Hello all
Loudspeaker advice.
I'm converting a GEC radio into bluetooth speaker using the cabinet.
Will be stereo. max 50w/channel @ 4ohms
There are two panels where each speaker or combination (woofer/tweeter) will fit. Size of these panels are 9" high x 10" deep
I want the best sound possible; not interested in bass heavy bull full range.
There was an 8" speaker in there as shown on photos. Cabinet is all wood and I will be making it more rigid.
Any thoughts or recommendations about single speakers or pairs with crossovers and suggestions for make. ? thanks Tom
Loudspeaker advice.
Thanks Tom. Just to narrow down the field regarding speaker choice, do you envisage the radio cabinet being open-back, completely sealed or reflex ported?
What volume do you estimate will be available to the speakers inside the cabinet?
I think good quality 8" full range speakers would present the least hassle regarding fitting into your radio cabinet, but their parameters have to suit your intended method of loading as questioned above.
I'll give your thread a nudge, Tom.
I don't have a firm suggestion as yet, other than to say you'll likely need fairly small drivers in order to match the limited volume available.
1200 cubic centimetres is 1.2 litres which means 0.6 litres is available to each driver.
A frontal photo of the radio cabinet would be nice and would give a better impression of its size.
1947 GEC
image attached. the curved outsides are flat insides. This is getting interesting. Still researching, but I've looked at these and would build suitable crossovers. Buying a SB Acoustics SB16PFC25-4-COAX woofer? - SoundImports
Tom
Tom
Have you considered the T/S parameters of that 6" COAX woofer, Tom?
It needs a sealed box of minimum volume 4.25 litres to be 3dB down at 90Hz.
For reference, the crossover circuit is available here: https://www.madisoundspeakerstore.com/pdf/SBAcoustic_PFC_Coaxial_Crossover_Designs.pdf
You say you don't need heavy bass, so you may be able to bend the volume rules and accept less bass extension.
I would question buying expensive hi-fi drivers though, as more basic full range units may be more appropriate in the circumstances.
I'm not heavily into loudspeaker design, so I hope you get more driver suggestions soon!
well those photo's aren't what i was hoping to see...i take it that the side with the loudspeaker has a cloth between the baffle and grill and the other side is still a mystery as to whether or not removing the panel would access the louver space...the coax is a tad overkill...this is going to be a bluetooth speaker,no? what amp is going to drive it?
is that a harp in the background?
1947 GEC
; feel free to suggest. thanks Tom
Amp is Dayton Audio KAB250V3; yes, a harp (my wife's)...well those photo's aren't what i was hoping to see...i take it that the side with the loudspeaker has a cloth between the baffle and grill and the other side is still a mystery as to whether or not removing the panel would access the louver space...the coax is a tad overkill...this is going to be a bluetooth speaker,no? what amp is going to drive it?
i bet that the curved louvers create a cavity space that may be resonant ,
I bet turk might have been right, as most probably the space between the curved louvres and the flat inner mounting panels aren't filled with anything. Anyway, as it is going to become just another BT unit...image attached. the curved outsides are flat insides. This is getting interesting. Still researching, but I've looked at these and would build suitable crossovers. Buying a SB Acoustics SB16PFC25-4-COAX woofer? - SoundImports
Best regards!
This little BMR driver is designed specifically for compact audio applications such as table radios, wireless speakers and Hi-Fi systems.
It has a diameter of 108mm, a high Qts of 0.95 and is available in 8 or 4 ohm.
TEBM65C20F-4 | Tectonic Round Speaker Driver, 30W nom, >60W max, 4Ω | RS Components
https://docs.rs-online.com/d86c/0900766b816b9923.pdf
- Full Range
- Conversion of a GEC radio 1947
