Single FR on huge OB?
Old 26th June 2020, 09:20 AM   #11
laserscrape is offline laserscrape
So i made quick and dirty baffle from some pine planks for just one of the drivers, a couple of 400x1200mm planks side by side for 800x1200mm baffle.
It has *some* bass, not non-existent bass like the other smaller baffle but not enough either, however much more importantly it sounded absolutely awful on this baffle... so that settles that.
Old 27th June 2020, 12:42 AM   #12
Richard Ellis is offline Richard Ellis  Argentina
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
I think I found just why your down on bass response...I see thirty, ( 30 ) decibels down from 100 hertz, to twenty hertz.
=========================================Rick..... ..
Old 27th June 2020, 01:28 AM   #13
OllBoll is offline OllBoll  Sweden
There is a good reason almost none is building single driver OB speakers. Most are using some kind of woofer support like the slot-loaded-open-baffle.
If I plug the math into calculations I got from Linkwitz Rileys dipole max-spl spreadsheet we have 20cm3 displacement for the alpair 7p. Even with a 800 mm wide baffle with a fequal of 120 hz (dipole spl = monopole spl) the max spl at 100 hz is 91 dB @ driver xmax.
Thats not a lot, and that is with excessive 800 mm wide baffles.
The driver would perform a lot better if you highcrossed it at 200 hz or higher given a ~ 300 mm wide baffle and used woofers to cover below. Probably closer to 250-300 hz if you want to use a smaller baffle.
Old 27th June 2020, 02:11 AM   #14
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
If you put the A7p in an infinite baffle it will have a system Q = Qts = 0.5. This is a bit lower than most prefer. A little EQ will help but it is a 4” driver with limited excursion so quantity will be limited.
There are few drivers that will produce decent bass in a (large) OB without EQ. In my experience the VIsaton B200, an Omnes 8” and a Korean-made 6.5” that was specifically made for OB. At one diyFEST we constructed a 16’ wide OB and the bass was staggering… probably a bit over the top.
Single FR on huge OB?-diyfest-16foot-ob-jpg
dave
Stay safe. Stay home. Respect the 2m bubble.
Old 27th June 2020, 02:23 AM   #15
norman bates is offline norman bates  United States
norman bates's Avatar
My 12” on a phy open baffle had 2’ deep wings.
Dip at 280hz, peak at 140, then falling off fast below that.
Old 27th June 2020, 03:15 AM   #16
mp9 is offline mp9  United States
^ Are PHY drivers back in production?
Old 27th June 2020, 04:10 AM   #17
Idk, I used a philips driver.
  Reply to this post
Single FR on huge OB?Hide this!Advertise here!
OMG! They're huge! Zuhl Multi-Way 41 25th October 2019 11:42 AM
Why this huge cap is so light? siliconray Tubes / Valves 5 8th March 2012 01:25 PM
FS: Huge EV speakers dnewma04 Swap Meet 7 6th May 2009 12:48 PM
Single Ended, Single driver: In-room distortion measurements Gerrit Boers Full Range 4 27th November 2007 08:12 AM
Huge ! Madmike2 Multi-Way 14 16th June 2005 10:45 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
