 2006 04:15 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
