Your favorite horn...
Old 30th September 2006, 07:02 AM   #11
johninCR is offline johninCR  United States
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
Originally posted by planet10
The Frugel-Horn Mk 2? Gotta get V1 into Martin's hands 1st.
I have a hunch, that thou possible by the theory, that a horn using the multiplying factor of a close surface still won't quit reach the same pinnacle as an all-out assault would.
dave
I was thinking of something made especially for an exact placement in my corners so the corner itself would truly be the final segment with a well planned transition into it. I would think that done correctly the concrete would make a better construction than relatively thin wood.
Everyone has a photographic memory. It's just that most are out of film.
Old 30th September 2006, 07:53 AM   #12
hm is offline hm  Europe
hm's Avatar
Default favorite horns
Hello,
look these:
http://www.hm-moreart.de/70.htm
Old 30th September 2006, 08:17 AM   #13
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
As a combination, my Harvey/Spawn horn works pretty well. BIB with FF165K. And my friend Steve's DIY tractrix horns with Lowther EX4s are pretty special when corner loaded & show a lot of potential.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 30th September 2006, 05:08 PM   #14
Rafal is offline Rafal  Canada
The Klein horns look interesting but they are way too big. I know I mentioned that I don't mind them being big but not That big.
Is the BIB a horn or is it a type if a TL?
Old 30th September 2006, 05:28 PM   #15
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
A little philosiphizing: Martin King's (and to a much lesser extent Augspurger's) tools have revealed to us a large space of what can be loosly called quarter-wave resonators. Within this space there are subspaces which nicely coincide with objects we have clasiically called horns, TLs, Voigt pipes, etc. The tools have opened up a much larger space for us to explore (the tools still don't blanket the entire space -- but i don't think Martin will be satisfied until they do), and over the last 5-6 years people have been exploring this space. Probably one of the biggest developments has seen the classification & understanding of the Mass Loaded designs... not that they weren't being built, i wonder how many designers build a tall-skinny BR and found that its response was not as expected?
The BIB is somewhere in the that space between the areas classically classified as Voigt pipe & Horn.
It is also of interest that this particular design highlited the need to be careful of the results the tool spit out and that the room cannot be taken out of the equation ... and may well have been at least partially responsible for the inclusion of some room effects being including as modeling options in the latst round of MJK sheets.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th September 2006, 08:00 PM   #16
Scottmoose's Avatar
Agreed. Lots of gray areas. For safety's sake now though, I follow GM's definition: all expanding pipes are effectively horns, so I just use that!
Old 30th September 2006, 08:49 PM   #17
YeeHaa, that means my OB-RLH is a horn after all.
Your favorite horn...Hide this!Advertise here!
Cult movies - what is your favorite - what is your favorite part Ken L The Lounge 247 9th December 2013 02:32 AM
Single Driver Horn Base Port from Frugal Horn EmergencyDpt Swap Meet 0 26th October 2008 01:24 AM
RCA MI-1425 with MI-1469 Horn, MI-1457 (W-horn) with RCA MI-? fieldcoil woofer thekop-bkk Swap Meet 0 26th September 2008 03:55 AM
Your Favorite Compression driver & Horn Combo Carl_Huff Multi-Way 15 14th December 2006 11:16 PM
Copyright ©1999-2019 diyAudio
