microTower Revisited
Thread Tools
Old 21st January 2021, 06:12 PM   #101
cogitech is offline cogitech  Canada
cogitech's Avatar
I don't own a router. I though about something similar, but with inset magnets. Never got past the thinking stage. Moved on to other distractions.
The plastic covers will do the trick for the foreseeable.
Old 21st January 2021, 06:29 PM   #102
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by cogitech View Post
Save the plastic protective covers...
They are not very good plastic covers, i would be careful with them and i expect use will cause them to die.
dave
Stay safe. Stay home. Respect the 2m bubble.
Old 21st January 2021, 06:34 PM   #103
frugal-phile(tm)
planet10's Avatar
Originally Posted by Bigun View Post
I’d suggest using a router to create a small rebate / ditch in a square shape, set back from the edges and fashion a grill cloth to sit on top with the cloth fixed to a square frame that simply drops into the routed slot.
I have a box full of metal mesh circular grills, we have use dthem for SDX7, SF W14 & A10. Anyone wants some i’d hate to toss them in the metal recysle.
Here on the W14 on the sides of Tysen V2 (now veneered [and for sale])
dave
Old 21st January 2021, 06:40 PM   #104
cogitech's Avatar
A nice offer, Dave. The dust and whatnot will go right through them, no?
I plan to be very gentle with the plastic covers, for now.
Old 21st January 2021, 06:42 PM   #105
frugal-phile(tm)
planet10's Avatar
Dust blows off, finger pokes or an errant drinking glass do not.
dave
Old 21st January 2021, 06:51 PM   #106
cogitech's Avatar
Worse than dust is cooking fumes. Our kitchen is right next to our living room.
The top EL70s eventually collected enough to become slightly tacky, which the dust loved to adhere to. Blowing was insufficient. Physical contact was required. This bugged me. The metal grilles would not do the trick for this issue.
I suppose the real solution is metal grilles on the top drivers, plus a cloth grille/frame for the top and sides (like the cloth covers in the sample photos in the microTower PDF).
Old 21st January 2021, 06:55 PM   #107
frugal-phile(tm)
planet10's Avatar
The box from those photos is downstairs :^)
Cooking fumes are a problem. With the paper EL70 they will penetrate the cone, the metal cones can (very) carefully be wiped does with 9% isopropanol. Much better to not have to do it at all.
dave
Old 21st January 2021, 06:55 PM   #108
von Ah is offline von Ah  United States
von Ah's Avatar
Here’s what I’ve done for 10 years:
Magnet attached grilles for MA drivers, good or bad idea
I considered the steel plus fabric idea back then, but never made it happen.
Old 21st January 2021, 07:01 PM   #109
cogitech's Avatar
I like that solution, von AH.
Upon seeing closer photos of your microTowers, it looks like the driver holes/rebates are perfectly sized for your drivers. I suspect there might not be enough room there to easily slide the plastic covers on. Although it is basically irrelevant because you have a protective solution already.
Old 21st January 2021, 07:12 PM   #110
cogitech's Avatar
I'm thinking about this more and I think you metal mesh guys are right. Lots of good points made in that old thread.
Dave, are the "A10" grilles for Alpair 10? Would there be a way to utilize them with P7 without it looking ugly?
microTower RevisitedHide this!Advertise here!
Thread Tools
Castle Microtower build zman01 Full Range 39 17th May 2020 08:59 PM
microTower bipolar ML-TL for CHR-70 or EL70 planet10 Full Range 665 31st May 2019 07:13 PM
newbee question regarding microtower stevros Full Range 2 16th August 2011 05:05 PM
Looking for Baltimore-DC Area carpenter to build EL70 MicroTower cabinets von Ah Full Range 70 18th July 2011 09:26 PM
Prices on Pensil cabinets and microtower cabinets TWills Planet 10 hifi 9 31st January 2011 03:21 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
