New Lii Audio 18" beast
Thread Tools
Old 20th January 2021, 09:58 AM   #1
peppennino is offline peppennino  Italy
peppennino's Avatar
Default New Lii Audio 18" beast
One Pair | 18 Inch Full Range Speakers | Superb Scale Soundstage with New Imaging | F-18 - Lii Audio, unique speaker, amplfier, quality and cost-saving parts for HiFi DIY
SL-1210 + Jim's PSU + 2M Blue | 834P TRLH | UBP-X800 + DDE3.0 | PassDiy B1R2 | Inca Tech | Diy Pi 4
Old 22nd January 2021, 09:37 AM   #2
Soundhappy is offline Soundhappy  France
Soundhappy's Avatar
Huge magnets, cost more money.
Make this 18" driver with 5x time stronger = bigger magnet (minimum)
and this will be starting very interesting performance.
class A amplifiers with full range speakers
sings like angels in heaven
Old 22nd January 2021, 10:38 AM   #3
Stixx is offline Stixx  Germany
Stixx's Avatar
This driver apparently was build for use in an open baffle... so small magnet = high Qts (0.94).
Also the weight of the cone and voicecoil is only 45 grams... extremely low for a 18"????
www.original-ton.net
Old 22nd January 2021, 11:10 AM   #4
peppennino's Avatar
Yes, I think the use is intended for OBs...
Old 22nd January 2021, 08:23 PM   #5
mp9 is offline mp9  United States
Do you mean like the magnet Lll Audio put on the Crystal 10 and its replacement the Silver 10?
Btw, anyone know if the 10's magnets are Alnico? Looks like it could be but no mention on the website.
Also getting back to the 18, the surround looks to be an accordion folded paper like a continuation of the paper cone and with a coating?
Again no mention on the site if the surround is paper, foam, or textile.
Old 22nd January 2021, 09:21 PM   #6
waxx is offline waxx  Belgium
To be honest, i don't see the advantage of this kind of big fullrange drivers. There are drivers that are much better quality that are smaller and more efficient, and much cheaper. But 18" must mean a lot of beaming in the high frequencies. I would like to see some independent measuring on and of axis with good results before i would consider these...
Old 22nd January 2021, 09:43 PM   #7
Soundhappy's Avatar
Btw, anyone know if the 10's magnets are Alnico? Looks like it could be but no mention on the website..
Better make 18" with small size but super strong neodymium magnets
Old 22nd January 2021, 10:18 PM   #8
freddi is offline freddi  United States
freddi's Avatar
It should be a nice speaker for those who want a coherent sound and some "bass" with an open baffle.
I'd love to see tradeoffs in response and smoothness of increasing motor strength to say qts-0.31 on this and Fane's 12-250TC. (Are there any speaker engineers at Diyaudio who would lend some insight?)
Old 23rd January 2021, 03:05 AM   #9
- and lighter weight too but also the most expensive magnet option available.
Old 23rd January 2021, 08:40 AM   #10
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Actually, short of a semi-custom type (which tend to be expensive due to economies of scale) a high grade AlNiCo is usually the most expensive to purchase. It's also usually the trickiest, and therefore most costly, to implement when high flux densities are desired in the VC gap due to the physical configuration -AlNiCo has some specific requirements in that regard which is one reason many drivers using it these days have relatively weak motors (in addition to usage requirements and marketing purposes).
www.wodendesign.com (commercial site)
www.frugal-horn.com www.frugal-phile.com (community sites)
  Reply to this post
New Lii Audio 18" beastHide this!Advertise here!
Thread Tools
Lii audio fast 10 paulfk Full Range 2 18th January 2021 04:21 PM
Lii Audio 15" full range jjasniew Full Range 363 15th January 2021 07:00 PM
My first build - Lii Audio and ESS Heil AMT? Hawkeye83 Multi-Way 7 21st February 2020 12:42 PM
Lii Audio Fast-8 yatr98 Full Range 2 1st January 2020 04:56 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
