Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
... the dodecahedron..
dodo stand.jpg Not often i get to post a build in full range ![]() Eleven 4fe35's on all the faces except for the bottom face, which has the pole mount and four 2" diameter vent ports. Has strong response down to 60Hz...time to play with port length etc. Put a quick and nasty tuning on it...kinda suprised how decent it sounds. And I've truly never heard anything so even anywhere/everywhere in the room. Time will tell, work to do.... |
#2 |
that's it...i'm selling my woodwork tools and i'm going to take up knitting...all my projects wind up looking like industrial Frankensteins !
seriously nice work! if they "fill" the room is there a point or reason for a second for stereo? |
#3 |
Got Foam?
Beautiful woodwork Mark! Can you share build photos of the insides? How is it wired with 11 drivers?
XRKaudio https://www.etsy.com/shop/XRKAudio |
#4 |
Speakerholic
Nice work Mark.
http://www.calweldonconsulting.ca/ |
#5 |
Beautifully done Mark.
![]() I'm surprised that you are getting 60 Hz out of the 4fe35 driver. Well done.
Take the Speaker Voltage Test! |
#6 |
Oh Wow guys, thanks for all the kind comments...!!!!!
Like said, just fired her up...will post details, meas, wiring etc, asap |
#7 |
Wow. The work and dedication to make that is truly remarkable. Kudos!
#8 |
My college roommate and best friend for a time got his ME Masters working with a speaker like that. He used it as an omni sound source to measure sound attenuation over snow, grass, blacktop. It used these Altec speakers with little aluminum dust caps. I remember he said it was omni up to a certain point, then it "beamed". Probably early 80s, AFAIR.
Nice work! What will you use it for?
Joe Jasniewski - PC>ZOUDIO AIO4CH> OB Lii Audio F15s w/ 18" assists. |
#9 |
weird I have been thinking omni as well but in the opposite direction using only one small Tannoy DC driver firing up and then play pool with the top end reflections to achieve best results at my seating location. early experiments doing this with a Revolution XT Mini have resulted in impressive stage and image with a realism I have not achieved with direct radiation. not at all an intuitive result but what ever works is good for me.
moray james |
#10 |
Nice, mounting everything on the inside you don't have to expose the ugly rabbit ears...
Oon |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Semisouth goes Dodo ; what now ? | Zen Mod | Pass Labs | 286 | 13th March 2021 05:54 AM |
Krell KAV 250a deader than a dodo | digitallake | Solid State | 70 | 12th July 2017 09:33 PM |
Will DIY audio go the way of the dodo? | majerjack | The Lounge | 41 | 14th September 2014 06:20 PM |
New DODO Case coupon code | nightrider0614 | The Lounge | 0 | 7th October 2012 08:18 PM |
Glad to Meet Everone | haldor | Introductions | 0 | 17th August 2001 12:24 AM |
New To Site? | Need Help? |
