PRV full range drivers
Old 2nd October 2019, 04:18 PM   #1
halo71 is offline halo71  United States
Default PRV full range drivers
Been interested in building a pair of full range speakers. And the 10" full range driver by PRV. That Parts Express sells caught my eye.
Anyone used these drivers before? Or have suggestions for a first build using full range drivers?
Product Specifications
Nominal Diameter10"Power Handling (RMS)150 Watts
Power Handling (max)300 WattsImpedance8 ohms
Frequency Response60 to 14,000 HzSensitivity100 dB 2.83V/1m
Voice Coil Diameter2"
Thiele-Small Parameters
Resonant Frequency (Fs)60.12 HzDC Resistance (Re)5.4 ohms
Voice Coil Inductance (Le)0.27 mHMechanical Q (Qms)15.57
Electromagnetic Q (Qes)0.68Total Q (Qts)0.65
Compliance Equivalent Volume (Vas)1.67 ft.³Mechanical Compliance of Suspension (Cms)0.216 mm/N
BL Product (BL)9.78 TmDiaphragm Mass Inc. Airload (Mms)32.1g
Maximum Linear Excursion (Xmax)4 mmSurface Area of Cone (Sd)394 cm²
Materials of Construction
Cone MaterialPaperSurround MaterialCloth
Voice Coil Wire MaterialCCAVoice Coil FormerKapton® / Polyimide
Basket / Frame MaterialSteelMagnet MaterialFerrite
Mounting Information
Overall Outside Diameter10.10"Baffle Cutout Diameter9.25"
Depth4.51"# Mounting Holes8
Optimum Cabinet Size (determined using BassBox 6 Pro High Fidelity suggestion)
Sealed Volume2.09 ft.³Sealed F379.05 Hz
Vented Volume4.30 ft.³Vented F338.61 Hz
PRV Audio 10FR300PR 10" Professional Full-Range Speaker 8 Ohm
BrandPRV AudioModel10FR300PR
Part Number294-2888UPC602938021623
Product CategoryWoofersUnit of MeasureEA
Product Rating(4 Reviews)Weight8.25 lbs.
Old 2nd October 2019, 04:30 PM   #2
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
Which model are you referring to? Only see 10in mid bass from PRV - not full range.
If you want a full range from PRV, I have used the 5MR450NDY. There is a good thread on that here:
PRV 5MR450-NDY for FAST/WAW applications
For first build with full range drivers, I would suggest a 0.40x scale Karlsonator with either a 3FE25 or TC9FD. If you want more bass, try 0.53x with dual 3FE26-16 in parallel or dual TC9FD in parallel. Both are wonderful sounding. The little 0.40x scale with a single driver is very high bang for the buck, and easy to make. Make it out of foamcore board if this is your first full range project. No tools or sawdust. Cheap and sounds great.
Mini Karlsonator (0.53X) with Dual TC9FD's
Edit: just saw that you updated post with model number - 10FR300PR. This is a new one to me. Super high sensitivity but with a dramatic rising response and peak at 10kHz. This would lend itself well to a front loaded horn to balance that out. But without a horn, that 113dB (at 2.83v) peak will need a shelving filter or it will rip your ears off with shout when played loud.
https://www.parts-express.com/pedocs...spec-sheet.pdf
Published response:
PRV full range drivers-88e6f665-b312-40c5-be85-99541721c7ae-jpeg
File Type: jpeg 88E6F665-B312-40C5-BE85-99541721C7AE.jpeg (172.0 KB, 894 views)
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 2nd October 2019, 04:42 PM   #3
the driver PE sells....PRV Audio 10FR300PR 10" Professional Full-Range Speaker 8 Ohm
Old 2nd October 2019, 11:58 PM   #4
GM is offline GM  United States
GM's Avatar
Originally Posted by xrk971 View Post
Edit: just saw that you updated post with model number - 10FR300PR. But without a horn, that 113dB (at 2.83v) peak will need a shelving filter or it will rip your ears off with shout when played loud.
Guess one could listen ~50 deg off axis.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 3rd October 2019, 02:22 AM   #5
tomtt is offline tomtt
tomtt's Avatar
Location: kansas city mo, and on occasion, around the world ...
These are quite interesting ......
internet photographer
Old 3rd October 2019, 10:48 AM   #6
Same thing I was thinking.
Old 4th October 2019, 08:32 AM   #7
GM's Avatar
Greets!
Did some cab sims awhile back and the recommended reflex is a ~39 Hz max flat alignment, though due to having a bit too weak a motor [high Qts] needs some stuffing to smooth it out plus needs to be at least up against a good/solid wall to reach 105 dB peaks/8 W down low [no BSC required], so converted it into a MLTL to get some added vent damping, driver up to ear height.
Doesn't really increase peak performance other than much less damping, shorter vent required, so less likely to sound 'muffled' IME. All in all, should be a pretty decent performer for most folks, music genres and the price is right too.
As for the top end, that's what EQ and/or whizzer tweaking is for and recommend doing at least the $0.98 Lowther tweak: Modifications
38" ear height assumes 1.5" thick base, all dims inside [i.d.] and approximate:
L = 142.4 cm
WxD = 870.25 cm^2
driver offset = 49.7 cm
vent offset = 120.76 cm
Av = 81.07 cm^2 [10.16 cm/4" dia.]
Lv = 3.6 cm
stuffing density = .212 Kg total [concentrated in the driver area]
GM
Old 6th October 2019, 03:20 AM   #8
kd1yt is offline kd1yt  United States
I'm very interested to learn more about what peoples' experiences are with this driver. A friend of mine is interested in 'big but low cost' sound for a big indoor equestrian riding arena, and I've been kicking around the idea in my mind of mounting one of these in the middle of a 4x8 sheet of plywood, oriented long side horizontal (aiming to get rid of baffle step), with a sonotube well-braced off the back to get to the 4.30 cu ft that Parts Express says will give a lower f3 of 38hz.
Old 6th October 2019, 05:28 AM   #9
GM's Avatar
Only know what the published specs tell me below its ~180 Hz upper mass corner and that a rectangular baffle's BSC point will be somewhere between its two sides, so will need [2] 4x8 shts. just to get it down to a ~90.5 Hz/F3, plenty good enough for PA.
GM
Old 8th October 2019, 07:52 AM   #10
freddi is offline freddi  United States
freddi's Avatar
FWIW had one stuffed into a little "K10" size scaled Karlson for a couple of years but not done much - -maybe I'll measure it with port open then blocked. although "throaty" from the small K, I don't remember it sounding as shrill as my AN10 in a reflex.
This PRV and assume the MISCO 6x9 should be fun.
PRV full range driversHide this!Advertise here!
FS - Coaxial Drivers, BMS Compression Tweeters and RS Full Range Drivers wskitche Swap Meet 0 18th February 2019 07:54 PM
Design suggestion for 3 inch full range drivers ( Random drivers challenge ). Aatto Full Range 4 28th August 2018 05:44 PM
Korean Sonodyne S-654 Full-Range/Wide-Range Drivers thetubeguy1954 Full Range 6 18th January 2011 11:42 PM
Full range drivers. tade Full Range 5 2nd March 2005 03:59 PM
Full Range Drivers Mohan Varkey Introductions 11 3rd February 2002 11:27 AM
Copyright ©1999-2019 diyAudio
