Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
Does anyone know of any builds that would work with a Visaton FRS8 as a full range single driver computer speaker? Thanks
#2 |
This driver is not really fit for a single driver system, you won't have any bass (with 0.3mm xmax) at all. But a 2L sealed can go to 150Hz (F3) on low power.
For this. better look at smaller fullrange with at least some xmax and a good response at least to 100hz from as example Tangband or Mark Audio drivers for this kind of thing. I thought there were some valid designs from Planet 10 that could be used as smaller computer speakers. |
#3 |
There are quite a few around though not too easy to find as most of them can be found in german diy forums where the drivers originate from.
You could search for "frs8 fast" or similar and will find people use it similar to other 3" fullrange drivers (Tangband, Fostex etc.) so mostly with an assisting woofer. There is even an official "kit" from Visaton, the Stella light: STELLA LIGHT | Visaton But thatīs not exactly what you want and Iīm with Waxx here: Those 3" fullrangers will quickly run out of steam, even nearfield. You could try 1.5-way and use two of them or get a cheap 2.1-amplifier with built in crossover and built a nearfield-sub to go with them. It all depends on your listening levels as well. I was quite happy with some Tangband W3-871S as desktop-speaker but I donīt listen very loud. Die Kiste | kwerl acoustic http://www.hifi-forum.de/viewthread-267-897.html Last edited by joensd; 28th November 2020 at 12:20 PM. |
#4 |
I own Visaton FRS8M in a MLTL enclosure (12,5 cm x 27 cm x 43 cm). As the comment #2, I agree that they don't have "real low frequencies/bass". However, if they are placed in the corner, you can "perceive low frequencies/bass" to some degree. In my 18m^2 room they are not that bad, but I'm not sure if I can recommend them in this exact setup.
And now to the "day dreaming" part. In my case I own H-class amplifier, which is not a good choice for powering these speakers. With an amplifier that is oriented toward more quality of sound, you might even get more "perceived low frequencies/bass". |
#5 |
#6 |
Google translate does a reasonable job on them, manually or via an auto facility like Firefox's (lesser browsers are available
www.wodendesign.com (commercial site) www.frugal-horn.com www.frugal-phile.com (community sites) |
#7 |
I have a new pair of FRS8's sitting around, not the FRS8M. My nephew is asking for Creative Pebble speakers for Christmas. I thought that I might find something to improve upon his choice. Hoping for something like a single driver Audioengine A2 build.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Finally built a prototype, dual FRS8 in pentagon-TL | ßart West-VL. | Full Range | 32 | 27th June 2011 08:36 PM |
Visaton frs8, frs8/m with cyburg ? | Redge | Full Range | 12 | 15th January 2011 03:59 PM |
Visaton FRS8 8ohm or 4ohm to choose? | hellmis | Full Range | 9 | 2nd July 2007 04:38 AM |
Needles with 2 FRS8 drivers | TDLofCC | Full Range | 14 | 11th September 2006 12:35 PM |
Visaton FRS8 line array & W170S | Miha | Multi-Way | 16 | 4th November 2004 12:24 AM |
New To Site? | Need Help? |
