Can someone explain how this Linkwitz Transform works?
Old 19th October 2019, 10:02 AM   #21
3rutu5 is offline 3rutu5  Australia
is there anything passive one can do to lift that low end?
I've been looking around and some of the audio\bt boards can be customised with their EQ settings, which i didnt know was possible, but looks like the change would be applied to all channels, which isnt something i would want to do.
Old 19th October 2019, 10:24 AM   #22
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
Originally Posted by 5th element View Post
That article ends with these words:
As is quite obvious, the differences are small, and in the greater scheme of things can be ignored. The room will cause far greater errors than the circuit.
What errors?
IDK...the sound propagates from the sources at Mach1 velocity, bounces to the walls and extinguishes, arrives to the ears...the brain does some calculations
What errors?
It's like learning sex during the Victorian era: you get to the wedding night and there are many things to do that you never imagined.
Old 19th October 2019, 10:25 AM   #23
Just use a huge subwoofer driver that overwhelms the satellites
Old 19th October 2019, 10:35 AM   #24
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
There are passive tone controls which work by cutting rather than boosting but if you have enough gain in the amplifier amount to the same thing.
Also, this very simple circuit will give you a small apparent boost at lower frequencies Baffle Step Compensation
Rod Elliott's site is somewhere you should explore I think
Old 19th October 2019, 10:42 AM   #25
Cheers, I've used a.BSC a few times and it was quite good, just not sure if it will provide the little bass note in a box half the size of what I'm using currently. I will have a bit of a read through that site though
Old 19th October 2019, 10:47 AM   #26
Equalisers
Old 21st October 2019, 09:06 PM   #27
5th element is offline 5th element  United Kingdom
5th element's Avatar
What errors?
What errors?
He's talking about the circuits measured response Vs the simulation. Saying there's only very little error between the two and as the majority of the error is at frequencies below which we can hear it doesn't really matter.
No doubt the deviation is caused by capacitor tolerances.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 22nd October 2019, 08:36 AM   #28
chris661 is offline chris661  United Kingdom
chris661's Avatar
This is completely missing the point.
No, I think you're missing my point.
My point is this:
At low frequencies, a speaker in a room will need fairly large EQ adjustments in order to produce a flat response at the listening position.
Your method seems to be be to use a Linkwitz Transform to make the speaker flat, and then apply more EQ to sort out what the room is doing.
My method is to treat the room and speaker as one, and EQ the result.
We end up with the same thing (flat response) at the listening position, but your method means you've got an stage with 6-10dB of boost when there's a fair possibility that's going to be cut down by the next EQ in the chain.
Here are the measurements:
Simulated:
Measured at the listening position:
I'm sure you can imagine what my EQ curve looks like - no positive gain is required to get a flat response.
So, if I did happen to apply a Linkwitz Transform to get flat to 20Hz, I'd end up having to make even larger cuts at the "room EQ" stage to get back down to flat.
In conclusion, instead of saying "oh yes, it's a sealed box, it'll need a Linkwitz Transform", I'd suggest that the speaker should be measured in-room before any EQ (Linkwitz Transform or otherwise) is applied.
Chris
Old 22nd October 2019, 08:54 AM   #29
freddi is offline freddi  United States
freddi's Avatar
re: passive, "3rd order" closed boxes using a series capacitor can be useful as long as the amplifier driving impedance is low and their "boost" comes from a drop in impedance where its normally risen somewhat above Re.
And of course assisted 6th order vented boxes make good use of active EQ.
Old 22nd October 2019, 03:41 PM   #30
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
Just buy an inexpensive 10in active sub with adjustable crossover. I got a Polk PSW10 free shipping from Amazon and it integrates easily and sounds very nice. Super low hassle if you don't want to deal with all of this. This used to be only $100, but now seems like it is $150. However, it's very well made and probably worth it. No way you are going to do it yourself an nicely finished box, panel connectors, amp, crossover, driver, port tube, rubber feet, power cord, and grill cover for anywhere close to this price. But if the goal is the learning journey - then by all means DIY.
https://www.amazon.com/Polk-Audio-PS...dp/B0002KVQBA/
XRKaudio https://www.etsy.com/shop/XRKAudio
Can someone explain how this Linkwitz Transform works?Hide this!Advertise here!
ESP Linkwitz transform PCB d1030180 Subwoofers 18 29th November 2012 01:15 AM
Will a Linkwitz transform...transform the driver? AllenB Subwoofers 20 17th May 2010 11:24 PM
WTB: Linkwitz Transform PCB's ShinOBIWAN Swap Meet 34 17th June 2007 10:04 PM
linkwitz transform peace brainerd Subwoofers 4 31st January 2006 02:13 AM
Linkwitz Transform PCB? diydave Parts 2 1st September 2005 01:05 AM
Copyright ©1999-2019 diyAudio
