TABAQ TL for Tang Band
Old 8th December 2019, 12:38 AM   #2541
Nahuelitsn is offline Nahuelitsn
Hi guys, I´m working in a tab design adapted to the Faital 4fe35. adapting the size of the cross section to the sd of the driver and in consequence every other aspect of the design. I'm modeling on Hornresp and its funny that I have less ripple with the driver in the start of the closed end than offsetting the driver to 1/3 of the total length of the TL. But in consequence have a more radical bass roll off and a increase in time delay and displacement.
Its ok? or is any problem with Hornresp. ?
Thank you so much to all.
Old 10th December 2019, 07:39 AM   #2542
revisorn is offline revisorn  Sweden
First: thanks to Björn who have replied in this thread for over a decade. This must be some sort of record....
A question:
Have anyone tried the TB driver W-1720 in the TABAQ design? It is labeled as a woofer (up to 8k) but it looks as if it can be used as a fullrange.
https://www.parts-express.com/pedocs...spec-sheet.pdf
Old 10th December 2019, 08:12 AM   #2543
perceval is offline perceval  Taiwan
perceval's Avatar
No, that driver is not fullrange.
It breaks badly higher up, probably a lot of distortion in the higher frequencies as well.
Looking at the cone, I'm sure it starts beaming quite low.
But if you add a tweeter and cross rather steep at 2-3kHz, then you might have something interesting.
Old 10th December 2019, 12:16 PM   #2544
You may be right, I've seen a couple of projects which could serve as inspration when using that small woofer in combination with a tweeter, I guess its possible to use the TABAQ box with these drivers and crossovers (since they also are narrow speakers)
Piccolata Mini Monitor
or
Speedster - undefinition
Old 11th December 2019, 09:14 AM   #2545
burgunder is offline burgunder  Denmark
This driver is a candidate for a 2-way too and it's half the price of the TB W4-1720
Peerless by Tymphany 830870 4" PPB Cone HDS Woofer
Something like this would be nice Speedster TMM - undefinition
Old 11th December 2019, 10:00 AM   #2546
the Peerless looks nice. Regarding the TMM, you cant fit two bassdrivers in the TABAQ box as it is. In that case the box would need to be much bigger. Maybe one SD12-driver, but it would be good if the actual driver could be simulated in the TABAQ-box first.
Old 13th December 2019, 04:10 PM   #2547
senordilys3542 is offline senordilys3542  United States
Default Kjez's Question about Tang Band W8-2145
This may be late, and I hope Bjorn does not mind my interjecting something non-Tabaq into this thread. In regard to Kjez’s question of 22 October 2019 in Post 2482, about the Tang Band W8-2145, I noticed on the Parts Express site in the USA there are drawings of a TL line memjay built for the Tang Band W8-2145. See the April 1, 2017 comment in the usere reviews at<<https://www.parts-express.com/tang-band-w8-2145-8-paper-cone-full-range-driver-8-ohm--264-960>>
The line is a slightly tapered, folded one, so it is definitely not a Tabaq type. The internal volume is approximately 45.5 liters (1.68 in2), so its dimensions are materially larger than either the original 3“ Tabaq or the larger 4” and 5” Tabaqs on this thread of Bjorn’s. However, its dimensions are not beyond what can usually be accommodated in a typical domestic environment, and it probably is within the capability of a person who can build a Tabaq.
Memjay’s comments are as follows:
“I have come to think very highly of TB speakers, this one is the third TB project I have completed and am very happy with the result. I put this driver in a transmission line box hoping for a natural less Q-ie bass response. At first the sound was shrill but the speakers have broken in after a week of use and have mellowed considerably. Measurements show a 6dB roll off starting at around 48 Hz which is better than I had hoped for. Jazz, classical, vocals, piano, sound great with this speaker which is articulate and inviting. I am blown away by how good acoustic guitar sounds and sometimes get that "speakers disappear" experience many of us long for. I connected a subwoofer crossed at 40Hz and pop comes alive.
“I have included a sketch-up of the box for those who might want to try a t-line. I ordered some 3" mineral wool stuffing which I attached to one side of the entire line, stopping before visible at opening. (I cut a hole in it for the driver magnet.) Also added 45 degrees at corners inside the line which are not shown. Mine is built out of 13-ply cabinet stock and has a radius routed in the front baffle and around the opening.”
Having built Bjorn’s larger 4 “ Tabaq and liked what I heard with Tang Band W4-657 and W4-1052SD and folded TL’s (Planet 10’s Babylabs) with both Tang Band W4-657 and Mark Audio Alpair 5.2, I am thinking of memjay’s W8-2145 TL for a coming project. However, since I have not yet built it or heard it, my mention it simply as an example of what might be possible.
Old 14th December 2019, 06:09 AM   #2548
kissabout2002 is offline kissabout2002  Italy
Finally make a definite version of my Tabaq with TB W5-2143, after I listen to my last Tabaq with Faital Pro 4FE32 for long time connect back the TB W5-2143 and I really missed the clarity and crispiness on mid/hight of the Faital so I decide to add an external twitter, now is perfect and match my expectations, with this tweeter also solved the beaming problem, just connected a 3.3 uF cap on the positive pole and that's it sound wonderful.....all the best to everybody
File Type: png Screen Shot 2019-12-14 at 1.45.38 PM.png (202.5 KB, 282 views)
File Type: png Screen Shot 2019-12-14 at 1.45.02 PM.png (339.8 KB, 278 views)
File Type: png Screen Shot 2019-12-14 at 1.44.30 PM.png (601.5 KB, 277 views)
Old 14th December 2019, 07:28 AM   #2549
dewdrop is offline dewdrop  Singapore
Beautiful!
Old 22nd December 2019, 04:33 AM   #2550
tamra is offline tamra  Japan
Hello.
I have W3-1319SA.
I would like to build TL cabinet.
http://coolcat.dk/bjoern/TABAQ_TL_for_TB.pdf
Is this cabinet fits for W3-1319SA?
I am sorry for noob question. I am still
no experience to design.
http://www.tb-speaker.com/uploads/fi...d11bf63def.pdf
TABAQ TL for Tang BandHide this!Advertise here!
Tang Band W3-593SF vs. Tang Band W3-926SD Zaputh Full Range 17 6th June 2009 12:37 AM
Tang Band MTM ? wrenchone Multi-Way 11 21st November 2007 07:39 PM
8 x 12 Tang Band troystg Subwoofers 3 2nd February 2007 04:37 AM
Tang-band 2-way (W3+W8) haffe Multi-Way 10 1st February 2007 12:11 AM
New Tang Band is BUSTED! Zero Cool Subwoofers 6 8th May 2006 05:15 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
