DIY audio accesarry for full-range driver
Thread Tools
Old 23rd July 2021, 02:35 PM   #21
Andrewbee is offline Andrewbee  Jamaica
Thank you Nandappe.
None of us are leaving this world alive. Enjoy it responsibly as you may.
Old 23rd July 2021, 04:35 PM   #22
jjasniew is offline jjasniew  United States
jjasniew's Avatar
My next effort is to try them (my small collection of FRs) boxless - OB. I'll need low frequency support for that, which I'm hoping to supply with a pair of 18s in H frames. I'll need Xover for that, which will probably come from a second Zoudio amp and its integrated DSP. I'd like to do it at speaker level with passive, but the inductor is costly, I assume.
I think that by using the drivers rear radiation to enhance the spatial presentation, while simultaneously crossing it so it doesnt have to make any bass at all, may be a good way to go. I can only build it and see!
Joe Jasniewski - PC>ZOUDIO AIO4CH> OB Lii Audio F15s w/ 18" assists.
Old 23rd July 2021, 09:05 PM   #23
GM is offline GM  United States
GM's Avatar
Put an acoustic low pass filter on it.
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 23rd July 2021, 10:40 PM   #24
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
From what i glean from the first post a subject similar to Bud’s grounding thingies. Can’t remember what they are called.
dave
Stay safe. Stay home. Respect the 2m bubble.
Old Yesterday, 09:31 AM   #25
Macfixer is offline Macfixer  United Kingdom
Groundside Electrons
was it these
ACA aleph J DCB1 Alpair 10P
Old Yesterday, 05:09 PM   #26
frugal-phile(tm)
planet10's Avatar
Yes, thanx for the link.
dave
Old Today, 02:29 AM   #27
jjasniew's Avatar
Originally Posted by nandappe View Post
Virtual ground for Full-range speakers.
Using brass scrubbers (kitchen items).
It reduces the miscellaneous taste and increases the transparency.
Could a similar effect occur using, say, a copper sheet adhered to the back and bottom square area of the speaker cabinet, connected to the (-) terminal?
Just trying to think of something with close to the same surface area, but having a more reliable electrical connection (solder).
Perhaps with the jar of metal scrubber, using a large alligator clip then filling the jar with oil - it would never have an electrical contact issue. My friend used to show off a jar full of machined brass chips in clear oil - they looked like gold for years!
Old Today, 08:25 AM   #28
nandappe is offline nandappe  Japan
Dear jjasniew,
I tried 0.4mm and 3mm copper plates, but the high density brass scrubbers gave better sounds.
And I don't use oiled scrubbers, because it will be difficult if the bottle breaks.
  Reply to this post
DIY audio accesarry for full-range driverHide this!Advertise here!
Thread Tools
full range + woofer OR full range + tweeter ? Bigun Full Range 63 30th July 2020 05:46 AM
Max practical driver size for full-range driver line-array? canonken Full Range 7 16th June 2020 05:26 PM
Full range driver as a wide range tweeter. midrange Multi-Way 49 23rd April 2015 06:32 AM
Driver Suggestions for DIY Full Range Monitor?? masterhifi Full Range 0 23rd September 2004 08:05 AM
First DIY Single-Full-Range-Driver Help Needed GregGC Full Range 19 24th February 2004 06:13 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
