Aperiodic boxes for Ciare CH250
Old 27th September 2006, 06:25 PM   #21
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
I prefer the small holes (i usually tune with foam up against the holes on the inside of the box), or the long thin slot like the Dynaco A25s,
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th September 2006, 07:17 PM   #22
foniton is offline foniton  Spain
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
Hi everybody.
Many thanks for your posts.
This is a provisional drawing of my inminent aperiodic Ciares. Internal volume is 100 liters. Dimensions according to "golden ratio" (the best box calculation software if you donīt have any software). All dimensions in cm.
Panels: 18mm finland birch plywood.
Aperiodic ports shape and location are merely indicative and open to experimentation.
I havenīt decided yet about driver mounting. In my opinion back mounting is more aesthetic but I didnīt have good sonic results in the past (more veiled sound). I have to think about.
Any experience on this matter with Ciares?.
More clear for me Itīs the correction circuit thing. If correction is really essential, then I will put it before the power amp. In my opinion, this is a less invasive technique. Components of much lower values, better tolerances and, generally, better performance can be used in a simple way. Itīs cheaper too.
Your suggestions and comments are very welcome.
Best Regards.
Aperiodic boxes for Ciare CH250Hide this!Advertise here!
Ciare CH250 in a BLHorn? Henkjan Full Range 1 2nd April 2008 03:04 AM
ciare ch250 question NED 209 Full Range 0 8th March 2008 12:11 AM
Ciare CH250 JoshK Swap Meet 0 4th June 2007 01:53 PM
FS Ciare CH250 JoshK Swap Meet 3 25th April 2007 05:21 PM
Ciare CH250 w/magnets, NIB tubesguy Swap Meet 0 10th September 2006 06:19 PM
Copyright ©1999-2019 diyAudio
