MAOP 7 in onken enclosure in needs of WAW
Thread Tools
Old 22nd November 2020, 01:03 AM   #11
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
There are many good woofers. What do you have in your closet naca?
dave
Stay safe. Stay home. Respect the 2m bubble.
Old 22nd November 2020, 07:06 AM   #12
naca5 is offline naca5  Belgium
Dave & waxx thanks for your help
actually my closet is empty, so from scratch.
So Dave, you prefer something like a minidsp to pass the woofer (MAOP is untouched if I use 2x Alpair 12?)
I guess the use of a couple of alpair means two enclosures ?
My room (actually my bedroom) is small, around 3*4m but with an interesting ceiling , the best room for music.
My 2 cents, would be easier to start with a new enclosure (FH3?) going lower?
@waxx I've a minidsp UMIK, so I can measure them (need to learn more about that)
Old 22nd November 2020, 07:43 AM   #13
frugal-phile(tm)
planet10's Avatar
My first choice for line level preamp is a PLLXO. Then 1 of the 2 Nelson Pass XOs in the diyAudio Store.
miniDSP is very verstaile but for really good sonics you need to get the 24/96 (still no 24/192) and your own DACs.
If you biamp you don’t have to worry too much about different sensitivities.
dave
Old 22nd November 2020, 07:49 AM   #14
Hum I forgot to mention that I only stream with that setup going directly in a full digital amp.
So minidsp looks better from that point of view isn't it..thus Tidal doesn't offer 24/96 for all records.
I can double full digital amp easily (and cheaply)..how that sounds?
Old 22nd November 2020, 10:16 AM   #15
waxx is offline waxx  Belgium
well, i'm not a fan of those digital amps, but if you like them, a full digital setup can be it. Just remember that if you use the minidsp, the ADC and DAC are their weak points, and for the best setup use external ones. I'm planning a monitor setup with digital out and dsp also, and if i will use minidsp, i'll use the digital only one and get a pair of toppings D30 dac's to do the conversion or so. Those are cheap and very good.
Old 22nd November 2020, 04:38 PM   #16
frugal-phile(tm)
planet10's Avatar
If you are not using any of the analog parts you should be fine, but still i would want at least 24/96 myself. But you have it, try it out for sure.
dave
Old 22nd November 2020, 04:42 PM   #17
will do, thanks again for tips
Old 23rd November 2020, 04:56 PM   #18
Life can be weird, while I was wondering what to do with my MAOP, a friend has just dropped a pair of Cube Magus....well...another project on the way ;-)
  Reply to this post
MAOP 7 in onken enclosure in needs of WAWHide this!Advertise here!
Thread Tools
MAOP 7 with MAOP 11's......? simplesteve Full Range 11 10th September 2020 07:28 PM
Alpair 10 Gen. MAOP Prototype TW-1 markaudio Planet 10 hifi 189 27th March 2019 02:04 AM
Enabling, MAOP on Markaudio drivers markaudio Planet 10 hifi 17 30th January 2015 04:40 PM
Retro Style Airplay Boombox with Alpair 10 MAOP eladmi Full Range 15 9th November 2013 11:33 AM
onken Onken w or A7 or Valencia gunnt Multi-Way 82 12th December 2010 03:20 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
