Thread Tools
Old 18th September 2021, 05:10 PM   #1
ggidzinski is offline ggidzinski  United States
ggidzinski's Avatar
Default Full range mixing “cubes”
I would like to add a pair of full range diy mixing speakers to my editing setup for the usual reasons of good midrange detail and a revealing listen to my mix. Almost every thread that recommends drivers (Fostex, Mark Audio, radio shack ...) turn up no longer in production. I prefer a paper cone driver for this build.
What do you recommend that is currently available?
Thanks,
George
Musician since 1961, fell in love with audiophile equipment in 1969 when I first met the mesmerizing blue glow of a vintage McIntosh and JBL L300’s. DIY fever started in 1978 watching a pair of Klipsch horn’s being built in a garage.
Old 18th September 2021, 05:21 PM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
My first recommend would be the MArk Audio P7HD. Not paper thou.
A bit larger, if you can find it would be the Alpair 10p which is paper.
I am pretty sure were there is a pair of A10PeN in Ontario in a closet.
dave
Stay safe. Stay home. Respect the 2m bubble.
Old 18th September 2021, 06:55 PM   #3
waxx is offline waxx  Belgium
I would say the CHN110 is a good driver like that. Just like the P it's not bright, and it gives a good detail, more than the original in my impression (i know the original, but did not put them side by side). In a 12L sealed (the original cubes were closed) you got a good response to 60Hz.
The 10P is also good, but hard to find these days in the US i hear (but here in Europe common availeble). The low response will be less altough but the case can be smaller if that matters (70Hz F6 in 9L).
If you want to stay close to the original, you need a 5" high qts low xmax paper cone, something like the Visaton WS 13E. But that won't sound detailed or good and will roll of at 100Hz down and 10kHz up, just like the original (5" CTS SR10-8 driver) didn't. It was used at that time to check how it sounded on cheap bad sounding systems.
Old 18th September 2021, 06:59 PM   #4
frugal-phile(tm)
planet10's Avatar
Yes, forgot about CHN-110. A really good driver and not that expensive,
-chn-110-sealed-png
Looks like about a 10 liitre sealedbox for max flat response.
dave
Old 21st September 2021, 03:07 PM   #5
ggidzinski's Avatar
Has anyone tried the GRS 4FR-8, it’s a replacement for the original Pioneer driver used in the Auratone cubes? It’s a low cost driver but some reviews claim that it’s a faithful reproduction of the Pioneer original.
This project has me torn between my usual quest for high quality drivers like Seas et al and something more faithful to the original in this case which apparently is a low price point.
George
Old 21st September 2021, 04:35 PM   #6
frugal-phile(tm)
planet10's Avatar
Don’t know about the 4”. but the 8” replacement is a poor substitute for the BOFU.
dave
Old 21st September 2021, 05:00 PM   #7
George
The original is not the pioneer. That driver was only used later when the original CTS SR10 became unavaileble.
Old 21st September 2021, 05:30 PM   #8
frugal-phile(tm)
planet10's Avatar
The CTS was also used in the original EPI microTower.
Look to the drivers used in modern implementations for suggestions for your small sealed box.
dave
Old 21st September 2021, 10:39 PM   #9
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Check out the Dayton PA130-8. Inexpensive, sounds wonderful and has great sensitivity. A very under-rated driver IMO. Looks are bit rough and industrial.
Also, TB W5-2143 are excellent. Great bass and smooth mid and pretty high reach. Pretty to look at too. A bit more expensive though.
XRKaudio Store // Manufacturer’s Forum
  Reply to this post
Thread Tools
the size of bose cubes....ideas damianl Multi-Way 3 3rd September 2007 03:51 PM
The Magic of Sugar Cubes lgreen Everything Else 7 25th June 2007 05:00 AM
Carver Cubes & Subs Thatch_Ear Multi-Way 4 29th March 2007 06:46 AM
Bose acoustimass cubes impedance? ssanmor Multi-Way 9 13th February 2007 03:34 AM
Adding extra cubes to bose acoustimass 5 Donna Multi-Way 4 3rd April 2004 02:22 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
