Desktop speaker with Markaudio Alpair 5.2
Thread Tools
Old 9th May 2021, 07:05 AM   #11
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Just so: the Gen3 unit is the Gen2 with a copper VC replacing the CCAW coil . Created at the behest of the Japanese distributor and his listening group of friends, who apparently felt a copper coil provided a more consistent tonality across the range. It didn't result in a significant parameter or FR shift, so they're drop-in replacements.
Nice job with the design BTW.
www.wodendesign.com (commercial site)
www.frugal-horn.com www.frugal-phile.com (community sites)
Old 9th May 2021, 08:24 AM   #12
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
thanks for the compliment, and thanks for the info re the gen3.
Old 9th May 2021, 09:34 AM   #13
Henkjan's Avatar
in the below schematic the 666uF for the HP is not indicated, to be "inserted" close to the driver. btw: while the exact value of this cap can be varied based on yr own listening, don't omit it, it is an essential part of the concept
Originally Posted by Henkjan View Post
the next step was to translate this into a passive filter. an LR series with a single LCR shunt should be able to do the job. sims gave an inductor of 0.56mH and resistor of 2.2 ohm for the BSC and an LCR of 1.8mH/10F/3R0.
so soldering iron was heated and listening again. the bass sounded a bit on the heavy side now. so time to experiment with some of the values in the LR. The resistor was OK, but varying the L value (see the graph for simulated changes) made quite a difference: yes even changes small as 0.5dB are very audible. the 0.56mH coil made the bass too thick, the 0.39mH resulted in lack of warmth, the 0.47mH was just right.
after a couple of hours I decided on the 0.47mH inductor.
so the final filter is:
note that R1021 represents the sum of the actual resistor and the dc resistance of the coil.
and this is the actual filter (no room for a print or other fancy stuff)
a 14gauge Janzen wax coil for the LR, a thin wire air coil (baked) for the L in the LCR since a high Rdc (2R2) is no problem here
Old 9th May 2021, 12:11 PM   #14
Henkjan's Avatar
Desktop speaker with Markaudio Alpair 5.2-filterschema_final_hp-jpg
Old 9th May 2021, 12:42 PM   #15
Scottmoose's Avatar
666?
Old 9th May 2021, 12:45 PM   #16
Henkjan's Avatar
Originally Posted by Scottmoose View Post
666?
just a coincidence
Old 9th May 2021, 01:30 PM   #17
zman01 is offline zman01  Bangladesh
666uF sounds like a big cap Henkjan...!
Old 9th May 2021, 04:05 PM   #18
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
It is huge. A good poly will coat more than the drivers, ($100.47x2+$28.12 CAD for 2 speakers -> $516 so one will be forced to use a bi-polar).
3 x 180 @ 7.37 + 5.24 -> $54.70 CAD still pricey.
dave
Stay safe. Stay home. Respect the 2m bubble.
Old 9th May 2021, 07:37 PM   #19
Henkjan's Avatar
yes, I have put 3x 220uF bipolar (€4 each) and a 5.6 poly (€3). both size and price made the choice easy.
poly would be better, in my 3 way with the css sdx10 in sealed cab with hp the improvement in bass quality was clear (I had bipolar in the test version, poly in the final)
Old 9th May 2021, 08:48 PM   #20
Henkjan's Avatar
I have used this type before in for example hp part of the midrange
MKP Folien Kondensator Radial 47mF 850V DC Icel MHBS455470KRSD1 47000nF
when it does not say audio, usually prices are lower
Desktop speaker with Markaudio Alpair 5.2Hide this!Advertise here!
Thread Tools
desktop speaker with Markaudio Alpair5 Henkjan Full Range 72 8th May 2021 07:29 PM
A quite simple bookshelf speaker with the Markaudio Alpair 10.3 h_a Full Range 22 8th March 2021 07:30 AM
Markaudio Pluvia 7 vs Markaudio Alpair 7MS. A subjective and objective comparison. Dr1v3n Full Range 31 2nd June 2019 04:27 PM
Ceramic 4.3l Speaker with Markaudio Alpair 10M (aka Unmonday) MosMike Full Range 1 29th April 2019 07:00 PM
Alpair 6p vs alpair 6m vs alpair 7 timreeves Full Range 11 8th January 2013 03:37 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
