Fostex FE108Sigma - Break in time
Old 19th September 2019, 04:39 PM   #11
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
The long-defunct Gemme Audio. They were pleased to call the design process 'nerve-shredding', which was presumably a euphemism for 'it took us a good few minutes to draw out the Factory design, then smooth it out for translam construction'. It also overlooked the fact (assuming they knew) that the manifold construction formed a functional part of the acoustic low pass.
They did finish them very nicely though, I'll give them that.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 19th September 2019, 04:54 PM   #12
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
And. IIRC, was asking something like $4k for them.
Gemme did inspire (a customers) the development of Lancet for the FE108e∑ (and a larger one in the same theme for the FF165wk).
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th September 2019, 05:34 PM   #13
perkri is offline perkri  Canada
Switching to CBC Radio 2- more music - and it varies
So, the stepped internal "horn" benefits from those indents?
I was thinking of "rounding" them with a bent piece of thin ply, and filling the cavities with sand.
Not a good idea?
P
Old 19th September 2019, 05:46 PM   #14
Scottmoose's Avatar
No, it's part of the acoustic low pass.
Old 19th September 2019, 06:04 PM   #15
frugal-phile(tm)
planet10's Avatar
If one looks at the scienc of ducts (bery important in HVAC for instance) an expension in the duct acts as a low pass filter, keeping unwanted “highs” (typically >250-300 Hz) from exiting the horn mouth.
In a chambered horn like th eone under discussion, the volume of the chamber and its exit/throat size also acts as a LP filter.
dave
Old 19th September 2019, 06:15 PM   #16
Thank you all!
Saves me contacting Foster
Old 20th September 2019, 12:47 AM   #17
Concrete or sand? The instructions call for sand to be "filled" into some of the internal cavities. Thoughts on using concrete instead? It'll be a heck of a lot easier to deal w the finishing if I use concrete in place of sand. Thoughts?
In other news... Put the drivers in the enclosures and crudely put in some filler. Terrible cables and connectors.
Had someone come into my listening room to check them out. They could not believe the sound coming from these speakers (nor could I)
And they are not even broken in yet!
They commented that they couldn't tell where the sound was coming from. Guess they disappeared
Cant wait for them to break in completely so I can tune the boxes.
So glad I followed through with this!
Old 20th September 2019, 12:48 AM   #18
frugal-phile(tm)
planet10's Avatar
Use sand.
dave
Fostex FE108Sigma - Break in timeHide this!Advertise here!
WTB: Fostex FE108sigma rogerfederer Swap Meet 0 3rd April 2017 05:33 PM
Pass Lab XA 160.5 Break-In Time swolff7963 Pass Labs 1 12th August 2012 06:53 PM
Break in time for TC Sounds 12's? SpinMonster Subwoofers 37 2nd June 2012 08:13 AM
Woofer break burn in time? promitheus Multi-Way 4 18th November 2003 12:42 PM
Copyright ©1999-2019 diyAudio
