Old 23rd June 2020, 10:56 PM   #1
norman bates is offline norman bates  United States
norman bates's Avatar
Default Baffle step inductor changing qts……………
Ok, I punched numbers in (online calculator) for a w8-2145 with a 4mh baffle step coil (1.24 ohms).
The Qts goes up from .45 to .495
For a sealed qtc .707 box.
Vb goes up from 1.63ft3 to 2.3ft3
F3 = fsb = 63hz goes down to 57hz (audible ? probably not)
Ported (standard 4th)
Vb goes from 3.43ft3 to 4.7ft3
Tuning goes from 35.7hz to 32.5hz
F3 goes from 34.13hz to 29hz
I assume (yup, I know the saying, but got to try), use the new numbers for ideal box size ?
Old 24th June 2020, 12:29 AM   #2
larryldspkr is offline larryldspkr  Canada
larryldspkr's Avatar
Goes to show you it's all just a big crap shoot! lol Is there a such thing as number bias?
Larry
Old 24th June 2020, 12:40 AM   #3
Thanks Larry.
I’ve been looking at the raven speaker.
But use with a 2145 and baffle step.
I got it sounding best when it left my house.
It needed huge bass boost for my volumes.
I learned of dispersion and distance bass (I find an 8” has bass out to 7’ or so).
1 listening spot, 1 pair of ears sitting No more than 7’ away, it was absolutely amazing.
Not a magnifier, but a smooth relaxing sound with no fatigue.
You just wanted to keep listening.
Old 24th June 2020, 06:26 AM   #4
GM is offline GM  United States
GM's Avatar
In theory, so always point it out, but truth be told I only did it for matching impedance systems, relying on the extra Vb I added for tower/column [MLTL] alignments and 'critically' damping the vent for the rest to tighten up any 'ringing' box alignments.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 24th June 2020, 10:44 AM   #5
chris661 is offline chris661  United Kingdom
chris661's Avatar
Well, maybe.
If you put the BSC resistor in parallel, what's the new DC resistance in series with the speaker?
Additional resistance in series affects Qes, which then changes Qts, which then changes the box alignment.
Chris
Bits of information and other things I've worked on: https://www.grimshawaudio.com/lab
Old 24th June 2020, 08:26 PM   #6
Hmmm
True, but 8ohm in parallel with 1.24ohm, it won't drop much.
Changing a Variable Baffle Step circuit scott68 Multi-Way 6 13th June 2017 06:10 PM
Baffle edge diffraction vs baffle step skogs Multi-Way 47 21st August 2016 05:15 PM
changing a power supply inductor WaFfLe Parts 3 12th March 2015 04:28 AM
Does open baffle suffer from baffle step? 454Casull Multi-Way 15 19th May 2012 03:12 PM
Baffle size and shape -> baffle step saschagabor Multi-Way 1 14th December 2010 10:45 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
