Show your aperiodic speakers
Thread Tools
Old 25th November 2021, 04:37 AM   #21
Nikolas Ojala is offline Nikolas Ojala  Finland
Nikolas Ojala's Avatar
Thumbs up Empirical formula is OK
Originally Posted by Galu View Post
If you wish to experiment, there is an empirical formula for calculating the total area of the resistive vent.
A = 5.5 x V [0.818 (Fs/25) + 0.182]
Where A is the resistive vent area in sq in, V is the enclosure volume in cu ft and Fs is the resonant frequency, in Hz, of the driver in free air.
Thanks!
I don't have any problem with the fact that the formula is empirical. Did you find that formula from some other source or did you discover it by your own experiments?
High-order harmonics are more offensive than low.
— D.E.L. Shorter: "The Influence of High-Order Products in Non-Linear Distortion". Electronic Engineering, April 1950.
Old 25th November 2021, 11:15 AM   #22
Galu is online now Galu  Scotland
The formula is from an article by Steve Hutton published in the December 1974 issue of Hi-Fi News & Record Review.
Old 25th November 2021, 07:40 PM   #23
During the 1960s, and continuing into the 1970s and 80s, a great many DIY speaker designs were published in the UK hi-fi press.
One of the DIY designs which appeared in Hi-Fi News was Steve Hutton's “Inexpensive Reflex Speaker” (December 1971) - so he did have some experience in the field.
Old 26th November 2021, 04:09 AM   #24
IG81 is offline IG81  Canada
IG81's Avatar
Here's a pair of Philips AD7060/M8 in aperiodic enclosures I built in 2010. The vent was glasswool sandwiched between guttermesh.
Here's the impedance sweep of an aperiodic mid-TL I made for a Fostex FF85WK. I did not implement this into a build, but did it for fun as well as to learn.
  Reply to this post
Show your aperiodic speakersHide this!Advertise here!
Thread Tools
Aperiodic boxes with aperiodic TL's - an idea. Shoog Full Range 9 29th November 2020 12:30 AM
What can measurements show/not show? jkeny Everything Else 137 9th August 2010 01:31 PM
show off your sub! paulspencer Subwoofers 0 30th September 2003 10:24 AM
Show us your works in progress jwb Everything Else 31 19th April 2003 06:06 PM
Show of hands for the Montreal Sound and Image Show (Le Festival Son & Image) alvaius Everything Else 2 28th January 2003 06:48 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
