simple enclosure for Fostex FE-208EZ?
Old 28th June 2020, 09:17 AM   #1
Havoc is offline Havoc
Default simple enclosure for Fostex FE-208EZ?
I made a pair of Bruce V1.2 from the Frugal-horn site (Spawn family). Started it a long time ago but it got shelved when life came in the way. Can't say I'm happy. Very thin sound, bit like a tiny transistor radio in a cavern.
Is there a reasonably simple enclosure for those Fostex speakers so I can at least salvage them into a usable speaker? The enclosure Fostex proposes is a bit a puzzle of all little pieces and I'd like something with less sawing involved. Something like a simple BR?
Old 28th June 2020, 02:19 PM   #2
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
I'm not surprised. Bruce was designed for the FE207E, which had rather different specs. to the FE208ESigma, and for it to work in that enclosure, the latter really needs some series R (or an equivalent high / adjustable output impedance amplifier). The overdamped (low Qt) characteristic is why it's not well-suited as-is to regular vented box loading.
You don't mention what your amplifier is, but if it's a regular voltage source type amp, then with a 2.5ohm power resistor inserted in series, about 13 litres tuned to 67Hz would be OK[ish] near boundaries. If you want more, then assuming about 6.8ohms series R, 44 litres to 44Hz would do, in similar conditions. 8.2ohms series R would allow a Vb = Vas, Fb = Fs alignment, near enough.
www.wodendesign.com (commercial site)
www.frugal-horn.com www.frugal-phile.com (community sites)
Old 29th June 2020, 05:45 PM   #3
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Havoc,
It is worth mentioning that the same resistor trick Scott specifies for a simple reflex should also work with Bruce. I would try that first before venturing towards a new box.
dave
Stay safe. Stay home. Respect the 2m bubble.
simple enclosure for Fostex FE-208EZ?Hide this!Advertise here!
Passive Crossover for Fostex 208ez and T90A WayneAudio Multi-Way 36 20th July 2019 04:24 PM
Kofi Annan in: "Unemployment and The Fostex 208EZ (or 206en)" Kofi Annan Full Range 12 14th July 2014 05:46 AM
WTB Fostex FE167E, FE127E, or any fostex suitable for BR enclosure. juanito Swap Meet 3 12th October 2013 03:04 PM
Disadvantage for place the Fostex 168e sigma into Fostex 166e BLH enclosure ? davidshya Full Range 2 27th January 2013 09:41 PM
fostex 208ez and fostex ft17 h good kombo? almightybozo Full Range 1 24th September 2010 06:00 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
