Open baffle step compensation on fullrange adds distortion
Old 30th June 2020, 08:23 PM   #1
flo777 is offline flo777  Canada
Default Open baffle step compensation on fullrange adds distortion
I followed the design by Rudolf in post #13 below to build a pair of small open baffle speakers
Small open-baffle?
For the baffle step circuit, I could not source a 3.3mh inductor, so I used a 2.4mh instead in parallel with a 12 ohm resistor.
(photo attached)
Adding this to the fullrange driver creates a lot of distortion in the low frequencies (similar to voice coil rubbing).
I tried adding hot glue on the coil, but did not help.
Does anyone know what the issue could be?
Thanks in advance
Old 30th June 2020, 08:29 PM   #2
kaos is offline kaos  United States
Could be coil saturation, try an air-core inductor.
Old 30th June 2020, 08:33 PM   #3
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Small baffle, small driver, bu\ig lift in the bass will certainly mean a big hit on how loud you can go before running out of excursion, so more LF distortion would be expected as you turn up the wick.
dave
Stay safe. Stay home. Respect the 2m bubble.
Old 30th June 2020, 09:07 PM   #4
Thanks for the tips.
The saturation current is rated at 3A.
The LF distortion also occurs at very low volumes.
Old 1st July 2020, 12:00 AM   #5
The core may be rated for 3 amps at 100 KHz but go down to 50 Hz and it could easily saturate at 20 mA. If you have a scope, signal generator, power amp and power resistor (5 ohms will work) it's easy enough to check if the core is saturating at lower frequencies. Connect the equipment in series in an appropriate manner and connect the scope probe across the resistor, when the core saturates you'll see a step in the sine wave. Use Ohm's law to solve for the current that saturation occurs at.
Old 1st July 2020, 01:41 AM   #6
perceval is offline perceval  Taiwan
perceval's Avatar
I tried the cheap inductors like those, along with the cheap capacitors you can get for pennies...
They are ok to test if your calculations were correct, but they introduce a lot of sound distortion and modulations.
Get audio grade stuff and your problems will disappear.
Old 1st July 2020, 07:30 PM   #7
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
Coil and resistor type have nothing to do with your problem!
Rudolf's small baffle speakers were sitting on a desk/table which works as extra baffle, and still response below 100Hz drops like stone. The driver very easily must work too hard and it reaches mechanical excursion limit (Xmech) easily and starts clonking. Even before that there will be rubbing noise from coil/magnet gap in many cases
Guru tells more about it here Tech
Radikal aktivist AINOgradient speaker project
Old 1st July 2020, 09:04 PM   #8
Thanks for the responses.
The inductors are 2.4mh at 15 khz. However, it did not read any value at 1 khz. Maybe the inductors are the problem here?
Old 1st July 2020, 09:27 PM   #9
Maybe something wrong with the inductors, can someone please explain?
1.3mH at 200 kHz
2.3mH at 15 khz
?58H at 1 kHz
Old 2nd July 2020, 01:15 AM   #10
perceval's Avatar
Just sharing my experience on the topic... yes it does.
Using the kind of inductor posted, I get all sorts of sound artefacts while doing a sweep in REW in the lower to midrange.
If I use a real air-core inductor, the artefacts go away.
Open baffle step compensation on fullrange adds distortionHide this!Advertise here!
Baffle step compensation.. how important is it? nannoo Multi-Way 64 17th March 2014 04:23 PM
When to use baffle step compensation? tmblack Multi-Way 28 6th December 2008 12:39 PM
Short TL as Baffle Step Compensation m@ Multi-Way 0 10th March 2008 09:07 AM
Baffle step compensation formula? bart_dood Full Range 4 8th July 2006 10:50 AM
Baffle Step Compensation Khron Multi-Way 4 16th April 2006 08:23 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
