QTS Method vs EBP for Full Range TangBand
Thread Tools
Old 23rd January 2021, 10:47 PM   #31
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Good point (like that needed saying ). I hold my hands up: I ended up learning that one the hard way. The B20 in question did not survive the experience. I'm not proud of it -you taught me better than that. On the other hand, it was a lesson I won't forget in a hurry, so on the whole, a positive...
www.wodendesign.com (commercial site)
www.frugal-horn.com www.frugal-phile.com (community sites)
Old 24th January 2021, 02:19 AM   #32
GM is offline GM  United States
GM's Avatar
Yeah, learned most of what I know the hard way too . A shame I didn't have 'second sight' as many of the drivers would be quite desirable nowadays on this forum.
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 24th January 2021, 10:19 AM   #33
Scottmoose's Avatar
Yeah, I think we'd all like one of those crystal balls from time to time.
I saw a pair of NIB 1354s go the other day for over $100. I may weep.
Old 24th January 2021, 05:07 PM   #34
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
$100? Nuts.
I think i gave my last pair away. I got a whole bunch in the end days for $5 each.
A good driver, but…
dave
Stay safe. Stay home. Respect the 2m bubble.
Old 25th January 2021, 03:13 AM   #35
GM's Avatar
Originally Posted by incredible80 View Post
P.S. I attached the driver files obtained via TangBand
What is Sd? 3.2 mM means millimeter to me, but can't be right, though 32 cm^2 seems about right, so curious if this is a typo or LMS wrong? [I find this hard to believe]
Old 25th January 2021, 06:09 PM   #36
norman bates is offline norman bates  United States
norman bates's Avatar
32 cm2 is a squeak bigger than me than a 3” driver (usually 27cm2).
Old 25th January 2021, 08:08 PM   #37
GM's Avatar
OK, thanks, but before posting I looked at a few different TB W3 drivers and 32 cm^2 was the norm, lining up with the '3.2 xx' spec and 27 cm^2 for 'sub' woofers. When I get HR updated I'll plug in the LMS specs to see what's what.
Old 25th January 2021, 08:14 PM   #38
frugal-phile(tm)
planet10's Avatar
My 2 favorite 3s (Alpair 5.2/3, FF85wk) are both 28 cm2.
dave
  Reply to this post
QTS Method vs EBP for Full Range TangBandHide this!Advertise here!
Thread Tools
Would it be okay to mix Low qts and high qts of the same sub? icecreamxd Subwoofers 7 4th December 2013 09:00 PM
what sounds best . . . Low Qts in small cab or higher Qts in bigger cab mikelm Subwoofers 18 15th July 2009 11:46 AM
EBP and QTS horus Multi-Way 27 2nd January 2007 01:29 AM
What if instead of a speaker with a Qts=1 I use a different Qts?? Tuliman Multi-Way 2 14th December 2004 12:54 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
