Re: question
Let me see if i can find one & i'll measure it... that will give a better idea.
dave
Originally posted by Sylver300B
Hi Planet,
Do you think the pair of half roll surround drivers could be used in a Swan 101 or Zigmahornet?
dave
Philips driver repair
The surgery has begun..
Ungluing the cone suspension surround from the frame was an easy one... ungluing the spider assembly, more tacky... but I did it and the complete cone/voice coil/ spider assembly is safe and sound..
Well, now.. what do we have here? it looks like a part of the material on wich the voice coil was wound has desintegrated.. but no burnt wires. So, how now could I kind of rewind the voice coil? if I find some holder, tube like, so that I can use it as a support, it will get stuck to the voice coil if I use some kind of varnish to fix it.. Any idea someone?
I'll put some pics when I get back from work.
Have a nice day.
Have a nice day.
Re: Philips driver repair
Sounds like you will need a new voice coil former. You get good at this and you've got a new vocation repairing vintage drivers.... what are the exact sizes of the former? I'll also look to see if i have one of these dead (still buried under my wife's sewing patterns)
dave
Sylver300B said:it looks like a part of the material on wich the voice coil was wound has desintegrated..
dave
Hey Sylvain,
I think I still have one of those drivers. I know I have also some of the non-whizzer variation of this Phillips driver. If you ever come to Montreal, I can give you one of them, perhaps you can salvage the voice coil.
These are nice drivers, but the 4 inch was the best of all (I bought a dozen of these 25 years ago from Payette électronique)
good luck!
PS mine are not of 1960`s vintage, but the frame is the exact same design and they have half-roll textile suspensions.
good luck!
Former? what is it? (french is my language..) The few drivers I have scavenged when I was a young boy had a kind of card board, or paper cylinder on wich the coil was wound.. this one doesn't seem to have that kind of support, it looks as if the coil would have been formed on a tool, then sprayed with some varnish, (brick color) so that it holds by itself, then I imagine the tool is removed and you have a coil that has no other "fomer?" than its varnish..
Am I wrong ??
Thanks Robert and friends! I am touched by the complicity and enthusiasm you folks display at giving me a helping hand.
I was in Montreal this last week-end! too bad I missed your invitation.
How do I measure the "former" ?? I imagine I do measure the voice coil diameter? the outside ?
I'll try again to get a decent pic. My camera (Canon G2) is supposed to be ok, but gee, do I have difficulties at taking close details. More later.
dave
Am I wrong ??
robertG said:Hey Sylvain,
I think I still have one of those drivers. If you ever come to Montreal, I can give you one of them, perhaps you can salvage the voice coil. PS mine are not of 1960`s vintage, but the frame is the exact same design and they have half-roll textile suspensions.
The coil is wound on the cylinder (called a voice coil former... you won't find the wire by itself.... your speaker had a VC former at some time, it is necessary to transmit the drive from the VC to the cone.
In the philips it will/would have been paper. Did you leave it behind in the gap...
dave
Sylver300B said:Am I wrong ??
dave
Re: Re: Philips driver repair
Well Dave, as I told before, I have not performed many autopsy on drivers, but yes, there used to be a paper former on wich the coil was wound.. but on this driver, it rather looks as if a thin tape would have been applied and it has partly melted when the coil was over driven.. Have a look to the pics. Sorry for the poor quality.
dave
disappearing act
Well,
I have looked carefully, and have seen no trace of the missing former.. sigh! I will look again.
As for this accordeon surround (textile) yes, it seems to be something rare. The other matching driver is perfect.. so, I'll do my best to salvage this one.
Any suggestion welcomed.
planet10 said:looks lke half the voice coil is there & half missing -- might well be sitting in the bottom of the gap... it is rare in my experience, all the accordian surrounds i recall were extensions of the cone.
dave
Well,
Message to RobertG
Hi Robert,
I would accept your offer about that driver. I see no other way to fix this poor driver.
Please email me directly at: gigueresylvain@hotmail.com
And when I go to Montreal, we arrange something, so that we can meet, may be even listen to some of your creations? And of course, I pay the beer!
Hi Robert,
Eureka! (Philips accordeon driver)
Hi folks,
Looks like I have found an easy solution to my buzzing driver with fried voice coil.
I went back to the same flea market where I had found the first pair of drivers with accordeon (textile) suspension.. and found another identical pair! for $25 cdn.
So, I now have a complete pair and a spare.
I plugged the pair and played music on them -> quite surprising. Of course, there is some boxiness due to those poor, very poor cabinets, but the mids and highs are more than decent. Very musical.
This way, I have two pairs of these Philips drivers, one pair with the half roll suspension and the other pair with the accordeon suspension, same cone, whizzer and basket/magnet and model numbers..
I'll be able to compare them in a TQWT soon.
Thanks for all those who gave me sound advices.
Hi folks,
Thanks Dave
Thanks for these specs.
They'll sure be usefull.
I'm glad you didn't forget. That makes you just even more precious.
I am on my way about finishing the Zigmahornets with Foster driver.
Do you think the Philips could work into this small TQWT?
Any suggestion about how to use these Philips? would they work in the Cyburgs Needle?
I know.. each answer generates more questions.. That's what friends are for, no?
Re: Thanks Dave
The Q on these is higher thean the FE103A which is already higher than the FE103. Fs is about the same. The unknown Vas plays a big role in the size of the box... so who knows if it will work in either of these. Certainly the Q is high enuff that it should work in an alphasTL or an ML-TQWT.
dave
Sylver300B said:I am on my way about finishing the Zigmahornets with Foster driver.
dave
- Full Range
- Full range buzzing sound. Suggestions?
