Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
#81 |
Light weight cone and voice coil mean less mechanical vibration transmitted to the enclosure, but it's more likely that any phase issues are at the frequency extremes, rather than right in the middle, no one seems bothered by the ( possible ) phase issues of signal transformers, and they're the same. Just have a small full range augmented by a bass driver coming in at around 150 Hz, best of both worlds.
The truth has a quiet voice, and I feel alone in having the ears to listen. |
#82 | |
#83 | |
For comparing various sources, an identical test signal (in this case, the same speech track) and EQ to approximate the same frequency curve are also necessary. In the absence of controlled tests with multiple experienced listeners, it's unlikely that any person can definitively say that "fullrangers are more intelligible" than something else. I've observed that well-designed multi-way loudspeakers will not only equal a "fullranger" in an intelligibility test (using SII or other standard), but also outperform it in many other areas which are relevant to high quality sound reproduction or reinforcement. The issue is not "fullrange" versus "multi-way". Rather, it's the quality of the design, and the intended application. |
#84 | |
#85 | |
#86 |
Location: Wilsonville Oregon, Corvallis Oregon native (You can't lick our beavers!).
Not true. My Audio Nirvana 12s have plenty. And driven off a 7 watt 300B set. if I have the right tubes in it.
I know this was tongue in cheek but its really true. my 12s have great bass. granted the boxes are huge but they sound nice.
Jwags818 - Wilsonville, Oregon D50s - 300B/D3A SET - 12in Audio Nirvana Speakers |
#87 | |
frugal-phile(tm)
dave
Stay safe. Stay home. Respect the 2m bubble. |
#88 |
frugal-phile(tm)
F3 is s useless number to humans (Toole), best to look at F6 and F10.
In room you are probably getting useful response into the mid30s. dave
#89 | |
frugal-phile(tm)
The ones i had (Quad 57 and Accoustat) were 2 ways. I even passive bi-amped the Accoustats. dave
#90 |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Tesla Fullrangers.... | JandG | Full Range | 9 | 31st July 2008 06:23 AM |
Is there such thing as filter free Fullrangers..?? | JandG | Full Range | 26 | 3rd December 2006 07:01 AM |
a new system based on Fullrangers- PC or CD player | T11 | Digital Source | 4 | 6th October 2006 03:43 PM |
Questions of OB bottom help w/ fullrangers | JandG | Multi-Way | 1 | 19th August 2006 03:24 AM |
diy fullrangers in oklahoma? | big_kahunah | Full Range | 3 | 23rd June 2006 10:06 PM |
New To Site? | Need Help? |
