Open baffle step compensation on fullrange adds distortion
Old 2nd July 2020, 09:16 AM   #11
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
Yes that type of coil is not suitable for crossovers.
Anyway the real problem to my understanding is that a small driver is asked to produce low frequencies as dipole.
Baffle step (or actually loss) compensation with a serial coil is 1st order lowpass by nature and it will attenuate mid and high frequency (sensitivity) When the driver is asked to put out "normal" spl fullrange , it is driver to extreme excursion in bass-low mid very easily.
This is main reason why dipole speakers must be at least 2-way with large bass driver(s)
Rudolf Finke's homepage Dipolplus - Alles über offene Schallwände
Radikal aktivist AINOgradient speaker project
Old 2nd July 2020, 02:26 PM   #12
flo777 is offline flo777  Canada
Thanks perceval, for confirming that these inductors are in fact problematic.
And thanks Juhazi, for bringing up the issue of driver excursion.
The distortion I heard was very similar to voice coil rubbing.
I hope that this won't be the case with good inductors, especially since the drivers are 1 m away from me and I won't be listening at loud volumes.
These drivers were also used in OB using a similar crossover (10 ohm and 2mH, instead of 12 ohm and 3.3mH)
OB-5’s | Parts Express Project Gallery
For 4 ohm drivers, I found that this 1st order low pass is 193 Hz for 3.3mH inductor and 318 Hz for 2mH inductor.
Maybe the high/mid attenuation is more due to the 12 ohm resistor instead of 10 ohm, but can it make such a difference to create excursion issues?
Open baffle step compensation on fullrange adds distortionHide this!Advertise here!
Baffle step compensation.. how important is it? nannoo Multi-Way 64 17th March 2014 04:23 PM
When to use baffle step compensation? tmblack Multi-Way 28 6th December 2008 12:39 PM
Short TL as Baffle Step Compensation m@ Multi-Way 0 10th March 2008 09:07 AM
Baffle step compensation formula? bart_dood Full Range 4 8th July 2006 10:50 AM
Baffle Step Compensation Khron Multi-Way 4 16th April 2006 08:23 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
