UK? Inexpensive? Has something happened over here that I don't know about?
Looking for those inexpensive drivers I guess!
By the way, welcome back Sreten - over a year without a post, I'm sure I'm not the only one who wondered where you'd gone...
Depends what you call cheap! £19.99 ?
http://www.madaboutsound.com/prod.asp?pname=DFR
Vikash's site uses them from a 'Zaph' design
http://www.vikash.info/audio/W3-871S/
Maybe what you're looking for?? Not overly sensitive though.
HTH
Steve
HTH
Steve
Hi Guys,
thanks for all the replies - though I should explain what I'm after.
I want to update a late 50's valve bass combo with a bright box.
The BB is a horizontal array of 4 3" drivers, 3 4" drivers or 2 6x4
drivers. It will also have a series capacitor for bass limiting and to
reduce the loading on the valve amplifier in the bass.
The bass amps output if your lucky is ~15 watt, with the series
capacitor power handling is not an issue, nor is "sound quality".
The loading of the array must be higher than 8 ohms.
The bass combo has a 15" alnico magnet driver - so the
ideal units would be NOS old high efficiency (TV?) drivers,
very bog-standard paper cone, dust cap and surround.
/sreten.
/sreten.
- Full Range
- UK source of inexpensive 3" or 4" driver - high efficiency
