The biggest baddest documented design for a 4inch?
Thread Tools
Old 13th April 2021, 04:59 PM   #1
donovas is offline donovas  South Korea
Cool The biggest baddest documented design for a 4inch?
Im trying to build a set of cabinets for my girlfriend using the generic 4" chinese drivers and would like to know what exotic designs are out there thats for squeezing the most bass out of these tiny units. Because she likes bass, lots of it, and i wanna satisfy her ��
Edit: already tried tabaq and fh3 in the past and tho theyre great i'd like to build something different
Old 13th April 2021, 05:09 PM   #2
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
You'll want more than 4 inches then.
jeff
Old 13th April 2021, 05:22 PM   #3
Hahaha.
Thats the biggest baffle width she wants. So i guess the rest is up to length
Old 13th April 2021, 06:07 PM   #4
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
When you say 'the generic Chinese drivers' which are you referring to? There are quite a lot of them out there, and they are not all created equal.
www.wodendesign.com (commercial site)
www.frugal-horn.com www.frugal-phile.com (community sites)
Old 13th April 2021, 07:50 PM   #5
PJN is offline PJN  United States
Try a cornu spiral horn, look for the thread here in the fullrange forum. Lots of fun, can be hung on a wall, can be disguised as art work, and can deliver surprising bass out of a small driver. Also cheap to build.
Old 13th April 2021, 09:52 PM   #6
chris661 is online now chris661  United Kingdom
chris661's Avatar
Hahaha.
Think I'd aim for as much cone area as possible. Can you mount woofers on the side of the cabinet?
Chris
Bits of information and other things I've worked on: https://www.grimshawaudio.com/lab
Old 13th April 2021, 10:02 PM   #7
zman01 is offline zman01  Bangladesh
donovas,
There is a design called the BiB = Bigger is Better!
However, 4 inches as a driver will have limitations, whatever the make or brand.
Given the labor and time you will probably end up investing in the project, probably better to get a set of better drivers and embark on the project.
I have read that the double mouth horns designed by Scottmoose can extract a good amount of low frequency performance from a 4" or 5" driver. You may want to look up the "Maeshowe" and "Silbury"; however you will need to use the drivers for which the designs are intended for, and a generic driver is not likely to work.
Old 13th April 2021, 10:12 PM   #8
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Cornu spiral horn has the largest expansion ratio for a BLH. Hence most bass-bang for the buck. Most of the time people have to attenuate the bass with stuffing in order to balance with the mids and highs.
Cornu with 4in driver is basically a 28in x 28in x 5.5in deep “pizza box”. As PJN said, they can be covered with printed cloth and hung in a wall like artwork. Very easy to get past the significant other without dominating floor space.
The bass is wide deep and surprisingly powerful.
Each driver is connected to 4 radially expanding spiral horns:
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 14th April 2021, 01:22 AM   #9
perceval is offline perceval  Taiwan
perceval's Avatar
Since we have no idea which driver we are talking about, it's quite hard to make meaningful suggestions.
Would need TS params.
If the driver has a Qts close to 0.5, it might work in a TABAQ, which always gives me the most satisfying bass experience from small drivers.
Old 14th April 2021, 01:28 AM   #10
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Cornu uses the wall to extend a significant sized horn, but they do need to mount on the wall.
The biggest documented enclosure for a 4” would be Maeshowe. But it is fairly specific to get optimum response. A big horn that also uses the wall (or corner) to extend the horn.
Without knowing more about your drivers it would be a crap shoot, a big build, and serious money (compared to the cost of your driver), which could well make for more sense to get more suitable drivers.
If 4” as wide (internal, and that is tight), then a woofer could be mounted side firing and the FR as a midTweeter. Or load the FR into a small bo and add a couple small woofers tucked away somewhere or otherwise disguised.
An example of side mounted woofers (actually one on each side, so why a bit fatter than i think you want)
dave
Stay safe. Stay home. Respect the 2m bubble.
The biggest baddest documented design for a 4inch?Hide this!Advertise here!
Thread Tools
FS: 2 x Peerless P830855 4inch + 2 x Peerless WA10 b_force Swap Meet 2 25th December 2019 07:53 PM
The Biggest (siz), the Loudest (dB), the Lowest (Hz), the Baddest DIY SUB of them all NorthStar Subwoofers 125 17th November 2014 12:26 AM
4inch to 3inch Speaker Replacement Fill javy Full Range 4 29th September 2014 02:27 PM
FS: Sony 4inch vintage alnico speakers MichaelPublic Swap Meet 2 3rd August 2007 06:29 PM
4inch fostex hacknet Multi-Way 23 23rd September 2004 01:43 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
