Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
Hi all,
I have cabs Lowther Bicor 2000, which requires two Lowther 8" speakers each. How should wiring look like? Simply parallel connection without crossover? |
#2 |
Cool cabs.
Assuming the Lowthers are 8ohms each and your amp is ok with a 4ohm load I would think that was fine?
Irishman downunder |
#3 |
I have Leak Stereo 20, which sounds very nice with my Lowther Mini Acousta PM6a. My second amp is HEATHKIT W-5m, which also plays good with Lowther, but IMO its better performance is with JBL-like speakers (I have a pair of JBL LE8T). BTW it is interesting that Leak 20 doesn't match JBL LE8T, the sound somewhat lacks flavor.
So returning to the Bicor question. The cabs go without wiring, only banana connectors are included. Should I make something like this? Sorry for the pic, I'm not an engineer. Should I switch my amp in the 4 ohms mode to use Bicor 2000? |
#4 |
Unfortunately I have no experience with those amps maybe someone else can chime in but if the amp has a 4ohm mode well then that certainly sounds promising for compatibility.
Your picture looks fine to me, when I've done this in the past I just had one set of wires going to one driver and then daisy-chained off that to the other. It might be interesting to bi-amp the speakers if you put in another set of banana plugs.
#5 |
Thank you!
#6 |
Series of parallel can be done. In series the impendance will be nominal 16ohm, which is no issue for any amp, but the amp won't give the full volume. In parallel the impendance will be nominal 4 ohm, which is no issue if your amp can drive 4R speakers. I don't know if the Leak can do that, but if it could, it may be the best solution.
#7 |
You could try contacting Contact | Lowther Loudspeakers
#8 |
I followed the advice and asked at lowtherloudspeakers.com. Martin Thornton from the Lowther team kindly answered me that, firstly, the parallel connection (as on my pic) is indeed an appropriate solution. Secondly the output will be either 15ohms (for two paralleled 15ohms speakers) or 8ohms (for two paralleled 8ohms speakers).
#9 | |
Using those nominal values: 1pr of 8ohm drivers wired in parallel = 4ohms 1pr of 8ohm drivers wired in series = 16ohms 1pr of 15ohm drivers wired in parallel = 7.5ohms 1pr of 15ohm drivers wired in series = 30ohms
www.wodendesign.com (commercial site) www.frugal-horn.com www.frugal-phile.com (community sites) |
#10 |
Yes, I guess it was Martin's accidental mistake.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Anything Beyond The Bicor 20 for the Lowther DX55? | Karl71 | Full Range | 23 | 22nd October 2018 02:40 AM |
Bicor Horns | Zero D | Subwoofers | 3 | 26th January 2017 11:01 AM |
Ideal filter for two way speaker system | tigox | Multi-Way | 22 | 26th June 2014 01:38 PM |
Lowther in a two way? | magnetman | Multi-Way | 8 | 1st September 2012 06:02 AM |
Converting two 2-way crossovers two one 3-way crossover - possible? | vshvsh | Multi-Way | 1 | 11th December 2010 09:27 AM |
New To Site? | Need Help? |
